Cannot access Cisco 1852e through web interface
rmiller
I have a Cisco 1852e on my network. It is broadcasting and I can connect and access the internet. I can also ping the device and can SSH into it but I cannot access it through the web interface. How can I turn on http on this device? The CLI command ip http server does not do anything.
7 Replies 7
Hi @rmiller
 If the Access Point is joined to an WLC you cannot access its web interface, only CLI is available.
 If the Access Point is in Mobility Express mode, then you should connect to its web interface by using the IP address.
 For Mobility Express you dont need to enable http service it is enabled by default.
-If I helped you somehow, please, rate it as useful.-
There is no controller -- is that what you mean by WLC? How do I confirm whether it is in Mobility Express mode?
You can access via CLI and issue show running-config. You might see Mobility Express somewhere. Or you can share here.
I would say it's enabled but I'm not exactly sure what to look for -- there's nothing too explicit.
(Cisco Controller) >show run-config
System Inventory
NAME: "Chassis" , DESCR: "Cisco Aironet 1850 Series Mobility Express"
PID: AIR-AP1852E-B-K9, VID: 8.3.102.0, SN: KWC205206LP
Burned-in MAC Address............................ 2C:0B:E9:C8:39:00
Maximum number of APs supported.................. 25
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.102.0
System Name...................................... Service Dept Wireless
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2250
IP Address....................................... xx.xx.200.251
Last Reset....................................... 0: unknown
System Up Time................................... 1 days 5 hrs 50 mins 14 secs
System Timezone Location......................... (GMT -7:00) Mountain Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 3
OUI Classification Failure Count................. 170
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
Backup Controller Configuration
AP primary Backup Controller ....................
AP secondary Backup Controller ..................
System Time Information:
Time............................................. Sat Jul 8 17:04:18 2017
Timezone delta................................... 0:0
Timezone location................................ (GMT -7:00) Mountain Time (US and Canada)
NTP Servers
NTP Polling Interval......................... 86400
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 time.nist.gov Not Synched AUTH DISABLED
2 0 1.ciscome.pool.ntp.org Not Synched AUTH DISABLED
3 0 2.ciscome.pool.ntp.org Not Synched AUTH DISABLED
Redundancy Information
Redundancy Mode ................................. SSO DISABLED
Local State...................................... ACTIVE
Peer State....................................... N/A
Unit............................................. Primary
Unit ID.......................................... 2C:0B:E9:C8:39:00
Redunadancy State................................ N/A
Mobility MAC..................................... 2C:0B:E9:C8:39:00
Redundancy Management IP Address................. 0.0.0.0
Peer Redundancy Management IP Address............ 0.0.0.0
Redundancy Port IP Address....................... 0.0.0.0
Peer Redundancy Port IP Address.................. 169.254.0.0
AP Bundle Information not supported.
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
WLANCC prerequisite features..................... Disabled
UCAPL prerequisite features...................... Disabled
DTLS WLC MIC .................................... SHA2
secret obfuscation............................... Enabled
Strong Password Check Features
case-check.................................... Enabled
consecutive-check............................. Enabled
default-check................................. Enabled
username-check................................ Enabled
position-check................................ Enabled
case-digit-check.............................. Enabled
Min. Password length.......................... 3
Min. Upper case chars......................... 0
Min. Lower case chars......................... 0
Min. Digits chars............................. 0
Min. Special chars............................ 0
Mgmt User
Password Lifetime [days]...................... 0
Password Lockout.............................. Disabled
Lockout Attempts.............................. 3
Lockout Timeout [mins]........................ 5
SNMPv3 User
Network Information
RF-Network Name............................. default
DNS Server IP............................... 127.0.0.1
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Disable
Secure Web Mode RC4 Cipher Preference....... Disable
Secure Web Mode SSL Protocol................ Disable
OCSP........................................ Disabled
OCSP responder URL..........................
Secure Shell (ssh).......................... Enable
Secure Shell (ssh) Cipher-Option High....... Disable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
IPv4 AP Multicast/Broadcast Mode............ Multicast Address : 0.0.0.0
IPv6 AP Multicast/Broadcast Mode............ Multicast Address : ::
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
IGMP Query Interval......................... 20 seconds
MLD snooping................................ Disabled
MLD timeout................................. 60 seconds
MLD query interval.......................... 20 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Enable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
Mesh Backhaul RRM........................... Disable
AP Fallback ................................ Enable
Web Auth CMCC Support ...................... Disabled
Web Auth Redirect Ports .................... 80
Web Auth Proxy Redirect ................... Disable
Web Auth Captive-Bypass .................. Disable
Web Auth Secure Web ....................... Enable
Web Auth Secure Redirection ............... Disable
Fast SSID Change ........................... Enabled
IP/MAC Addr Binding Check .................. Enabled
Link Local Bridging Status ................. Disabled
CCX-lite status ............................ Disable
WebPortal Online Client .................... 0
WebPortal NTF_LOGOUT Client ................ 0
mDNS snooping............................... Disabled
mDNS Query Interval......................... 0 minutes
Web Color Theme............................. Default
Capwap Prefer Mode.......................... IPv4
Network Profile............................. Typical Deployment with Data traffic
Client ip conflict detection (DHCP) ........ Disabled
Mesh BH RRM ................................ Disable
Mesh Aggressive DCA......................... Disable
Mesh Auto RF................................ Disable
HTTP Profiling Port......................... 80
HTTP-Proxy Ip Address....................... 0.0.0.0
HTTP-Proxy Port............................. 80
Port Summary
STP Admin Physical Physical Link Link
Pr Type Stat Mode Mode Status Status Trap POE
1 Normal Forw Enable Auto 1000 Full Up Enable N/A
AP Summary
Number of APs.................................... 1
Global AP User Name.............................. xx
Global AP Dot1x User Name........................ Not Configured
AP Name Slots AP Model Ethernet MAC Location Country IP Address Clients DSE Locaton
AP2C0B.E9C8.3900 2 AIR-AP1852E-B-K9 2c:0b:e9:c8:39:00 default location US xx.xx.200.148 3 [0 ,0 ,0
AP Tcp-Mss-Adjust Info
AP Name TCP State MSS Size
AP2C0B.E9C8.3900 disabled -
AP Location
Total Number of AP Groups........................ 1
Site Name........................................ default-group
Site Description................................. <none>
NAS-identifier................................... none
Client Traffic QinQ Enable....................... FALSE
DHCPv4 QinQ Enable............................... FALSE
AP Operating Class............................... Not-configured
Capwap Prefer Mode............................... Not-configured
RF Profile
2.4 GHz band..................................... <none>
5 GHz band....................................... <none>
WLAN ID Interface Network Admission Control Radio Policy
1 management Disabled None
*AP3600 with 802.11ac Module will only advertise first 8 WLANs on 5GHz radios.
