can't get 1532i to associate to 5508 WLC running 7.6.130.0
Greetings,
I've got 20 or so APs on a 5508 WLC.  Most of the APs are 1242, one is 3602.  I'm now trying to get a 1532i to associate to the 5508 and it's not happening.  This is the first 1532 on this controller.
Also, I got this 1532 AP from a sister site and they had it configured as Autonomous in wgb mode, so I had to do the Autonomous to Unified Conversion.  This conversion appeared to go successfully.  But now the AP won't associate to my controller.
Following is what happens from the AP's console :
AP78da.6e59.e58a#reload
Proceed with reload? [confirm]
Writing out the event log to flash:/event.log ...
Write of event.log done
*Oct 28 20:27:37.151: %SYS-5-RELOAD: Reload requested by Cisco on console. Reload Reason: Reload.
*Oct 28 20:27:37.155: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
        *Oct 28 20:27:39.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.132.249.5:5246
*Oct 28 20:27:40.039: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
System Bootstrap, Version U-Boot 1.1.4-gf5ee82b1-dirty Corfu , RELEASE SOFTWARE
Build Date: Oct 17 2013 - 18:08:55
corfu - Scorpion 1.0
DRAM:  256 MB
Now running in RAM - U-Boot at: 8ffbc000
Flash Manuf Id 0xc2, DeviceId0 0x20, DeviceId1 0x14
flash size 1MB, sector count = 256
Atheros on-chip NAND FLash Controller Driver, Version 0.1 (c) 2010 Atheros Communications, Ltd.
Ath Nand ID[8ffee17c]: 2c:f1:80:95:02
ONFI MICRON      MT29F1G08ABADAWP
Micron NAND 128MiB 3,3V 8-bit [128MB]
size = 128MB
Hit any key to stop autoboot:  0
boot_method is set to IOS_BOOT, boot IOS bootloader in NOR flash
Loading .text @ 0x84000000 (207840 bytes)
Loading .rodata @ 0x84032be0 (39008 bytes)
Loading .data @ 0x8403c440 (3264 bytes)
Loading .data.rel.local @ 0x8403d100 (1084 bytes)
Loading .data.rel @ 0x8403d53c (124 bytes)
Loading .data.rel.ro @ 0x8403d5b8 (960 bytes)
Clearing .bss @ 0x8403d980 (161116 bytes)
Clearing .scommon @ 0x84064edc (56 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.HW Test Status(0)
Ath Nand ID: 95:80:f1:2c:00
Using driver version 1 for media type 2
Valid buffers 146
total146  146
success found all blocks
start end 65 85
found in range
high low end 2728 2089 85
Xmodem file system is available.
mifs[0]: 15 files, 5 directories
mifs[0]: Total bytes     :  131334144
mifs[0]: Bytes used      :    7966720
mifs[0]: Bytes available :  123367424
mifs[0]: mifs fsck took 0 seconds.
Base Ethernet MAC address: 78:da:6e:59:e5:8a
Setup MAC....
Waiting for PHY auto negotiation to complete...Port 0 Negogiation success.
Ethernet speed is 100 Mb - FULL duplex
Scorpion  ----> F1 PHY *
: cfg1 0xf cfg2 0x7115
Loading "flash:/ap1g3-k9w8-mx.152-4.JB6/ap1g3-k9w8-mx.152-4.JB6"...##########################################################################################################################################################################################################################################################################################################################################################################
File "flash:/ap1g3-k9w8-mx.152-4.JB6/ap1g3-k9w8-mx.152-4.JB6" uncompressed and installed, entry point: 0x60080000
executing...
Stop MAC.
Starting IOS...
cp0 timer begin value is set as 1000
prid= 19750
Starts main.
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1530 Software (ap1g3-K9W8-M), Version 15.2(4)JB6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 22-Aug-14 11:03 by prod_rel_team
Initializing flashfs...
Ath Nand ID: 95:80:F1:2C:00
Valid buffers 146
total146  146
start end 65 85
found in range
mifs[4]: 15 files, 5 directories
mifs[4]: Total bytes     : 131334144
mifs[4]: Bytes used      : 7966720
mifs[4]: Bytes available : 123367424
mifs[4]: mifs fsck took 2 seconds.
mifs[4]: Initialization complete.
...done Initializing flashfs.
:pci_init_board:521 *** Warning *** : PCIe1 WLAN Module not found !!!
pci_rc2_init_board:570 PCIE Controller Init Bus Master Enable
:pci_rc2_init_board:593 PCIe2 WLAN Module Found !!!
soap_pci_subsys_init:706 Bus Master/Mem Enable on pci_write side
soap_pci_subsys_init(713): PCI vendor ID: 0x168C ret:0
soap_pci_subsys_init(715): PCI device ID: 0x33 ret:0
Disabling 802.3az feature on port 0
sgmii cal value = 0xE
Disabling 802.3az feature on port 1.
