Both radios useable for bridge connection
I have 2 1242 Accesspoints.
1 is the Root Bridge and the other the Nonrootbridge.
My question is can i use both radios for the link?
At the moment it works only with one radio.
It works with both g od. a Standart but not with both together.
If i turn on the second radio i have no connection.
best regard Dieter
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Both radios useable for bridge connection
yes
Thanks for your answer.
Hope you could help me with the configs.
I think it is a problem with the bridge-groups but i have no idea to solve this.
This is my root Bridge Config.
no service pad
service password-encryption
hostname root
enable secret 5 $1$XYrB$xov2WG/kNnnH1ldFMJEHz.
no aaa new-model
dot11 syslog
dot11 ssid test
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 071B245F5A1D1C1603
power inline negotiation prestandard source
username Cisco password 7 062506324F41
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid test
channel 2412
station-role root bridge
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid test
no dfs band block
channel dfs
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.0.1 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
And this the Non-Root Bridge:
no service pad
hostname non-root
enable secret 5 $1$LSB2$q0iBDYt3eciyALsil0yf50
no aaa new-model
dot11 syslog
dot11 ssid test
   authentication open
   infrastructure-ssid optional
   wpa-psk ascii 7 131112011F1801393F
bridge irb
no ip address
no ip route-cache
shutdown
ssid test
station-role non-root bridge
bridge-group 1
no ip address
no ip route-cache
ssid test
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.0.2 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
best regards Dieter
297
