Community Member
bridge to bridge and bridge to access-point via wireless is it possible.
here;s my topology i am trying to configure. i have a router whose ethernet is connected to a bridge.this bridge 1 is connected to a bridge 2 via wireless. now i am trying to connect a access-point via wireless to this bridge2. is it possible for bridge 2 to support connectivity to the bridge1 and the access-point both of them via wireless.
can someone pls help me on this.
waiting for someone to reply.
Re: bridge to bridge and bridge to access-point via wireless is
You can set up each radio in the access point for different functionality. Considering the scenario, this can be done by setting up the SSID for the G radio and another SSID for the A radio. Then, set the role in the radio network parameter for the G radio to access point and for the A radio to the root bridge role.
ou can prevent unauthorized users from reconfiguring your access point/bridge and viewing configuration information. Typically, you want network administrators to have access to the access point/bridge while you restrict access to users who connect through a terminal or workstation from within the local network.
To prevent unauthorized access to your access point/bridge, you should configure one of these security features:
Username and password pairs, which are locally stored on the access point/bridge. These pairs authenticate each user before that user can access the access point/bridge. You can also assign a specific privilege level (read only or read/write) to each username and password pair.
