Can i Mix AP models AIR-LAP1142N-I-K9 With AIR-LAP1142N-E-K9 On Same Controller?
Controller
WiSM WLAN Service Module               WS-SVC-WISM-1-K9
Software Version              7.0.250.0
1 ACCEPTED SOLUTION
VIP Purple
HI,What is the country code
HI,
What is the country code configured on WLC.
AIR-LAP1142N-I-K9 : It is for Belarus,Marcedonia.....etc
AIR-LAP1142N-E-K9: It is for Europe domain
If your WLC is is configured for any europiaon country then AIR-LAP1142N-E-K9 will join to wlc and AIR-LAP1142N-I-K9 qill not join.
If you want to join both AP to WLC then you must configure multiple country code on WLC.
Note:
Running multiple country codes in a WLC is a not a good idea,  be aware that only common channels will be allowed. Power will also be curtailed to the most common one. The best thing is to get another WLC and group them by using the same regulatory domain.
Dont forget to rate helpful posts
1 REPLY
VIP Purple
HI,
Note:
87