Lan Port configs
LAN Status POE RLAN
1 Disabled Disabled None
2 Disabled None
3 Disabled None
External 3G/4G module configs
LAN Status POE RLAN
1 Disabled None
AP Name Slots AP Model Ethernet MAC Location Port Country Priority
AP2C0B.E9C8.3900 2 AIR-AP1852E-B-K9 2c:0b:e9:c8:39:00 default location 1 US 1
RF Profile
Number of RF Profiles............................ 6
Out Of Box State................................. Disabled
Out Of Box Persistence........................... Disabled
RF Profile Name Band Description 11n-client-only Applied
High-Client-Density-802.11a 5 GHz <none> disable No
High-Client-Density-802.11bg 2.4 GHz <none> disable No
Low-Client-Density-802.11a 5 GHz <none> disable No
Low-Client-Density-802.11bg 2.4 GHz <none> disable No
Typical-Client-Density-802.11a 5 GHz <none> disable No
Typical-Client-Density-802.11bg 2.4 GHz <none> disable No
RF Profile name................................ High-Client-Density-802.11a
Description...................................... <none>
AP Group Name.................................... <none>
Radio policy..................................... 5 GHz
11n-client-only.................................. disabled
Transmit Power Threshold v1...................... -65 dBm
Transmit Power Threshold v2...................... -67 dBm
Min Transmit Power............................... 7 dBm
Max Transmit Power............................... 30 dBm
802.11a Operational Rates
802.11a 6M Rate.............................. Disabled
802.11a 9M Rate.............................. Disabled
802.11a 12M Rate............................. Mandatory
802.11a 18M Rate............................. Supported
802.11a 24M Rate............................. Mandatory
802.11a 36M Rate............................. Supported
802.11a 48M Rate............................. Supported
802.11a 54M Rate............................. Supported
Max Clients...................................... 200
WLAN ID Max Clients
1 600
Trap Threshold
Clients...................................... 12 clients
Interference................................. 10 %
Noise........................................ -70 dBm
Utilization.................................. 80 %
Multicast Data Rate.............................. 0
Rx Sop Threshold................................. -78 dBm
Cca Threshold.................................... 0 dBm
Slot Admin State:................................ Enabled
Band Select
Probe Response............................... Disabled
Cycle Count.................................. 2 cycles
Cycle Threshold.............................. 200 milliseconds
Expire Suppression........................... 20 seconds
Expire Dual Band............................. 60 seconds
Client Rssi.................................. -80 dBm
Client Mid Rssi.............................. -80 dBm
Load Balancing
Denial....................................... 3 count
Window....................................... 5 clients
Coverage Data
Data......................................... 176 dBm
Voice........................................ 176 dBm
Minimum Client Level......................... 3 clients
Exception Level.............................. 25 %
DCA Channel List................................. 36,40,44,48,52,56,60,64,149,
153,157,161,100,104,108,112,
116,120,124,128,132,136,140
DCA Bandwidth.................................... 20
DCA Foreign AP Contribution...................... enabled
802.11n MCS Rates
MCS-00 Rate.................................. enabled
MCS-01 Rate.................................. enabled
MCS-02 Rate.................................. enabled
MCS-03 Rate.................................. enabled
MCS-04 Rate.................................. enabled
MCS-05 Rate.................................. enabled
MCS-06 Rate.................................. enabled
MCS-07 Rate.................................. enabled
MCS-08 Rate.................................. enabled
MCS-09 Rate.................................. enabled
MCS-10 Rate.................................. enabled
MCS-11 Rate.................................. enabled
MCS-12 Rate.................................. enabled
MCS-13 Rate.................................. enabled
MCS-14 Rate.................................. enabled
MCS-15 Rate.................................. enabled
MCS-16 Rate.................................. enabled
MCS-17 Rate.................................. enabled
MCS-18 Rate.................................. enabled
MCS-19 Rate.................................. enabled
MCS-20 Rate.................................. enabled
MCS-21 Rate.................................. enabled
MCS-22 Rate.................................. enabled
MCS-23 Rate.................................. enabled
MCS-24 Rate.................................. enabled
MCS-25 Rate.................................. enabled
MCS-26 Rate.................................. enabled
MCS-27 Rate.................................. enabled
MCS-28 Rate.................................. enabled
MCS-29 Rate.................................. enabled
MCS-30 Rate.................................. enabled
MCS-31 Rate.................................. enabled
Client Network Preference....................... default
RF Profile name................................ High-Client-Density-802.11bg
Radio policy..................................... 2.4 GHz
Transmit Power Threshold v1...................... -70 dBm
802.11b/g Operational Rates
802.11b/g 1M Rate............................ Disabled
802.11b/g 2M Rate............................ Disabled
802.11b/g 5.5M Rate.......................... Disabled
802.11b/g 11M Rate........................... Disabled
802.11g 6M Rate.............................. Disabled
802.11g 9M Rate.............................. Supported
802.11g 12M Rate............................. Mandatory
802.11g 18M Rate............................. Supported
802.11g 24M Rate............................. Supported
802.11g 36M Rate............................. Supported
802.11g 48M Rate............................. Supported
802.11g 54M Rate............................. Supported
WLAN ID Max Clients
1 600
Trap Threshold
Rx Sop Threshold................................. -82 dBm
Band Select
Load Balancing
Coverage Data
DCA Channel List................................. 1,6,11
802.11n MCS Rates
RF Profile name................................ Low-Client-Density-802.11a
Transmit Power Threshold v1...................... -60 dBm
Min Transmit Power............................... -10 dBm
802.11a 6M Rate.............................. Mandatory
802.11a 9M Rate.............................. Supported
WLAN ID Max Clients
1 600
Trap Threshold
Rx Sop Threshold................................. -80 dBm
Band Select
Load Balancing
Coverage Data
Minimum Client Level......................... 2 clients
802.11n MCS Rates
RF Profile name................................ Low-Client-Density-802.11bg
802.11b/g 1M Rate............................ Mandatory
802.11b/g 2M Rate............................ Mandatory
802.11b/g 5.5M Rate.......................... Mandatory
802.11b/g 11M Rate........................... Mandatory
802.11g 6M Rate.............................. Supported
802.11g 12M Rate............................. Supported
WLAN ID Max Clients
1 600
Trap Threshold
Rx Sop Threshold................................. -85 dBm
Band Select
Load Balancing
Coverage Data
802.11n MCS Rates
RF Profile name................................ Typical-Client-Density-802.11a
WLAN ID Max Clients
1 600
Trap Threshold
Rx Sop Threshold................................. AUTO
Band Select
Load Balancing
Coverage Data
802.11n MCS Rates
RF Profile name................................ Typical-Client-Density-802.11bg
WLAN ID Max Clients
1 600
Trap Threshold
Band Select
Load Balancing
Coverage Data
802.11n MCS Rates
AP Config
Cisco AP Identifier.............................. 1
Cisco AP Name.................................... AP2C0B.E9C8.3900
Country code..................................... US - United States
Regulatory Domain allowed by Country............. 802.11bg:-A 802.11a:-AB
AP Country code.................................. US - United States
AP Regulatory Domain............................. -B
Switch Port Number .............................. 1
MAC Address...................................... 2c:0b:e9:c8:39:00
IP Address Configuration......................... DHCP
IP Address....................................... xx.xx.200.xx
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. xx.xx.200.xx
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
DHCP Release Override............................ Disabled
Telnet State..................................... Globally Disabled
Ssh State........................................ Specifically Enabled
Cisco AP Location................................ default location
Cisco AP Floor Label............................. 0
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... FlexConnect
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Rogue Detection ................................. Enabled
AP Vlan Trunking ................................ Enabled
AP Native Vlan ID: .............................. 1
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W Version .................................... 8.3.102.0
Boot Version ................................... 1.1.2.4
Mini IOS Version ................................ 0.0.0.0
Stats Reporting Period .......................... 30
Stats Collection Mode ........................... normal
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-AP1852E-B-K9
AP Image......................................... AP1G4-K9W8-M
IOS Version...................................... 8.3.102.0
Reset Button..................................... Enabled
AP Serial Number................................. KWC205206LP
AP Certificate Type.............................. Manufacture Installed
AP Lag Status ................................... Disable
Native Vlan Inheritance: ........................ Group
FlexConnect Vlan mode :.......................... Enabled
Native ID :..................................... 1
WLAN 1 :........................................ 1 (Wlan-Specific)
FlexConnect VLAN ACL Mappings
FlexConnect Group................................ default-flexgroup
Group VLAN ACL Mappings
Group VLAN Name to Id Mappings
AP-Specific FlexConnect Policy ACLs :
L2Acl Configuration ............................. Not Available
FlexConnect Local-Split ACLs :
WLAN ID PROFILE NAME ACL TYPE
Flexconnect Central-Dhcp Values :
WLAN ID PROFILE NAME Central-Dhcp DNS Override Nat-Pat Type
1 Service West Wall False False False Wlan
Flex AVC visibility Configurations..............
