cant upgrade AP to Lightweight using WCS or Upgrade Tool
when I try the Upgrade Tool, I get an error that Station Role should be a Root. When I try WCS to upgrade I got the error below. HELP
INFO: Telnet to device 10.108.200.101 done.
INFO: Privilege level is equal to 15.
INFO: Setting vty line completed.
INFO: Dumped Environmental variables.
INFO: AP is supported for Upgrade process
INFO: IOS version is greater than or equal to 12.3(7)JA.
INFO: AP has MIC installed already.
INFO: Station role is root.
INFO: DNS and Domain name configured.
INFO: Mac address of device is 00:1d:a1:ef:f7:58
INFO: Completed Dot11Radio0 shutting.
INFO: Device set up done and time configured on device.
INFO: Run-config dumped.
INFO: Gateway 10.108.200.254
INFO: Hostname MHaccess1_203F
INFO: Starts loading recovery image, takes time based on link speed.
ERROR: Device Response :: examining image...
%Error opening (Invalid IP address or hostname)
archive download: takes 0 seconds
ERROR: Image Loading FAILURE.
INFO: Un-shut radio 1 done.
END: Migration Process Failure: Image Loading Failure.
Re: cant upgrade AP to Lightweight using WCS or Upgrade Tool
post "show run" of your AP and post screenshot of upgrade tool before you start upgrade
I.ve attached them
You have this on Dot11Radio0
station-role root fallback shutdown
Change it to
station-role root
and try again
that got me farther than before, the LWAPP image will not load, I am assuming it's the TFTP server possibly ...
2009/05/12 16:34:33 INFO 10.108.200.101 User has Full privilege
2009/05/12 16:34:33 INFO 10.108.200.101 Getting AP Name
2009/05/12 16:34:34 INFO 10.108.200.101 AP has 12.3(7)JA Image or greater
2009/05/12 16:34:34 INFO 10.108.200.101 Term Length configured.
2009/05/12 16:34:34 INFO 10.108.200.101 Upgrade Tool supported AP
2009/05/12 16:34:34 INFO 10.108.200.101 AP has two radios
2009/05/12 16:34:34 INFO 10.108.200.101 AP has Supported Radio
2009/05/12 16:34:34 INFO 10.108.200.101 Station role is Root AP
2009/05/12 16:34:35 INFO 10.108.200.101 MIC is already configured in the AP
2009/05/12 16:34:35 INFO 10.108.200.101 Hardware is PowerPCElvis Ethernet, address is 001d.a1ef.f758 (bia 001d.a1ef.f758)
2009/05/12 16:34:35 INFO 10.108.200.101 Inside Shutdown function
2009/05/12 16:34:37 INFO 10.108.200.101 Shutdown the Dot11Radio1
2009/05/12 16:34:39 INFO 10.108.200.101 Shutdown the Dot11Radio0
2009/05/12 16:34:40 INFO 10.108.200.101 Updating the AP with Current System Time
2009/05/12 16:34:41 INFO 10.108.200.101 Saving the configuration into memory
2009/05/12 16:34:41 INFO 10.108.200.101 Getting AP Name
2009/05/12 16:35:25 ERROR 10.108.200.101 Unable to Load the LWAPP Recovery Image on to the AP
2009/05/12 16:35:31 INFO 10.108.200.101 Dot11Radio1 is up now
2009/05/12 16:35:36 INFO 10.108.200.101 Dot11Radio0 is up now
Thanks very much for your help by the way! I am going to try the upgrade tool TFTP server and see how it goes now
I did get an error that the ACL\Firewall might be blocking the TFTP and to disable it. I am using Vista with Forefront Client Security
The command that upgrade tool is trying to run on AP and fails is this:
"arch down /over /create-space tftp://10.115.10.21/c1130-rcvk9w8-tar.123-11JX1.tar"
try to run this command manually on the AP and see what error message it gives you? Are you sure TFTP server is running on your PC? Does it point to the right directory?
Your upgrade tool is configured for "Use External TFTP Server", maybe try "Use UpgradeTool TFTP Server" setting.
