Cannot Enable Radio on AIR-LAP1041N-E-K9 autonomous
Hi, i have swapped the "flash:/c1140-k9w7-mx.124-25d.JA2" with AIR-LAP1041N-E-K9 ap to make it autonomous and configured the interface BVI1 with ip address 192.168.0.10 255.255.255.0. I can access the GUI too.. but i cannot turn on the dot11 radio. this is what i get from CLI
ap(config)#interface dot11Radio 0
% Invalid input detected at '^' marker.
ap(config)#interface dot11Radio 1
please find the below image.. its different and lacks many items from the manual
please help me with the situation is there somthing wrong with the AP?
Prasad
Everyone's tags (3)
please find the screen shot i wanted to attach. sorry it didnt showed up with my post earlier
Hall of Fame Super Gold
Console into your AP and post the following output:
1.  sh version;
2.  sh inventory;
3.  sh log
Hi Leo,
these are the results,
ap#sh ver
Cisco IOS Software, C1040 Software (C1140-K9W7-M), Version 12.4(25d)JA2, RELEASE        SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 12-Sep-12 00:44 by prod_rel_team
ROM: Bootstrap program is C1040 boot loader
BOOTLDR: C1040 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE        (fc3)
ap uptime is 1 minute
System image file is "flash:/c1140-k9w7-mx.124-25d.JA2/c1140-k9w7-mx.124-25d.JA2        "
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1041N-E-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1516Z17D
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from power-on
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:00:F1:08:7A:CC
Part Number                          : 73-13215-01
PCA Assembly Number                  : 800-34273-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC1507704K
Top Assembly Part Number             : 800-34284-01
Top Assembly Serial Number           : FCZ1516Z17D
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1041N-E-K9
Configuration register is 0xF
ap#
ap#sh inven
ap#sh inventory
NAME: "AP1040", DESCR: "Cisco Aironet 1040 Series (IEEE 802.11n) Access Point"
PID: AIR-LAP1041N-E-K9 , VID: V01, SN: FCZ1516Z17D
ap#sh lo
ap#sh log
Syslog logging: enabled (1 messages dropped, 2 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 16 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 16 messages logged, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 17 message lines logged
Log Buffer (1048576 bytes):
*Mar  1 00:00:09.445: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.463: *** CRASH_LOG = YES
*Mar  1 00:00:09.763: Port 1 is not present
*Mar  1 00:00:10.475: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0Base Ethernet MAC address: 64:00:F1:08:7A:CC
*Mar  1 00:00:51.260: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:52.341: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:53.564: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:53.608: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:53.608: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:00:53.627: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:00:53.629: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:54.510: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:54.627: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:01:05.493: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:01:06.493: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
ap#
Console into the AP and reboot the AP.
Post the entire bootup process.
now suddenly the dot11Radio 0 started to work and i could assign an SSID to it too but dot11Radio 1 cannot be started,.. it returns with
ap(config)#
ap(config)#int dot11Radio 1
the reload prompt is as follows.........
ap#reload
Proceed with reload? [confirm]
*Mar  1 00:16:03.710: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
using  eeprom values
WRDTR,CLKTR: 0x82000800 0xc0000000
RQDC ,RFDC : 0x80000037 0x0000018d
ddr init done
Running Normal Memtest...
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x82000800, 0xc0000000
RQDC, RFDC : 0x80000037, 0x0000018d
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is NOT up.
PCIE1 port 1 not initialized
PCIEx: initialization done
flashfs[0]: 150 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 5690368
flashfs[0]: Bytes available: 26694656
flashfs[0]: flashfs fsck took 24 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 64:00:f1:08:7a:cc
Waiting for PHY auto negotiation to complete... TIMEOUT !
Ethernet link is down.
The system has encountered an error initializing
the Ethernet port.
The system is ignoring the error and continuing to boot.