WlanId PROFILE NAME Inherit-level Visibility Flex Avc-profile
1 Service West Wall flexgroup enable none
FlexConnect Backup Auth Radius Servers :
Primary Radius Server........................... Disabled
Secondary Radius Server......................... Disabled
AP User Mode..................................... AUTOMATIC
AP User Name..................................... xxn
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Core Dump Config.............................. Disabled
AP Up Time....................................... 1 days, 06 h 06 m 03 s
AP LWAPP Up Time................................. 0 days, 06 h 04 m 21 s
Join Date and Time............................... Sat Jul 8 11:13:21 2017
Join Taken Time.................................. 0 days, 00 h 00 m 09 s
Attributes for Slot 0
Radio Type................................... RADIO_TYPE_80211n-2.4
Administrative State ........................ ADMIN_ENABLED
Operation State ............................. UP
Mesh Radio Role ............................. ACCESS
Radio Role .................................. Client Serving (Remote)
CellId ...................................... 0
Station Configuration
Configuration ............................. CUSTOMIZED
Number Of WLANs ........................... 1
Medium Occupancy Limit .................... 100
CFP Period ................................ 4
CFP MaxDuration ........................... 60
BSSID ..................................... 2c:0b:e9:c9:4a:80
Operation Rate Set
9000 Kilo Bits........................... SUPPORTED
12000 Kilo Bits.......................... MANDATORY
18000 Kilo Bits.......................... SUPPORTED
24000 Kilo Bits.......................... SUPPORTED
36000 Kilo Bits.......................... SUPPORTED
48000 Kilo Bits.......................... SUPPORTED
54000 Kilo Bits.......................... SUPPORTED
MCS Set
MCS 0.................................... SUPPORTED
MCS 1.................................... SUPPORTED
MCS 2.................................... SUPPORTED
MCS 3.................................... SUPPORTED
MCS 4.................................... SUPPORTED
MCS 5.................................... SUPPORTED
MCS 6.................................... SUPPORTED
MCS 7.................................... SUPPORTED
MCS 8.................................... SUPPORTED
MCS 9.................................... SUPPORTED
MCS 10................................... SUPPORTED
MCS 11................................... SUPPORTED
MCS 12................................... SUPPORTED
MCS 13................................... SUPPORTED
MCS 14................................... SUPPORTED
MCS 15................................... SUPPORTED
MCS 16................................... SUPPORTED
MCS 17................................... SUPPORTED
MCS 18................................... SUPPORTED
MCS 19................................... SUPPORTED
MCS 20................................... SUPPORTED
MCS 21................................... SUPPORTED
MCS 22................................... SUPPORTED
MCS 23................................... SUPPORTED
MCS 24................................... SUPPORTED
MCS 25................................... SUPPORTED
MCS 26................................... SUPPORTED
MCS 27................................... SUPPORTED
MCS 28................................... SUPPORTED
MCS 29................................... SUPPORTED
MCS 30................................... SUPPORTED
MCS 31................................... SUPPORTED
Beacon Period ............................. 100
Fragmentation Threshold ................... 2346
Multi Domain Capability Implemented ....... TRUE
Multi Domain Capability Enabled ........... TRUE
Country String ............................ US
First Chan Num ............................ 0
Number Of Channels ........................ 0
MAC Operation Parameters
Packet Retry Limit ........................ 64
Tx Power
Num Of Supported Power Levels ............. 8
Tx Power Level 1 .......................... 22 dBm
Tx Power Level 2 .......................... 19 dBm
Tx Power Level 3 .......................... 16 dBm
Tx Power Level 4 .......................... 13 dBm
Tx Power Level 5 .......................... 10 dBm
Tx Power Level 6 .......................... 7 dBm
Tx Power Level 7 .......................... 4 dBm
Tx Power Level 8 .......................... 1 dBm
Tx Power Configuration .................... AUTOMATIC
Current Tx Power Level .................... 1
Tx Power Assigned By ...................... DTPC
Phy OFDM parameters
Configuration ............................. AUTOMATIC
Current Channel ........................... 11
Channel Assigned By ....................... DCA
Extension Channel ......................... NONE
Channel Width.............................. 20 Mhz
Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11
TI Threshold .............................. -50
DCA Channel List........................... Global
Legacy Tx Beamforming Configuration ....... AUTOMATIC
Legacy Tx Beamforming ..................... DISABLED
Antenna Type............................... EXTERNAL_ANTENNA
External Antenna Gain (in .5 dBi units).... 8
Diversity.................................. DIVERSITY_ENABLED
802.11n Antennas
A....................................... ENABLED
B....................................... ENABLED
C....................................... ENABLED
D....................................... DISABLED
Performance Profile Parameters
Interference threshold..................... 10 %
Noise threshold............................ -70 dBm
RF utilization threshold................... 80 %
Data-rate threshold........................ 1000000 bps
Client threshold........................... 12 clients
Coverage SNR threshold..................... 12 dB
Coverage exception level................... 25 %
Client minimum exception level............. 3 clients
Rogue Containment Information
Containment Count............................ 0
CleanAir Management Information
CleanAir Capable......................... No
Radio Extended Configurations
Beacon period.............................. 100 milliseconds
Beacon range............................... AUTO
Multicast buffer........................... AUTO
Multicast data-rate........................ AUTO
RX SOP threshold........................... AUTO
CCA threshold.............................. AUTO
Attributes for Slot 1
Radio Type................................... RADIO_TYPE_80211ac-5
Radio Subband................................ RADIO_SUBBAND_ALL
Operation Rate Set
6000 Kilo Bits........................... MANDATORY
24000 Kilo Bits.......................... MANDATORY
MCS Set
802.11ac MCS Set
Nss=1: MCS 0-9 .......................... SUPPORTED
Nss=2: MCS 0-9 .......................... SUPPORTED
Nss=3: MCS 0-9 .......................... SUPPORTED
Nss=4: MCS 0-7 .......................... SUPPORTED
Tx Power
Tx Power Level 1 .......................... 23 dBm
Tx Power Level 2 .......................... 20 dBm
Tx Power Level 3 .......................... 17 dBm
Tx Power Level 4 .......................... 14 dBm
Tx Power Level 5 .......................... 11 dBm
Tx Power Level 6 .......................... 8 dBm
Tx Power Level 7 .......................... 5 dBm
Tx Power Level 8 .......................... 2 dBm
Phy OFDM parameters
Current Channel ........................... 36
Extension Channel ......................... ABOVE, S40 ABOVE
Channel Width.............................. 80 Mhz
Allowed Channel List....................... 36,40,44,48,52,56,60,64,100,
......................................... 104,108,112,116,120,124,128,
......................................... 132,136,140,144,149,153,157,
......................................... 161,165
802.11n Antennas
D....................................... ENABLED
Coverage SNR threshold..................... 16 dB
AP Airewave Director Configuration
AP does not have the 802.11-abgn radio.
AP Name.......................................... AP2C0B.E9C8.3900
Slot ID........................................ 0
Radio Type..................................... RADIO_TYPE_80211b/g
Sub-band Type.................................. All
Noise Information
Noise Profile................................ PASSED
Channel 1.................................... -90 dBm
Channel 2.................................... -91 dBm
Channel 3.................................... -90 dBm
Channel 4.................................... -90 dBm
Channel 5.................................... -90 dBm
Channel 6.................................... -90 dBm
Channel 7.................................... -90 dBm
Channel 8.................................... -90 dBm
Channel 9.................................... -90 dBm
Channel 10................................... -90 dBm
Channel 11................................... -92 dBm
Interference Information
Interference Profile......................... FAILED
Channel 1.................................... -76 dBm @ 15 % busy
Channel 2.................................... -70 dBm @ 6 % busy
Channel 3.................................... -70 dBm @ 16 % busy
Channel 4.................................... -67 dBm @ 2 % busy
Channel 5.................................... -67 dBm @ 23 % busy
Channel 6.................................... -76 dBm @ 18 % busy
Channel 7.................................... -71 dBm @ 7 % busy
Channel 8.................................... -70 dBm @ 16 % busy
Channel 9.................................... -70 dBm @ 9 % busy
Channel 10................................... -76 dBm @ 3 % busy
Channel 11................................... -76 dBm @ 12 % busy
Rogue Histogram (20)
Channel 1.................................... 4
Channel 2.................................... 2
Channel 3.................................... 0
Channel 4.................................... 0
Channel 5.................................... 2
Channel 6.................................... 5
Channel 7.................................... 0
Channel 8.................................... 2
Channel 9.................................... 1
Channel 10................................... 1
Channel 11................................... 31
Load Information
Load Profile................................. PASSED
Receive Utilization.......................... 0 %
Transmit Utilization......................... 0 %
Channel Utilization.......................... 20 %
Attached Clients............................. 1 clients
Coverage Information
Coverage Profile............................. PASSED
Failed Clients............................... 0 clients
Client Signal Strengths
RSSI -100 dbm................................ 0 clients
RSSI -92 dbm................................ 0 clients
RSSI -84 dbm................................ 1 clients
RSSI -76 dbm................................ 0 clients
RSSI -68 dbm................................ 0 clients
RSSI -60 dbm................................ 0 clients
RSSI -52 dbm................................ 0 clients
Client Signal To Noise Ratios
SNR 0 dB.................................. 0 clients
SNR 5 dB.................................. 0 clients
SNR 10 dB.................................. 0 clients
SNR 15 dB.................................. 1 clients
SNR 20 dB.................................. 0 clients
SNR 25 dB.................................. 0 clients
SNR 30 dB.................................. 0 clients
SNR 35 dB.................................. 0 clients
SNR 40 dB.................................. 0 clients
SNR 45 dB.................................. 0 clients
Nearby APs
AP 38:ed:18:cc:e7:20 slot 0.................. -80 dBm on 1 20MHz (10.217.84.19)
AP 38:ed:18:cf:ab:e0 slot 0.................. -76 dBm on 11 20MHz (10.217.84.19)
AP 94:d4:69:f3:90:e0 slot 0.................. -73 dBm on 11 20MHz (10.217.84.19)
Radar Information
Channel Assignment Information
Current Channel Average Energy............... -80 dBm
Previous Channel Average Energy.............. -80 dBm
Channel Change Count......................... 36
Last Channel Change Time..................... Sat Jul 8 17:12:48 2017
Recommended Best Channel..................... 11
RF Parameter Recommendations
Power Level.................................. 1
RTS/CTS Threshold............................ 2347
Fragmentation Threshold...................... 2346
Antenna Pattern.............................. 0
Persistent Interference Devices
Class Type Channel DC (%%) RSSI (dBm) Last Update Time
All third party trademarks are the property of their respective owners.