Hall of Fame Super Gold
You are using the 1130? Very good! Are you willing to try the following procedures?
Requirements:
• Image file (The recovery file has the prefix “rcv” in the image name, such as c1130-rcvk9w7-tar.122-15.JA.tar);
• AP is connected to the Wireless LAN Controller; and
• AP can ping the TFTP server where the image is located.
Procedure
1. Copy the recovery file to the AP using the following command:
archive tar /x tftp:/// flash:
2. Let the AP boot on this image:
boot system flash://.bin
3. Reboot the AP.
OPTIONAL
• DO NOT ALLOW THE AP TO JOIN THE WIRELESS LAN CONTROLLER IN ORDER TO USE THE OPTIONAL COMMANDS BELOW.
• IF POSSIBLE, type the following commands:
 clear lwapp private-config (This will bring the AP to factory default.);
 clear lwapp ap ip address
 clear lwapp ap hostname
 clear lwapp ap controller ip address
4. Let the AP connect to the Wireless LAN controller.
OPTIONAL
If an AP refuses to join the Wireless LAN Controller, type the following command from the AP:
I changed the dot11radio1 station-role parameter as suggested and that seemed to have worked but windows firewall was preventing the TFTP transfer even after TFTP exception was created. I disabled the firewall all together and ran the upgrade tool again and thankfully the AP has now converted to lightweight.
The issues now is it has not joined WCS. I believe this is related to VLAN/DHCP issues at this point. I am switching VLANs and will check the scope build on our DHCP server.
I believe you mean it hasn't joined WLC.
Is AP on the same VLAN as management IP of WLC? If it is, it should have joined automatically, so I assume it's not on the same subnet.
You have three options:
1. DHCP option 43. Look for instructions on CCO
2. DNS. AP will attempt to resolve CISCO-LWAPP-CONTROLLER host name from the DNS server provided by DHCP
3. Manually prime AP from CLI, here's an example from CCO:
AP1240#clear lwapp private-config
AP1240#lwapp ap hostname AP1240
AP1240#lwapp ap ip address 10.77.244.199 255.255.255.224
AP1240#lwapp ap ip default-gateway 10.77.244.220
AP1240#lwapp ap controller ip address 172.16.1.50
AP1240#show lwapp ip config
LWAPP Static IP Configuration
IP Address 10.77.244.199
IP netmask 255.255.255.224
Default Gateway 10.77.244.220
Primary Controller 172.16.1.50
Once AP associates with WLC, then you configure PRIMARY WLC in the AP settings on the WLC web interface. That name is the system name of the WLC controller (it's not a DNS name! and don't put an IP address in there!). Next time AP resets it will connect to the last primary WLC it remembers about.
ok It looks like I finally got it to join the WLC and it's talking to WCS.
DHCP option 43 was used to add the 4 WiSM controller and nothing else. The AP was on the same VLAN as the Mgmt IP of the WiSM.
It was showing up with a DHCP assigned IP as well as a static IP (10.0.0.1)but on the wrong WiSM controller. I unchecked the static IP box and then tried to select the proper AP group and controller.
Unfortunatley the AP group I had built was not showing and when trying to save the setting that I could modify, amessage came up requesting to create a Global Username/Password??? I did and eventually the AP group showed and the AP moved to the proper controller. But then guess what? The clients couldn't connect to the SSID's.
I checked VLAN settings on our Dist and core switches as well as DHCP scopes and Radius. It all matched up but finally found out I had not added the IP range we wanted to use for wireless to the access list on our core switches. after doing so, VOILA! we now have full wireless connectivity.
Questions. It seems that when the AP tried to join the controller I wanted it to, I didnt see the AP group I had built in there. It instead joined the backup controller before I forced it to join the primary WLC.
Why am I bing asked to create a global username after I had already done so in my upgrade text file.
Why was the AP being introduced to the WLC with DHCP and Static IP's?
The original problem with the TFTP transfer was related to desktop issues with my windows firewall.
Thanks for your help. This was my first experience with the Cisco Forum and I am happy I got you guys.
Rob
1590
