Cannot configure our Aironet 1200 Access Point, please help!
lewispumps
We have an Aironet 1200 Series Access Point that I am trying to set up for our shop employees. When I go into IPSU and enter the MAC address that is listed below the unit and click on get IP Address, it says device does not answer.
Then, when I click on set parameters and try to manually assign an IP address it says device does not answer for SET IP. I then noticed that I can change the last letter in the MAC address and get the same outcome. This got me to thinking that the MAC address might be wrong. I have tried this unit at several stations thinking it could be a bad wire, but that is not the case.
If someone could please help me I would greatly appreciate it...
kmarrero
Level 4
Level 4
Try uninstalling and reinstalling the IPSU tool. If that does not help then you should be able use a serial cable and console into the access point. Here is a link showing the steps to do so. http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/ap120scg/bkscgch2.htm