Slot ID........................................ 1
Radio Type..................................... RADIO_TYPE_80211a
Noise Information
Channel 36................................... -95 dBm
Channel 40................................... -95 dBm
Channel 44................................... -94 dBm
Channel 48................................... -92 dBm
Channel 52................................... -93 dBm
Channel 56................................... -93 dBm
Channel 60................................... -93 dBm
Channel 64................................... -93 dBm
Channel 100.................................. -92 dBm
Channel 104.................................. -92 dBm
Channel 108.................................. -92 dBm
Channel 112.................................. -92 dBm
Channel 116.................................. -91 dBm
Channel 120.................................. -91 dBm
Channel 124.................................. -91 dBm
Channel 128.................................. -91 dBm
Channel 132.................................. -93 dBm
Channel 136.................................. -93 dBm
Channel 140.................................. -93 dBm
Channel 144.................................. -92 dBm
Channel 149.................................. -92 dBm
Channel 153.................................. -93 dBm
Channel 157.................................. -93 dBm
Channel 161.................................. -93 dBm
Channel 165.................................. -94 dBm
Interference Profile......................... PASSED
Channel 36................................... -128 dBm @ 0 % busy
Channel 40................................... -128 dBm @ 0 % busy
Channel 44................................... -128 dBm @ 0 % busy
Channel 48................................... -128 dBm @ 0 % busy
Channel 52................................... -128 dBm @ 0 % busy
Channel 56................................... -128 dBm @ 0 % busy
Channel 60................................... -128 dBm @ 0 % busy
Channel 64................................... -128 dBm @ 0 % busy
Channel 100.................................. -128 dBm @ 0 % busy
Channel 104.................................. -128 dBm @ 0 % busy
Channel 108.................................. -128 dBm @ 0 % busy
Channel 112.................................. -128 dBm @ 0 % busy
Channel 116.................................. -128 dBm @ 0 % busy
Channel 120.................................. -128 dBm @ 0 % busy
Channel 124.................................. -128 dBm @ 0 % busy
Channel 128.................................. -128 dBm @ 0 % busy
Channel 132.................................. -128 dBm @ 0 % busy
Channel 136.................................. -128 dBm @ 0 % busy
Channel 140.................................. -128 dBm @ 0 % busy
Channel 144.................................. -128 dBm @ 0 % busy
Channel 149.................................. -128 dBm @ 0 % busy
Channel 153.................................. -128 dBm @ 0 % busy
Channel 157.................................. -128 dBm @ 0 % busy
Channel 161.................................. -128 dBm @ 0 % busy
Channel 165.................................. -128 dBm @ 0 % busy
Rogue Histogram (20/40/80/160)
Channel 36................................... 0/ 0/ 0/ 0
Channel 40................................... 0/ 0/ 0/ 0
--More or (q)uit current module or <ctrl-z> to abort
Channel 44................................... 0/ 0/ 0/ 0
Channel 48................................... 0/ 0/ 0/ 0
Channel 52................................... 0/ 0/ 0/ 0
Channel 56................................... 0/ 0/ 0/ 0
Channel 60................................... 0/ 0/ 0/ 0
Channel 64................................... 0/ 0/ 0/ 0
Channel 100.................................. 0/ 0/ 0/ 0
Channel 104.................................. 0/ 0/ 0/ 0
Channel 108.................................. 0/ 0/ 0/ 0
Channel 112.................................. 0/ 0/ 0/ 0
Channel 116.................................. 0/ 0/ 0/ 0
Channel 120.................................. 0/ 0/ 0/ 0
Channel 124.................................. 0/ 0/ 0/ 0
Channel 128.................................. 0/ 0/ 0/ 0
Channel 132.................................. 0/ 0/ 0/ 0
Channel 136.................................. 0/ 0/ 0/ 0
Channel 140.................................. 0/ 0/ 0/ 0
Channel 144.................................. 0/ 0/ 0/ 0
Channel 149.................................. 0/ 0/ 0/ 0
Channel 153.................................. 0/ 0/ 0/ 0
Channel 157.................................. 0/ 0/ 0/ 0
Channel 161.................................. 0/ 0/ 0/ 0
Channel 165.................................. 0/ 0/ 0/ 0
Load Information
Channel Utilization.......................... 0 %
Attached Clients............................. 2 clients
RSSI -84 dbm................................ 0 clients
RSSI -68 dbm................................ 1 clients
RSSI -60 dbm................................ 1 clients
SNR 15 dB.................................. 0 clients
SNR 30 dB.................................. 1 clients
SNR 45 dB.................................. 1 clients
Nearby APs
AP 94:d4:69:f3:90:e0 slot 1.................. -88 dBm on 64 20MHz (10.217.84.19)
Radar Information
Current Channel Average Energy............... -71 dBm
Previous Channel Average Energy.............. -71 dBm
Last Channel Change Time..................... Sat Jul 8 17:16:39 2017
Recommended Best Channel..................... 36
802.11a Configuration
802.11a Network.................................. Enabled
11acSupport...................................... Enabled
11nSupport....................................... Enabled
802.11a Low Band........................... Enabled
802.11a Mid Band........................... Enabled
802.11a High Band.......................... Enabled
802.11n MCS Settings:
MCS 0........................................ Supported
MCS 1........................................ Supported
MCS 2........................................ Supported
MCS 3........................................ Supported
MCS 4........................................ Supported
MCS 5........................................ Supported
MCS 6........................................ Supported
MCS 7........................................ Supported
MCS 8........................................ Supported
MCS 9........................................ Supported
MCS 10....................................... Supported
MCS 11....................................... Supported
MCS 12....................................... Supported
MCS 13....................................... Supported
MCS 14....................................... Supported
MCS 15....................................... Supported
MCS 16....................................... Supported
MCS 17....................................... Supported
MCS 18....................................... Supported
MCS 19....................................... Supported
MCS 20....................................... Supported
MCS 21....................................... Supported
MCS 22....................................... Supported
MCS 23....................................... Supported
MCS 24....................................... Supported
MCS 25....................................... Supported
MCS 26....................................... Supported
MCS 27....................................... Supported
MCS 28....................................... Supported
MCS 29....................................... Supported
MCS 30....................................... Supported
MCS 31....................................... Supported
802.11ac MCS Settings:
Nss=1: MCS 0-9 .............................. Supported
Nss=2: MCS 0-9 .............................. Supported
Nss=3: MCS 0-9 .............................. Supported
Nss=4: MCS 0-7 .............................. Supported
802.11n Status:
A-MPDU Tx:
Priority 0............................... Enabled
Priority 1............................... Enabled
Priority 2............................... Enabled
Priority 3............................... Enabled
Priority 4............................... Enabled
Priority 5............................... Enabled
Priority 6............................... Disabled
Priority 7............................... Disabled
Aggregation scheduler.................... Enabled
Frame Burst.............................. Automatic
Realtime Timeout..................... 10
Non Realtime Timeout................. 200
A-MSDU Tx:
A-MSDU Max Subframes ........................ 3
A-MSDU MAX Length ........................... 8k
Rifs Rx ..................................... Enabled
Guard Interval .............................. Any
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC Status..................................... Enabled
Fragmentation Threshold.......................... 2346
RSSI Low Check................................... Disabled
RSSI Threshold................................... -80
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
dfs-peakdetect................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admission Control (CAC) configuration
Voice AC:
Voice AC - Admission control (ACM)............ Disabled
Voice Stream-Size............................. 84000
Voice Max-Streams............................. 2
Voice max RF bandwidth........................ 75
Voice reserved roaming bandwidth.............. 6
Voice CAC Method ............................. Load-Based
Voice tspec inactivity timeout................ Disabled
CAC SIP-Voice configuration
SIP based CAC ................................ Disabled
SIP Codec Type ............................... CODEC_TYPE_G711
SIP call bandwidth ........................... 64
SIP call bandwith sample-size ................ 20
Video AC:
Video AC - Admission control (ACM)............ Disabled
Video max RF bandwidth........................ 0
Video reserved roaming bandwidth.............. 0
Video load-based CAC mode..................... Disabled
Video CAC Method ............................. Static
CAC SIP-Video Configuration
Best-effort AC - Admission control (ACM)...... Disabled
Background AC - Admission control (ACM)....... Disabled
Maximum Number of Clients per AP Radio........... 200
802.11a Advanced Configuration
Member RRM Information
AP Name MAC Address Slot Admin Oper Channel TxPower
AP2C0B.E9C8.3900 2c:0b:e9:c9:4a:80 1 ENABLED UP (36,40,44,48)* *1/8 (23 dBm)
* global assignment
802.11a Airewave Director Configuration
RF Event and Performance Logging
Channel Update Logging......................... Off
Coverage Profile Logging....................... Off
Foreign Profile Logging........................ Off
Load Profile Logging........................... Off
Noise Profile Logging.......................... Off
Performance Profile Logging.................... Off
TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
802.11a Global Interference threshold.......... 10 %
802.11a Global noise threshold................. -70 dBm
802.11a Global RF utilization threshold........ 80 %
802.11a Global throughput threshold............ 1000000 bps
802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
802.11a Monitor Mode........................... enable
802.11a Monitor Mode for Mesh AP Backhaul...... disable
802.11a Monitor Channels....................... Country channels
802.11a RRM Neighbor Discover Type............. Transparent
802.11a RRM Neighbor RSSI Normalization........ Enabled
802.11a AP Coverage Interval................... 90 seconds
802.11a AP Load Interval....................... 60 seconds
802.11a AP Monitor Measurement Interval........ 180 seconds
802.11a AP Neighbor Timeout Factor............. 5
802.11a AP Report Measurement Interval......... 180 seconds
Leader Automatic Transmit Power Assignment