If you abort the system boot process, the following
commands will re-initialize Ethernet, TFTP, and finish
loading the operating system software:
    ether_init
    tftp_init
    boot
Loading "flash:/c1140-k9w7-mx.124-25d.JA2/c1140-k9w7-mx.124-25d.JA2"...#################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w7-mx.124-25d.JA2/c1140-k9w7-mx.124-25d.JA2" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 150 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32126976
flashfs[1]: Bytes used: 5690368
flashfs[1]: Bytes available: 26436608
flashfs[1]: flashfs fsck took 7 seconds.
flashfs[1]: Initialization complete.
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 11999232
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 11998208
flashfs[2]: flashfs fsck took 1 seconds.
flashfs[2]: Initialization complete....done Initializing flashfs.
Radio0  present 8363 8000 90020000 0 90030000 B
Radio1 not present 0 0 0 0 0 0
export@cisco.com.
Last reset from reload
1 802.11 Radio(s)
Press RETURN to get started!
*Mar  1 00:00:52.340: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:53.561: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:16:03.011: %SYS-5-RESTART: System restarted --
*Mar  1 00:16:03.011: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:16:03.031: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:16:03.032: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:16:03.913: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:16:04.031: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:16:14.895: %LINK-3-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:16:15.896: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
ap>
ap>
Re: Cannot Enable Radio on AIR-LAP1041N-E-K9 autonomous
Your AP, specifically a AP1141, only has ONE radio, 802.11b/g.
This specific model does NOT have 802.11 a/n radio.
Hi leo thank you so much for the quick reply.. i see so it only has one radio but i just need to say that this is1041N-E-K9 not 1141...
Ok, sorry,  1041.  Still the same.  The last digit in your model number signifies the amount of radios.  1041 means a single radio (802.11b/g) and 1042 means you have both radios (802.11 a/b/g/n).
Thank you Leo you saved my day.. Thank you.
Ohh leo by theway at the back of the AP the sticker says Aironet 802.11n single band access point.. so does it mean that it has "n" ?
VIP Purple
Hi Prasad,
802.11n is not another band, it can operate in either 2.4GHz (b/g/n) or 5GHz (a/n) which are the two frequency bands.
Rasika
Thank so much for the reply rasika. and thanks for the info.
you shure can run "n" on 2,4 ghz, its recommened to use only 20Ghz Channels aat 2,4 Ghz..
You CANNOT run 802.11n with just 802.11b/g (2.4 Ghz) radio.
802.11n requires 802.11a/n radios.
Thank you once again for the clarification leo
Christian is Correct. You sure CAN!! run 802.11n on 802.11b/g but as he stated, Cisco recommends only 20Mhz because of channel overlap and interference created when you can only enable 1 x 40Mhz channel. Cisco Channel Deployment Readme
Hall of Fame Super Silver
I think Leo got confused with channel bonding on the 2.4ghz, which you can't do.  That AP is 802.11N capable, but the client needs to be N compatible and you also need to follow the standard.  Open and WPA2/AES is supported by 802.11n standard, WEP and WPA/TKIP is not and you will only see up to 144mbps on the 2.4ghz.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
The access point radios are disabled by default, and there is no default SSID. You must create an SSID and enable the radios before the access point allows wireless associations from other devices. Refer to the "Configuring Basic Security Settings" section for instructions on configuring the SSID.
Follow these steps to enable the radio interfaces:
Step 1 Browse to your access point.
Step 2 When the Summary Status page appears, click 802.11N2.4GHz. The 2.4-GHz radio status page appears.
Step 3 Choose the Settings tab at the top of the page. The Radio Settings page appears.
Step 4 Click Enable in the Enable Radio field.
Step 5 Click Apply.
Step 6 Return to the Summary Status page and click 802.11N5GHz. The 5-GHz radio status page appears.
Step 7 Repeat Steps 3-5.
Step 8 Close your web browser
More more information please check out the following cisco doc:
http://www.cisco.com/en/US/docs/wireless/access_point/1140/autonomous/getting_started/guide/ap1140aut_getstart.html#wp40423
1887
