can cisco 3560 switch act as wireless controlrer
wireless issue
VIP Purple
HI Mohamed,As per knowledge:
HI Mohamed,
As per knowledge: No its not acted as Wireless Controller.
Dont forget to rate helpful posts
VIP Purple
Not 3560, but 3650 can do
Not 3560, but 3650 can do that
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet_c78-729449.html
If you have 3650 model & having some issue, then refer below post that may help you. Even though it refer 3850 configuration should be very similar on 3650
http://mrncciew.com/2013/09/29/getting-started-with-3850/
Rasika
**** Pls rate all useful respones ****
29