Transmit Power Assignment Mode................. AUTO
Transmit Power Update Interval................. 600 seconds
Transmit Power Threshold....................... -70 dBm
Transmit Power Neighbor Count.................. 3 APs
Min Transmit Power............................. -10 dBm
Max Transmit Power............................. 30 dBm
Update Contribution
Noise........................................ Enable
Interference................................. Enable
Load......................................... Disable
Device Aware................................. Disable
Transmit Power Assignment Leader............... Service Dept Wireless (xx.xx.200.251) (::)
Last Run....................................... 493 seconds ago
Last Run Time.................................. 0 seconds
TPC Mode....................................... Version 1
TPCv2 Target RSSI.............................. -67 dBm
TPCv2 VoWLAN Guide RSSI........................ -67.0 dBm
TPCv2 SOP...................................... -85.0 dBm
TPCv2 Default Client Ant Gain.................. 0.0 dBi
TPCv2 Path Loss Decay Factor................... 3.6
TPCv2 Search Intensity......................... 10 Iterations
AP Name Channel TxPower Allowed Power Levels
AP2C0B.E9C8.3900 *36 *1/8 (23 dBm) [23/20/17/14/11/8/5/2]
Coverage Hole Detection
802.11a Coverage Hole Detection Mode........... Enabled
802.11a Coverage Voice Packet Count............ 100 packets
802.11a Coverage Voice Packet Percentage....... 50%
802.11a Coverage Voice RSSI Threshold.......... -80 dBm
802.11a Coverage Data Packet Count............. 50 packets
802.11a Coverage Data Packet Percentage........ 50%
802.11a Coverage Data RSSI Threshold........... -80 dBm
802.11a Global coverage exception level........ 25 %
802.11a Global client minimum exception lev.... 3 clients
OptimizedRoaming
802.11a OptimizedRoaming Mode.................. Disabled
802.11a OptimizedRoaming Reporting Interval.... 90 seconds
802.11a OptimizedRoaming Rate Threshold........ disabled
802.11a OptimizedRoaming Hysteresis............ 6 dB
OptimizedRoaming Stats
802.11a OptimizedRoaming Disassociations....... 0
802.11a OptimizedRoaming Rejections............ 0
Leader Automatic Channel Assignment
Channel Assignment Mode........................ AUTO
Channel Update Interval........................ 600 seconds
Anchor time (Hour of the day).................. 0
Update Contribution
CleanAir Event-driven RRM option............... Disabled
Channel Assignment Leader...................... Service Dept Wireless (xx.xx.200.251) (::)
DCA Sensitivity Level.......................... MEDIUM (15 dB)
DCA 802.11n/ac Channel Width................... BEST
DBS Max Channel Width.......................... 80 MHz
DCA Minimum Energy Limit....................... -95 dBm
Channel Energy Levels
Minimum...................................... -71 dBm
Average...................................... -71 dBm
Maximum...................................... -71 dBm
Channel Dwell Times
Minimum...................................... 0 days, 00 h 08 m 11 s
Average...................................... 0 days, 00 h 08 m 11 s
Maximum...................................... 0 days, 00 h 08 m 11 s
802.11a 5 GHz Auto-RF Channel List
Allowed Channel List......................... 36,40,44,48,52,56,60,64,100,
161
Unused Channel List.......................... 165
802.11a 4.9 GHz Auto-RF Channel List
Unused Channel List.......................... 1,2,3,4,5,6,7,8,9,10,11,12,
13,14,15,16,17,18,19,20,21,
22,23,24,25,26
DCA Outdoor AP option.......................... Disabled
802.11a Radio RF Grouping
RF Group Name.................................. default
RF Protocol Version(MIN)....................... 101(30)
RF Packet Header Version....................... 2
Group Role(Mode)............................... LEADER(AUTO)
Group State.................................... Idle
Group Update Interval.......................... 600 seconds
Group Leader................................... Service Dept Wireless (xx.xx.200.251) (::800:0:b00:0:100:0)
Group Member
Maximum/Current number of Group Member......... 20/1
Maximum/Current number of AP................... 500/1
Mobility Agents RF membership information
No of connected members : 1
802.11a MA RF member : (0.0.0.0)
802.11a CleanAir Configuration
Clean Air Solution............................... Enabled
Air Quality Settings:
Air Quality Reporting........................ Enabled
Air Quality Reporting Period (min)........... 15
Air Quality Alarms........................... Enabled
Air Quality Alarm Threshold................ 35
Unclassified Interference.................. Disabled
Unclassified Severity Threshold............ 20
Interference Device Settings:
Interference Device Reporting................ Enabled
Interference Device Types:
TDD Transmitter.......................... Enabled
Jammer................................... Enabled
Continuous Transmitter................... Enabled
DECT-like Phone.......................... Enabled
Video Camera............................. Enabled
WiFi Inverted............................ Enabled
WiFi Invalid Channel..................... Enabled
SuperAG.................................. Enabled
Canopy................................... Enabled
WiMax Mobile............................. Enabled
WiMax Fixed.............................. Enabled
Interference Device Alarms................... Enabled
Interference Device Types Triggering Alarms:
TDD Transmitter.......................... Disabled
Continuous Transmitter................... Disabled
DECT-like Phone.......................... Disabled
Video Camera............................. Disabled
SuperAG.................................. Disabled
Canopy................................... Disabled
WiMax Mobile............................. Disabled
WiMax Fixed.............................. Disabled
Additional Clean Air Settings:
CleanAir ED-RRM State........................ Disabled
CleanAir ED-RRM Sensitivity.................. Medium
CleanAir ED-RRM Custom Threshold............. 50
CleanAir Rogue Contribution.................. Disabled
CleanAir Rogue Duty-Cycle Threshold.......... 80
CleanAir Persistent Devices state............ Disabled
CleanAir Persistent Device Propagation....... Enabled
802.11a CleanAir AirQuality Summary
AQ = Air Quality
DFS = Dynamic Frequency Selection
AP Name Channel Avg AQ Min AQ Interferers DFS
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11n Status:
A-MPDU Tx:
A-MSDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
Voice CAC Method.............................. Load-Based
SIP call bandwidth: .......................... 64
SIP call bandwidth sample-size ............... 20
CAC SIP-Video configuration
Maximum Number of Clients per AP................. 200
802.11b Advanced Configuration
AP Name MAC Address Admin Oper Channel TxPower
AP2C0B.E9C8.3900 2c:0b:e9:c9:4a:80 ENABLED UP 11* *1/8 (22 dBm)
* global assignment
802.11b Airewave Director Configuration
Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
802.11b Global Interference threshold.......... 10 %
802.11b Global noise threshold................. -70 dBm
802.11b Global RF utilization threshold........ 80 %
802.11b Global throughput threshold............ 1000000 bps
802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
802.11b Monitor Mode........................... enable
802.11b Monitor Channels....................... Country channels
802.11b RRM Neighbor Discovery Type............ Transparent
802.11b RRM Neighbor RSSI Normalization........ Enabled
802.11b AP Coverage Interval................... 90 seconds
802.11b AP Load Interval....................... 60 seconds
802.11b AP Monitor Measurement Interval........ 180 seconds
802.11b AP Neighbor Timeout Factor............. 5
802.11b AP Report Measurement Interval......... 180 seconds
Update Contribution
Last Run....................................... 331 seconds ago
AP2C0B.E9C8.3900 *11 *1/8 (22 dBm) [22/19/16/13/10/7/4/1]
802.11b Coverage Hole Detection Mode........... Enabled
802.11b Coverage Voice Packet Count............ 100 packets
802.11b Coverage Voice Packet Percentage....... 50%
802.11b Coverage Voice RSSI Threshold.......... -80 dBm
802.11b Coverage Data Packet Count............. 50 packets
802.11b Coverage Data Packet Percentage........ 50%
802.11b Coverage Data RSSI Threshold........... -80 dBm
802.11b Global coverage exception level........ 25 %
802.11b Global client minimum exception lev.... 3 clients
OptimizedRoaming
802.11b OptimizedRoaming Mode.................. Disabled
802.11b OptimizedRoaming Reporting Interval.... 90 seconds
802.11b OptimizedRoaming Rate Threshold........ disabled
802.11b OptimizedRoaming Hysteresis............ 6 dB
802.11b OptimizedRoaming Disassociations....... 0
802.11b OptimizedRoaming Rejections............ 0
Update Contribution
DCA Sensitivity Level: ...................... MEDIUM (10 dB)
Minimum...................................... -77 dBm
Average...................................... -77 dBm
Maximum...................................... -77 dBm
Channel Dwell Times
Minimum...................................... 0 days, 00 h 05 m 28 s
Average...................................... 0 days, 00 h 05 m 28 s
Maximum...................................... 0 days, 00 h 05 m 28 s
802.11b Auto-RF Allowed Channel List........... 1,6,11
Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10
802.11b Radio RF Grouping
Group Leader................................... Service Dept Wireless (xx.xx.200.251) (::50.249.20.10)
Group Member
802.11b MA RF member : (0.0.0.0)
802.11b CleanAir Configuration
Bluetooth Link........................... Enabled
Microwave Oven........................... Enabled
802.11 FH................................ Enabled
Bluetooth Discovery...................... Enabled
802.15.4................................. Enabled
Microsoft Device......................... Enabled
BLE Beacon............................... Enabled
Bluetooth Link........................... Disabled
Microwave Oven........................... Disabled
802.11 FH................................ Disabled
Bluetooth Discovery...................... Disabled
802.15.4................................. Disabled
Microsoft Device......................... Disabled
BLE Beacon............................... Disabled
CleanAir ED-RRM Sensitivity.................. Low
AQ = Air Quality
RF Density Optimization Configurations
FRA State........................................ Disabled
FRA Sensitivity.................................. low (100)
FAR Interval..................................... 1 Hour(s)
Last Run....................................... 1828 seconds ago
AP Name MAC Address Slot Current Band COF % Suggested Mode
COF : Coverage Overlap Factor
RF Client Steering Configurations
Client Steering Configuration Information
Macro to micro transition threshold............ 201 dBm
micro to Macro transition threshold............ 191 dBm
micro-Macro transition minimum client count.... 3
micro-Macro transition client balancing win.... 3
Probe suppression mode......................... disabled
Probe suppression validity window.............. 100 s
Probe suppression aggregate window............. 200 ms
Probe suppression transition aggressiveness.... 3
Probe suppression hysteresis................... 250 dBm
Mobility Configuration
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... default
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0xac34
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 1
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address IP Address Group Name Multicast IP Status
2c:0b:e9:c8:39:00 xx.xx.200.xx default 0.0.0.0 Up
Mobility Hash Configuration
IP Address Hash Key
Self Signed Certificate details
SSC Hash validation.............................. Enabled.
