C2700 AP Not Joinining vWLC
NETAD
Level 4
Level 4
Hello I'm trying to get my AP to join my vWLC and it's not working. I've tried multiple versions of the vWLC with the same behavior. Something is wrong with my AP. It joins for a brief moment then it drops. Can you assist please. I've tried resetting through the mode button but that didn't do it. I'm using 8.3.102 for the controller version
I got some messages from the AP while joining.
The AP logs show that the AP is still getting the IP from DHCP server. Probably you missed to to save the static config on the AP (write mem).
and I see that the AP joins the WLC also creates a DTLS tunnel  but for some reason keeps on sending a new Join request to the same WLC even after that. I suspect that there may be something wrong on the WLC side config. Is this the only AP that you have or any other AP is able to associate to this WLC ?
I see this log in the AP:
Mar  3 20:40:18.903: %PARSER-4-BADCFG: Unexpected end of configuration file
It may be normal but I never noticed this log in the AP bootup. So , not sure.
Since, the AP is able to join the WLC once but drops off again, let's try this:
>> Check the config on the WLC once again.
>> Run "debug capwap errors enable" on the WLC during the whole process.
>> Initiate a continuous ping to the AP from the WLC VLAN to make sure that the AP is reachable and it doesn't lose its IP after the association.
Cheers,
Manish
32 Replies 32
I'd say that the problem may be this:
*Mar  3 20:38:41.659: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Renewing DHCP IP.
*Mar  3 20:38:44.759: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.88.88.11, mask 255.255.255.0, hostname APa89d.2188.3f5c
Double check if the IP address provided by DHCP is correct. The IP is in a different network, then, you need a gateway to get to the WLC.
-If I helped you somehow, please, rate it as useful.-
I'm able to ping the wlc from the AP.
Going with your information that the AP joins for a brief moment and then drops off , It appears to me that the AP may be losing the IP every now and then. Where is the AP getting IP from ? What is the lease time ? Can u configure a static IP on the AP and also a static entry for the WLC in the AP ?
Cheers,
Manish
It gets them from a win2k12 configured for DHCP. Can you share the commands to hardcode the IPs?
You can login to the AP console and issue :
AP#capwap ap ip address
AP#lcapwap ap ip default-gateway
AP#lcapwap ap controller ip address
AP#lcapwap ap hostname
But you will have to make sure that this static IP is excluded in the DHCP server. Otherwise , there may be an IP conflict.
Cheers,
Manish
Here's the log after static assignment.
Check firewall.
There's no firewall actually. It's literally one switch with one server running win2k12 and and the WLC running on vmware workstation. The server is in vlan 30(10.30.30.0/24) and the AP is in vlan 88(10.88.88.0/24) where the switch is doing layer 3 routing.
Put the AP and the controller in the same VLAN.
Unfortunately that also didn't do it. This time I used a dhcp pool on the switch with the DNS name to resolve the controller and join. The AP resolves the name correctly but not able to join still. What should I try next you think?
Cheers,
Manish
I finally got it to join. Don't know how. I re-installed the wlc even though I've done that many times but it seems like putting them on the same subnet is what made it work. Thank you all for your assistance on this.
Leo Laohoo
@NETAD wrote:
*Mar  3 20:37:56.155: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.30.30.77 obtained through DHCP
Post the complete output to the following commands:
1.  WLC:  sh sysyinfo;
2.  WLC:  sh time; and
3.  AP:  sh version
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.102.0
RTOS Version..................................... 8.3.102.0
Bootloader Version............................... 8.3.15.96
Emergency Image Version.......................... 8.3.102.0
OUI File Update Time............................. Sun Sep 07 10:44:07                                                  IST 2014
Build Type....................................... DATA + WPS
System Name...................................... vWLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.163                                                 1
IP Address....................................... 10.30.30.77
IPv6 Address..................................... ::
System Up Time................................... 1 days 22 hrs 31 mi                                                 ns 15 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US  - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 00:0C:29:36:96:F0
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
APa89d.2188.3f5c#sho version
Cisco IOS Software, C2700 Software (AP3G2-K9W8-M), Version 15.3(3)JD, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 29-Jul-16 04:06 by prod_rel_team
ROM: Bootstrap program is C2700 boot loader
BOOTLDR: C2700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB5m, RELEASE SOFTWARE (fc2)
APa89d.2188.3f5c uptime is 4 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JD/ap3g2-k9w8-xx.153-3.JD"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2702I-A-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW1909NL7J
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.102.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A8:9D:21:88:3F:5C
Part Number                          : 73-15824-03
PCB Serial Number                    : FOC190753G3
Top Assembly Part Number             : 068-100373-01
Top Assembly Serial Number           : FCW1909NL7J
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP2702I-A-K9
Configuration register is 0xF
NTP isn't configured on my controller.
