can AIR-CAP1602i-x-k9 be converted to stand alone??
can air-cap1602i-x-k9 be converted to stand alone??
Re: can AIR-CAP1602i-x-k9 be converted to stand alone??
Yes , you can convert the AP to stanadlone  by pushig the below image  into the AP
http://software.cisco.com/download/release.html?mdfid=284366503&flowid=37523&softwareid=284180979&release=15.2.4-JB3a&relind=AVAILABLE&rellifecycle=ED&reltype=latest
You can use the below method to convert the same
Using a TFTP Server to Return to a Previous Release
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release
using a TFTP server: This method is for local conversion.
Step 1 The PC on which your TFTP server software runs must be configured with a static IP address in the range
of 10.0.0.2 to 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a
1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200
series access point.
Step 4 Connect the PC to the access point using a Category 5 or better Ethernet cable.
Step 5 Disconnect power from the access point.
Step 6 Press and hold the MODE button while you reconnect power to the access point.
Step 7 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds), and release the
MODE button.
Step 8 Wait until the access point reboots as indicated by all LEDs turning green followed by the Status LED
blinking green.
Thanks..
VIP Purple
HI,
Yes you can.
  • k9w7 – autonomous IOS----> You need this image
  • k9w8 – full lightweight IOS (this is what is bundled in the WLC .aes image, and is factory installed on “mesh” APs)
Here is the procedure:
https://supportforums.cisco.com/docs/DOC-15126
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Hope it helps.
Dont forget to rate helpful posts
Yes you can convert lightweight CAPWAP 1602 to autonomous standalone AP. Please refer the link below.1602.png
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/rn_aap_OL30935_01.html#wp381669
1601
