05-29-2014 12:58 AM - edited 07-05-2021 12:54 AM
I want to convert CAP-AIR 2600 access point to SAP but i can't connect to it via console ..it needs controller but i haven't.
05-29-2014 01:31 AM
HI,
Yes you can convert it to SAP easily.
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/document/71501/installing-autonomous-ios-aios-lightweight-ap-cli
https://supportforums.cisco.com/document/57476/lwapp-autonomous-conversion-and-vice-versa-access-points
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
https://www.youtube.com/watch?v=QQ_NuxdRhQ4
Dont forget to rate helpful posts
05-29-2014 02:43 AM
I can't access it via console connection it needs WLC and I don't have it. !!
05-29-2014 03:05 AM
AP need to WLC to get configuration file but if you want to convert it then try to reset it
Reset AP:
Remove power supply.
Press mode and connnect power supply agin while pressing mode buttion(10-15 seconds till status light shows amber colour)
then try to convert it.
05-29-2014 02:42 AM