SSC device certificate not present.
Mobility Foreign Map Configuration
WLAN ID Foreign Mac Address Interface
Probe request filtering.......................... Enabled
Probes fwd to controller per client per radio.... 2
Probe request rate-limiting interval............. 500 msec
Aggregate Probe request interval................. 500 msec
Increased backoff parameters for probe respon.... Disabled
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
EAP-Broadcast Key Interval....................... 3600
dot11-padding.................................... Disabled
padding-size..................................... 0
Advanced Hotspot Commands
ANQP 4-way state................................. Disabled
GARP Broadcast state: ........................... Enabled
GAS request rate limit .......................... Disabled
ANQP comeback delay in TUs(TU=1024usec).......... 0 TUs (=0mSec)
Location Configuration
RFID Tag data Collection......................... Enabled
RFID timeout.................................... 1200 seconds
RFID mobility....................................
Interface Configuration
Interface Name................................... management
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... xx.xx.200.254
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Link Local IPv6 Address.......................... fe80::2e0b:e9ff:fec8:3900/64
STATE ........................................... NONE
Primary IPv6 Address............................. ::/128
Primary IPv6 Gateway............................. ::
Primary IPv6 Gateway Mac Address................. 00:00:00:00:00:00
VLAN............................................. untagged
Quarantine-vlan.................................. 0
Physical Port.................................... 1
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. Unconfigured
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
DHCP Option 82 bridge mode insertion............. Disabled
IPv4 ACL......................................... Unconfigured
IPv6 ACL......................................... Unconfigured
URL ACL.......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Interface Name................................... virtual
IP Address....................................... 192.0.2.1
Virtual DNS Host Name............................ Disabled
AP Manager....................................... No
Interface Group Configuration
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... Service West Wall
Network Name (SSID).............................. Service West Wall
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Client Profiling Status
Radius Profiling ............................ Disabled
DHCP ....................................... Disabled
HTTP ....................................... Disabled
Local Profiling ............................. Enabled
DHCP ....................................... Enabled
HTTP ....................................... Enabled
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum Clients Allowed.......................... Unlimited
Maximum number of Clients per AP Radio........... 200
ATF Policy....................................... 0
Number of Active Clients......................... 2
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ Global Servers
Accounting.................................... Global Servers
Interim Update............................. Enabled
Interim Update Interval.................... 0
Framed IPv6 Acct AVP ...................... Prefix
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
802.11 Authentication:........................ Open System
FT Support.................................... Adaptive
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
OSEN IE.................................... Disabled
Auth Key Management
802.1x.................................. Disabled
PSK..................................... Enabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
PMF-1X(802.11w)......................... Disabled
PMF-PSK(802.11w)........................ Disabled
OSEN-1X................................. Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Enabled
GTK Randomization.......................... Disabled
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web Authentication Timeout.................... 300
Web-Passthrough............................... Disabled
Mac-auth-server............................... 0.0.0.0
Web-portal-server............................. 0.0.0.0
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Enabled
FlexConnect Central Association............... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
flexconnect PPPoE pass-through................ Disabled
flexconnect local-switching IP-source-guar.... Disabled
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
Tkip MIC Countermeasure Hold-down Timer....... 60
Eap-params.................................... Disabled
AVC Visibilty.................................... Enabled
AVC Profile Name................................. None
Flex Avc Profile Name............................ None
Flow Monitor Name................................ None
Split Tunnel Configuration
Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Enabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Enabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Enabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Broadcast Tagging................................ Disabled
Mobility Anchor List
WLAN ID IP Address Status Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority Policy Name
QoS Fastlane Status.............................. Disable
Policy Configuration
L2ACL Configuration
URL ACL Configuration
ACL Configuration
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Accounting Call Station Id Type.................. IP Address
Auth Call Station Id Type........................ AP's Radio MAC Address:SSID
Extended Source Ports Support.................... Enabled
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
Test Mode.................................... Passive
Probe User Name.............................. cisco-probe
Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
RADIUS Authentication Framed-MTU................. 1300 Bytes
Authentication Servers
Idx Type Server Address Port State Tout MgmtTout RFC3576 IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr/Region
Accounting Servers
TACACS Configuration
Fallback Test:
Interval (in seconds)........................ 0
Idx Server Address Port State Tout MgmtTout
Authorization Servers
Accounting Servers
LDAP Configuration
Local EAP Configuration
User credentials database search order:
Primary ..................................... Local DB
Timer:
Active timeout .............................. 300
Configured EAP profiles:
EAP Method configuration:
EAP-FAST:
Server key ................................ <hidden>
TTL for the PAC ........................... 10
Anonymous provision allowed ............... Yes
Authority ID .............................. 436973636f0000000000000000000000
Authority Information ..................... Cisco A-ID
Dns Configuration
Radius port......................................
Radius secret.................................... 0000
Dns url..........................................
Dns timeout......................................
Dns Serverip.....................................
Dns state........................................ Disable
Dns Auth Retransmit Timeout...................... 2
Dns Acct Retransmit Timeout...................... 2
Dns Auth Mgmt-Retransmit Timeout................. 2
Dns Network Auth................................. Enable
Dns Mgmt Auth.................................... Enable
Dns Network Acct................................. Enable
Dns RFC 3576 Auth................................ Disable
Tacacs port......................................
