Cannot login using Iphone/Ipad cisco WLC 4404 and WISM ver 7.0.240
Logs on WLC
*apfReceiveTask: Feb 05 16:56:20.132: %MM-1-ANCHOR_UNAVAILABLE: mm_mobile.c:2442 All export anchors are down. Cannot anchor the client.8c:fa:ba:c5:1d:69
*dot1xMsgTask: Feb 05 16:56:02.929: %DOT1X-3-MAX_EAP_RETRANS: 1x_ptsm.c:463 Max EAP retransmissions exceeded for client 8c:fa:ba:c5:1d:69
*dot1xMsgTask: Feb 05 16:55:55.129: %DOT1X-3-MAX_EAP_RETRANS: 1x_ptsm.c:463 Max EAP retransmissions exceeded for client 8c:fa:ba:c5:1d:69
*dot1xMsgTask: Feb 05 16:55:47.329: %DOT1X-3-MAX_EAP_RETRANS: 1x_ptsm.c:463 Max EAP retransmissions exceeded for client 8c:fa:ba:c5:1d:69
Issues resolves after rebooting the devices. Please advise on this
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Here is the info for that error.... the error states an issue with the connectivity between the foreigh and the anchor wlc.
Error Message    %MM-1-ANCHOR_UNAVAILABLE: All export anchors are down. Cannot anchor
the client.[hex]:[hex]:[hex]:[hex]:[hex]:[hex]
Explanation    No export anchors are up to anchor the client. A loss of network connectivity has occurred between the WLC and the export anchors for this WLAN.
Recommended Action    Debug the network and the status of the anchors for connectivity issues.
http://www.cisco.com/en/US/docs/wireless/controller/7.0/sysmessage/guide/mirror_mm_mmc_7_0_msgs16.html
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Re: Cannot login using Iphone/Ipad cisco WLC 4404 and WISM ver 7
I would think that this would affect all devices since a reboot seemed to of fixed your issue. It's hard to say what was the cause since you rebooted the WLC. It seems like you are anchoring which could of meant that maybe the mobility was down.
-Scott
Hi Scott,
Thanks for your fast response. We did not reboot the WLC. We just reboot the end user device.
Well... it possibly an iPhone/iPad issue... i have to reboot my iPad almost daily, my wife's iPad is fine and my iPhone, once in a while.  All because it will fail to connect to any SSID.
Scott
-Scott
Hi Scott,
Thanks for your reply. Just one last question
after 3x     DOT1X-3-MAX_EAP_RETRANS I get  MM-1-ANCHOR_UNAVAILABLE any reason for anchor not available message for the same client? Please advice
Scott
-Scott
314
