Brocade FCX PoE with Cisco LAP
We are using Brocade FCX PoE switches with AIR-LAP1142N-N-K9 and AIR-LAP1252AG-A-K9. We have some issues that may or may not be due to the Brocade-LAP links but would like a reality check with other Brocade sites. If you are successfully using Brocade PoE switches with Cisco LAPs can you give a typical port config?
Example configs we have have tried:
interface ethernet 1/1/2
no cdp enable
inline power power
interface ethernet 2/1/23
port-name TX_LWAP01
no fdp enable
no cdp enable
inline power power-by-class 4"
interface ethernet 2/1/12
inline power
Typical switch:
UNIT 1: compiled on Jun 17 2010 at 18:20:53 labeled as FCXS07100a
HW: Stackable FCX648S-HPOE
John
  • Getting Started with Wireless
Everyone's tags (3)
1 REPLY
Re: Brocade FCX PoE with Cisco LAP
Hi John,
Unfortunetally, I will not be able to help you from the switch side. Maybe someone else reading the thread will do; but I wanted to tell you that 11n Access Points have special POE requirements to function as expected.
Check this http://www.cisco.com/en/US/prod/switches/epoe.html if you haven't seen it yet.
Hope this help you
Have a good day
Serge
1283
