Best SSID Practices for really old devices on WEP (I realize the irony)
So first let me say, I realize the irony of asking for best practices to setup a WEP SSID on my 5508 controllers.  THat being said, I have multiple sites with extremely old scan guns that only do 104bit wep.  I plan on locally switching this SSID and using static WEP 104bit key with MAC authentication, and then ACLing to limit my inherent security issues/exposure once someone compromises my WEP key.  So my question is this:
I believe the SSID should be set up per below.  Anyone see something I should change to make this work with really crappy/old radios?
802.11b/g only
No Multicast VLAN
Broadcast SSID
Flex Connect Local switching
Learn Client IP address
Diagnostic Channel - disabled
Aironet DISABLED ----> QUESTION should I enable Aironet so I can get Diagnostic Channel for troubleshooting?
Session Time out Disabled
Client Exclusion Disabled
Passive Client Disabled
Static Tunneling Disabled
Scan Defer Priority 4,5,6
Scan Defer Time 100ms (Thinking I should take this one up)
DTIM Period 1ms
No DHCP overides
No MFP
No load Balancing or Band Select
No NAC
No Voice
No Client Profiling
No WMM
Coverage Hole Detection Enabled
Peer to Peer Blocking Disable
  • Getting Started with Wireless
Re: Best SSID Practices for really old devices on WEP (I realize
That should be fine the scan defer is for if the AP heard traffic I. Those up categories it backs off that 100ms before it goes off channel to scan.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Would you all enable the aironet extensions so that I could do the diagnostic channel for debugging?  Or would you leave it disabled?
Hall of Fame Super Gold
Disable Aeronet IE at all cost.
looks ok
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
499