Tacacs secret.................................... 2
Fallback Radio Shut configuration:
Fallback Radio Shut: Disabled
Arp-caching: Disabled
Subnet Broadcast Drop: Disabled
FlexConnect Group Summary
FlexConnect Group Summary: Count: 1
Group Name # Aps
default-flexgroup 1
FlexConnect Group Detail
FlexConnect Group Name - default-flexgroup
Number of AP's in Group: 1
AP Ethernet MAC Name Status Mode Type Conflict with PnP
2c:0b:e9:c8:39:00 AP2C0B.E9C8.3900 Joined Flexconnect Manual No
Efficient AP Image Upgrade ..... Enabled
Max Retry Count for Slaves ..... 44
Number Of Masters .............. 0
Master-AP-Mac Master-AP-Name Model Manual
Group Radius Servers Settings:
Primary Unconfigured Unconfigured
Secondary Unconfigured Unconfigured
Group Radius/Local Auth Parameters :
Radius Retransmit Count......................... 3 (default)
Active Radius Timeout........................... 5 (default)
Group Radius AP Settings:
AP RADIUS server............ Disabled
EAP-FAST Auth............... Disabled
LEAP Auth................... Disabled
EAP-TLS Auth................ Disabled
EAP-TLS CERT Download....... Disabled
PEAP Auth................... Disabled
Server Key Auto Generated... No
Server Key.................. <hidden>
Authority ID................ 436973636f0000000000000000000000
Authority Info.............. Cisco A_ID
PAC Timeout................. 0
HTTP-Proxy Ip Address....... 0.0.0.0
HTTP-Proxy Port............. 0
Multicast on Overridden interface config: Disabled
DHCP Broadcast Overridden interface config: Disabled
Number of User's in Group: 0
FlexConnect Vlan-name to Id Template name: none
Flex-Group Wlan Avc Mappings
WLAN ID Visibility Avc-profile
1 enable
Group-Specific Vlan Config:
Vlan Mode.................... Enabled
Native Vlan.................. 1
Override AP Config........... Enabled
Group-Specific FlexConnect Wlan-Vlan Mapping:
WLAN ID Vlan ID
WLAN ID SSID Central-Dhcp Dns-Override Nat-Pat
FlexConnect Vlan name Summary
Vlan-Name Id Status
FlexConnect Vlan Name Detail
Route Info
Number of Routes................................. 0
Destination Network Netmask Gateway
Peer Route Info
Number of Routes................................. 1077817812
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................ 75
Silver queue length.............................. 50
Bronze queue length.............................. 25
Qos Profile Info
Description...................................... For Voice Applications
Maximum Priority................................. voice
Unicast Default Priority......................... voice
Multicast Default Priority....................... besteffort
protocol......................................... none
Description...................................... For Video Applications
Maximum Priority................................. video
Unicast Default Priority......................... video
Multicast Default Priority....................... video
protocol......................................... dot1p
dot1p............................................ 4
Description...................................... For Best Effort
Maximum Priority................................. besteffort
Unicast Default Priority......................... besteffort
dot1p............................................ 0
Description...................................... For Background
Maximum Priority................................. background
Unicast Default Priority......................... background
Multicast Default Priority....................... background
dot1p............................................ 1
Qos Map Info
Status: Disabled
UP-TO-DSCP Map:
Up Default DSCP Start DSCP End DSCP
0 255 255 255
1 255 255 255
2 255 255 255
3 255 255 255
4 255 255 255
5 255 255 255
6 255 255 255
7 255 255 255
Exception List:
DSCP UP
Trust DSCP Upstream: Disabled
Mac Filter Info
Authorization List
Authorize MIC APs against Auth-list or AAA ...... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
AP with Manufacturing Installed Certificate.... yes
AP with Self-Signed Certificate................ no
AP with Locally Significant Certificate........ no
Load Balancing Info
Aggressive Load Balancing........................ per WLAN enabling
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
Aggressive Load Balancing Uplink Threshold....... 50
Statistics (client-count based)
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
Statistics (uplink-usage based)
Mobility Express DHCP Server
Scope: day0-mgmt
Enabled.......................................... Yes
Lease Time....................................... 86400 (1 day )
Pool Start....................................... xx.xx.200.100
Pool End......................................... xx.xx.200.199
Network.......................................... xx.xx.200.0
Netmask.......................................... 255.255.255.0
DHCP Server...................................... xx.xx.200.199
Vlan............................................. 0
Native........................................... Yes
Default Routers.................................. xx.xx.200.254 0.0.0.0 0.0.0.0
DNS Domain.......................................
DNS.............................................. 65.106.1.196 65.106.7.196 0.0.0.0
DHCP Opt-82 RID Format: <AP radio MAC address>
DHCP Opt-82 Format: binary
DHCP Proxy Behaviour: disabled
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
cdp version v2
Country Channels Configuration
Configured Country............................. US - United States
KEY: * = Channel is legal in this country and may be configured manually.
A = Channel is the Auto-RF default in this country.
. = Channel is not legal in this country.
C = Channel has been configured for use by Auto-RF.
x = Channel is available to be configured for use by Auto-RF.
(-,-) = (indoor, outdoor) regulatory domain allowed by this country.
802.11bg :
Channels : 1 1 1 1 1
: 1 2 3 4 5 6 7 8 9 0 1 2 3 4
US (-A ,-AB ): A * * * * A * * * * A . . .
802.11a : 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
Channels : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 4 5 5 6 6 6 7
: 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 4 9 3 7 1 5 9 3
US (-AB ,-AB ): . A . A . A . A A A A A A A A A A A A A A A A A A A A A * . .
4.9GHz 802.11a :
Channels : 1 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2
: 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
US (-AB ,-AB ): * * * * * * * * * * * * * * * * * * * A * * * * * A
WPS Configuration Summary
Auto-Immune
Auto-Immune.................................... Disabled
Auto-Immune by aWIPS Prevention................ Disabled
Client Exclusion Policy
Excessive 802.11-association failures.......... Enabled
Excessive 802.11-authentication failures....... Enabled
Excessive 802.1x-authentication................ Enabled
IP-theft....................................... Enabled
Excessive Web authentication failure........... Enabled
Maximum 802.1x-AAA failure attempts............ 3
Signature Policy
Signature Processing........................... Enabled
Management Frame Protection
Global Infrastructure MFP state................ DISABLED (*all infrastructure settings are overridden)
AP Impersonation detection..................... Disabled
Controller Time Source Valid................... False
WLAN Client
WLAN ID WLAN Name Status Protection
1 Service West Wall Enabled Optional
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... None
Custom Message................................... None
Custom Redirect URL.............................. None
Web Authentication Type.......................... Internal Default
Logout-popup..................................... Enabled
External Web Authentication URL.................. None
Configuration Per Profile:
Core dump Configuration
Core Dump upload is disabled
Core Dump file on flash:
Rogue AP Configuration
Rogue Detection Security Level................... high
Rogue Pending Time............................... 60 secs
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
Rogue Detection Report Interval.................. 30
Rogue Detection Min Rssi......................... -80
Rogue Detection Transient Interval............... 300
Rogue Detection Client Num Threshold............. 0
Validate rogue AP against AAA.................... Disabled
Rogue AP AAA validation interval................. 0 secs
Total Rogues(AP+Ad-hoc) supported................ 200
Total Rogues classified.......................... 21
MAC Address Class State #Det #Rogue #Highest RSSI #RSSI #Channel #Second Highest #RSSI #Channel
Aps Clients det-Ap RSSI Det-Ap
00:18:b9:b3:d0:f0 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -128 9
00:1d:45:af:0b:80 Unclassified Alert 1 3 2c:0b:e9:c9:4a:80 -64 5
00:1d:45:cd:59:d0 Unclassified Alert 1 2 2c:0b:e9:c9:4a:80 -76 1
00:3a:9a:b1:23:30 Unclassified Alert 1 1 2c:0b:e9:c9:4a:80 -77 3
24:79:2a:25:1e:58 Unclassified Alert 1 1 2c:0b:e9:c9:4a:80 -72 11
40:e2:30:0f:cc:91 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -60 6
54:2a:a2:5a:67:b6 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -70 11
54:2a:a2:6c:19:e7 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -71 9
54:2a:a2:a0:e3:91 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -64 8
64:ae:0c:eb:6b:50 Unclassified Alert 1 1 2c:0b:e9:c9:4a:80 -72 2
6c:aa:b3:17:c4:ca Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -79 11
6c:aa:b3:d7:c4:ca Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -78 11
6c:aa:b3:d7:c4:cb Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -79 11
a0:8c:fd:b8:22:91 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -63 5
b4:75:0e:cf:b2:a0 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -75 1
e0:91:f5:e6:0f:c8 Unclassified Alert 1 3 2c:0b:e9:c9:4a:80 -73 11
e2:55:7d:4a:ab:a0 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -76 6
e2:55:7d:4a:ab:a1 Unclassified Alert 1 2 2c:0b:e9:c9:4a:80 -67 6
e2:55:7d:4a:ab:af Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -76 6
e2:55:7d:62:39:71 Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -76 11
f4:30:b9:b2:cc:5a Unclassified Alert 1 0 2c:0b:e9:c9:4a:80 -70 6
Rogue AP RLDP Configuration
Rogue Location Discovery Protocol................ Enabled & Monitor-Only
RLDP Schedule Config............................. Disabled
RLDP Scheduling Operation........................ Disabled
RLDP Retry....................................... 1
RLDP Start Time RLDP End Time Day
Rogue Auto Contain Configuration
Containment Level................................ 0(auto)
monitor_ap_only.................................. false
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
Auto-Contain Ad-Hoc Networks..................... Disabled
Total Rogues(Ad-Hoc+AP) supported ............... 200
Total Ad-Hoc entries ............................ 0
Client MAC Address Adhoc BSSID State # APs Last Heard
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
Validate rogue clients against MSE............... Enabled
Total Rogue Clients supported.................... 166
Total Rogue Clients present...................... 13
MAC Address State # APs Last Heard
1c:65:9d:1a:21:17 Alert 1 Sat Jul 8 17:28:50 2017
1c:65:9d:c4:6a:a6 Alert 1 Sat Jul 8 17:40:50 2017
20:10:7a:85:f7:cb Alert 1 Sat Jul 8 17:39:20 2017
30:3a:64:e9:d1:44 Alert 1 Sat Jul 8 17:27:50 2017
40:f0:2f:76:1b:1e Alert 1 Sat Jul 8 17:39:20 2017
48:51:b7:30:9d:82 Alert 1 Sat Jul 8 17:39:20 2017
78:7e:61:56:b3:69 Alert 1 Sat Jul 8 17:36:20 2017
80:1f:02:05:6f:86 Alert 1 Sat Jul 8 17:30:20 2017
84:a1:34:cc:6f:65 Alert 1 Sat Jul 8 17:38:50 2017
8c:f5:a3:96:b8:87 Alert 1 Sat Jul 8 17:33:50 2017
a0:cc:2b:8e:c5:2c Alert 1 Sat Jul 8 17:38:20 2017
ac:37:43:dc:a4:61 Alert 1 Sat Jul 8 17:39:20 2017
bc:a9:20:6f:f9:6d Alert 1 Sat Jul 8 17:28:50 2017
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority Rule Name Rule state Class Type Notify State Match Hit Count
Media-Stream Configuration
Multicast-direct State........................... disable
Allowed WLANs....................................
