Can the Cisco AIR-AP1261N-A-K9 AP be controlled by a wireless LAN controller?
We have the Cisco AIR-AP1261N-A-K9  ...... is this unit compatible with a Wireless LAN controller?  If not, can it be upgraded to allow this?
  • Getting Started with Wireless
VIP Purple
Hi Shane,
Yes, it is. You require min 7.0 software code on your WLC.Refer table 2 of the given reference
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
If AP is autonomous mode, then you may need to load a recovery image (to convert to LWAP) prior to connect to a WLC. This post may help you on that.
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
**** Pls rate all useful resposnes ****
Gold
Re: Can the Cisco AIR-AP1261N-A-K9 AP be controlled by a wireles
Hi Shane,
Looks like you have got a autonomous access point. But don't worry this can be converted to light weight and can be used with controller based solution.
Please checks below post which details how to convert autonomous to lightweight ap.
Using a TFTP Server to Return to a Previous Release
https://supportforums.cisco.com/docs/DOC-18268
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
Hope that helps
Najaf
89