SGMII setup done, status is 0x2
Radio0  present 9550 9000 0 0 0 0
Rate table has 282 entries (12 legacy/96 11n/174 11ac)
Radio1  present 9590 9000 0 0 B2000000 1
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1532I-A-K9 (MIPS74k) processor (revision 27) with 204800K/57344K bytes of memory.
Processor board ID FTX1813201L
MIPS74k CPU at 700MHz, revision number 0x0000
Last reset from power-on
LWAPP image version 7.6.100.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 78:DA:6E:59:E5:8A
Part Number                          : 74-11942-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC180951ZR
Top Assembly Part Number             : 000-00000-00
Top Assembly Serial Number           : FTX1813201L
Top Revision Number                  : 23
Product/Model Number                 : AIR-CAP1532I-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:09.895: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)mips74k_config_radio_pci(302): PCI CMD write: 0x356
*Mar  1 00:00:14.391: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to upEnterprise mode: 0x44000000
*Mar  1 00:00:14.895: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (2)
*Mar  1 00:00:14.971: ath_load_ctl_pwr_tbl() dot11radio 2G loading CTL binary flash:/ap1g3-k9w8-mx.152-4.JB6/CO2.bin version# 3.0
*Mar  1 00:00:15.419: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (2)
*Mar  1 00:00:15.419: ath_load_ctl_pwr_tbl() dot11radio 5G loading CTL binary flash:/ap1g3-k9w8-mx.152-4.JB6/CO5.bin version# 3.4
*Mar  1 00:00:15.699: CDP_PD: Power Source: 4-pair Power Injector
*Mar  1 00:00:15.723: AP Mesh platform identified (backhaul config:0x2, access:0xF)
*Mar  1 00:00:15.735: Starting Ethernet promiscuous mode
*Mar  1 00:00:15.735: Skipping Ethernet bridge initializaion
*Mar  1 00:00:16.431: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:18.363: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:18.363: %SNMP-5-COLDSTART: SNMP agent on host AP78da.6e59.e58a is undergoing a cold start
*Mar  1 00:00:18.399: %MESH-6-BVI_CREATED: Mesh BVI1 interface created
*Mar  1 00:00:18.399: ath_ACIF_set_distance: Retrieved existing timeout value: 25us for distance: 0km
*Mar  1 00:00:18.399: ath_ACIF_set_distance: Setting new timeout value: 45us for distance: 3km
*Mar  1 00:00:18.399: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Mar  1 00:00:18.619: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:18.619: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:18.619: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to uplwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:18.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:20.399: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:00:37.015: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:37.027: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:38.027: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:38.035: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:39.027: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:39.067: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:40.023: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Mar  1 00:00:40.067: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:01:13.531:  Mesh setting the ethernet port 0 state to 2
*Mar  1 00:01:13.531: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:01:15.531: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:01:16.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:01:18.639: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Mar  1 00:01:18.651: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:01:19.639: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:01:19.671: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:20.671: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:28.643: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:01:28.759: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.132.120.85, mask 255.255.255.0, hostname AP78da.6e59.e58a
*Mar  1 00:01:28.759: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:01:33.791: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Mar  1 00:01:33.855: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Translating "CISCO-CAPWAP-CONTROLLER.americas.mittalco.com"...domain server (10.132.250.250) [OK]
*Mar  1 00:01:33.867: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:01:34.855: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:34.855: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:01:34.915: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:35.915: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:44.855: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 28 20:29:44.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.132.249.5 peer_port: 5246
*Oct 28 20:29:44.495: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.132.249.5 peer_port: 5246
*Oct 28 20:29:44.495: %CAPWAP-5-SENDJOIN: sending Join Request to 10.132.249.5
*Oct 28 20:29:44.499: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Oct 28 20:29:44.499: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Oct 28 20:29:44.499: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Oct 28 20:29:44.499: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.132.249.5
*Oct 28 20:29:49.495: %CAPWAP-5-SENDJOIN: sending Join Request to 10.132.249.5
*Oct 28 20:30:43.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.132.249.5:5246
*Oct 28 20:30:44.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Oct 28 20:30:44.095: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Oct 28 20:30:44.135: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct 28 20:30:45.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct 28 20:30:45.155: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct 28 20:30:46.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct 28 20:30:54.095: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 28 20:30:52.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.132.249.5 peer_port: 5246
*Oct 28 20:30:52.499: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.132.249.5 peer_port: 5246
*Oct 28 20:30:52.499: %CAPWAP-5-SENDJOIN: sending Join Request to 10.132.249.5
*Oct 28 20:30:52.499: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Oct 28 20:30:52.503: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Oct 28 20:30:52.503: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Oct 28 20:30:52.503: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.132.249.5
*Oct 28 20:30:57.499: %CAPWAP-5-SENDJOIN: sending Join Request to 10.132.249.5
Hall of Fame Super Silver
Wahoo have to add the MAC
You have to add the MAC address of the 1530 to the WLC mac filter list before the AP will join. Here is a link that explains it.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1530/quick/guide/ap1532qsg.html#pgfId-45801
Scott
-Scott
Also make sure your WLC is on
Also make sure your WLC is on a supported code for all your access points.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Scott
-Scott
831