Stream Name Start IP End IP Operation Status
URL..............................................
E-mail...........................................
Phone............................................
Note.............................................
State............................................ disable
2.4G Band Media-Stream Configuration
Multicast-direct................................. Enabled
Best Effort...................................... Disabled
Video Re-Direct.................................. Enabled
Max Allowed Streams Per Radio.................... Auto
Max Allowed Streams Per Client................... Auto
Max Video Bandwidth.............................. 0
Max Voice Bandwidth.............................. 75
Max Media Bandwidth.............................. 85
Min PHY Rate..................................... 6000
Max Retry Percentage............................. 80
5G Band Media-Stream Configuration
Number of Clients................................ 0
Client Mac Stream Name Stream Type Radio WLAN QoS Status
WLC Voice Call Statistics
WLC Voice Call Statistics for 802.11b Radio
WMM TSPEC CAC Call Stats
Total num of Calls in progress................. 0
Num of Roam Calls in progress.................. 0
Total Num of Calls Admitted.................... 0
Total Num of Roam Calls Admitted............... 0
Total Num of exp bw requests received.......... 0
Total Num of exp bw requests Admitted.......... 0
Total Num of Calls Rejected.................... 0
Total Num of Roam Calls Rejected............... 0
Num of Calls Rejected due to insufficent bw.... 0
Num of Calls Rejected due to invalid params.... 0
Num of Calls Rejected due to PHY rate.......... 0
Num of Calls Rejected due to QoS policy........ 0
SIP CAC Call Stats
Total Num of Calls in progress................. 0
Total Num of Preferred Calls Received.......... 0
WLC IPv6 Summary
Global Config............................... Disabled
Reachable-lifetime value.................... 0
Stale-lifetime value........................ 0
Down-lifetime value......................... 0
RA Throttling............................... Disabled
RA Throttling allow at-least................ 0
RA Throttling allow at-most................. 0
RA Throttling max-through................... 0
RA Throttling throttle-period............... 0
RA Throttling interval-option............... 0
NS Mulitcast CacheMiss Forwarding........... Disabled
NA Mulitcast Forwarding..................... Disabled
IPv6 Capwap UDP Lite........................ Un-configured
mDNS Service Summary
Number of Services.............................. 0
Mobility learning status ........................ Enabled
mDNS service-group Summary
Access Policy Status............................ Disabled
Total number of mDNS Policies.................... 0
Number of Admin configured Policies.............. 0
mDNS profile detailed
mDNS AP Summary
Number of mDNS APs............................. 0
Sorry @rmiller. This command is usefull as well, but the command I should ask is show version.
 My bad.
 My bad.
Lol. There is no show version" on the 1852e. I hate this frigging thing -- it has its own command set.
(Cisco Controller) >show mobility summary
Here's the whole command set:
(Cisco Controller) >show ?
802.11a Display 802.11a configuration.
802.11b Display 802.11b configuration.
802.11h Display 802.11h configuration.
aaa Displays AAA related information
acl Display system Access Control Lists.
advanced Display Advanced configuration and statistics.
ap Display AP Configuration.
arp Display ARP cache.
assisted-roaming Display Assisted Roaming and 802.11k configuration.
atf Display ATF configuration/statistics
auth-list Display AP authorization list.
avc Display AVC Configuration/Statistics.
band-select Display Aggressive Load Balancing configuration.
boot Displays the default boot image.
buffers Display pmalloc buffer utilization.
cac Show Call-Admission-Control details
call-control Display Call-control information
cdp Display CDP information
certificate Display SSL Certificate Configuration.
client Displays active clients.
cloud-services Displays the Cloud Server Configuration
--More-- or (q)uit
coredump Displays Core Dump Summary
country Display the configured countries.
cpu Display current CPU usage information.
custom-web Display Web Authentication customization information.
database Show local database configuration.
debug Display enabled debugs.
dhcp Display the dhcp server configuration.
dtls Display the DTLS server status.
emweb Displays emweb related information.
eventlog Display event log entries.
exclusionlist Display exclusion-list.
flexconnect Display controller flexconnect information.
flow Display flow Configuration.
fragDetails Display CAPWAP Control Fragment Reassembly Counters.
guest-lan Display Guest LAN Configuration.
icons Show icon filename and its information.
interface Display system interfaces.
invalid-config Display Invalid Config.
inventory Display vital product data.
ipv6 Display IPv6 information.
ldap Displays LDAP information.
linktest Shows the configured frame size and number of frames for linktest.
load-balancing Display Aggressive Load Balancing configuration.
--More-- or (q)uit
local-auth Display Local EAP Authentication information.
location Display Location based System information
logging Display logger parameters and buffer contents.
loginsession Display login session info.
macfilter Display MAC filtering configuration.
mdns Displays mDNS information
media-stream Display Multicast-direct Configuration State
memory Display system memory usage statistics.
mesh Show mesh configuration.
mgmtuser Display local management user accounts.
mobility Display Mobility Management Configuration.
msglog Display message log entries.
netuser Display local network user accounts.
network Display configuration for inband connectivity.
nmheartbeat Displays Network Manager Heart Beat Summary
nmsp Displays data for NMSP protocol between controller and Location Server.
ntp-keys Display the system time.
oeap-acl Display OEAP Access Control Lists.
pmk-cache Display information about the PMK cache.
policy Displays detailed information of a policy
port Display port mode and settings; display port status.
process Display CPU and memory usage per process.
profiling Display local device classification information.
--More-- or (q)uit
qos Display qos information (queue length)
queue-info Display system Message Queue Information.
radius Displays RADIUS information.
reset Display scheduled system reset parameters.
rf-profile Configures RF Profile parameters.
rfid Shows the RFID tag tracking information
rogue Displays Rogue AP and Client information.
route Display configured route
rules Display active internal firewall rules.
run-config Display running configuration.
running-config Display running configuration.
serial Display EIA-232 parameters and serial port inactivity timeout.
service Display service information.
sessions Display cli session configuration information.
snmpcommunity Display SNMP community entries.
snmpengineID Display SNMP v3 EngineId.
snmptrap Display SNMP trap port number and trap receiver entries.
snmpv3user Display SNMP v3 user entries.
snmpversion Display SNMP v1/v2/v3c status(enabled or disabled).
split-tunnel Show the configured split tunnel network lists.
stats Display port and switch statistics.
switchconfig Display parameters that apply to the switch.
sysinfo Display system information including system up time.
--More-- or (q)uit
syslog Displays the state of system syslog.
system Display system information
tacacs Displays TACACS+ information.
tech-support Display system resource information.
time Display the system time.
trapflags Display the value of trap flags that apply to the switch.
traplog Display snmp trap records.
trapstats Display snmp trap statistics.
udi Display UDI for the controller
wgb Displays active work-group bridges (WGB).
wlan Display WLAN Configuration.
wps Displays WPS Configuration.
Then this takes me to the conclusion that you have a capwap AP and not an Mobility Express AP.
 You can convert it but it is necessary to have mobility express image.
See what Cisco Says:
"Access Point with CAPWAP image will not show the AP Image Type and AP Configuration parameters in the AP#show version output.
cisco AIR-AP1852E-UXK9 ARMv7 Processor rev 0 (v71) with 997184/525160K bytes of memory.
Processor board ID RFDP2BCR021
AP Running Image : 8.2.100.0
Primary Boot Image : 8.2.100.0
Backup Boot Image : 8.1.106.33
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
-If I helped you somehow, please, rate it as useful.-
