CAP3602 LightWeight AP disassociated from Controller 2405
Hi all,
I am facing a issue in my WLAN,CAP3602 LightWeight AP suddenly disassociated from Controller 2405. All other APs are working fine. Even i can ping that disassociated AP and i can see on that switch through CDP it working but cant able to associate controller. Can any body help me to rectify  this issue??
Hall of Fame Super Silver
Can you post an output from the console or some info so we can see whats going wrong?  Is the AP's in local mode and located in the same location as the WLC?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Re: CAP3602 LightWeight AP disassociated from Controller 2405
yea AP is in local mode but AP is not in approach so cant give u console logs. I can Ping the AP from Controller
So the AP hasn't joined the WLC... At least you know that the AP is pingable, but hopefully its not a duplicate ip address.  It's tough to say whats wrong... if you can look at the CDP neighbor on the switch and maybe ping the ip and then shut the port and verify that the ping stops.  Then let the AP boot back up and check CDP to see if the AP has enough power and that you see the hostname of the AP in CDP.
Scott
-Scott
@Scott
Here is the Log on WLC
*spamApTask3:  Feb 05 10:12:59.772: #CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:6655 Did not  receive heartbeat reply; AP: c0:25:5c:f3:0e:b0
Already Done all these steps
Scott
VIP Purple
As per this logs... The Controller did not get a response for the AP heartbeat message. May be connectivity issues between the AP and the controller.
To resolve this kind of issue Check  if the AP has rebooted or if it has been removed from the network. Also ensure that there are no connectivity issues between the AP and the controller.
Dont forget to rate helpful posts
That doesn't help much. You have other AP's that are joined from that site to the WLC? What does CDP show. Did the ping stop?
-Scott
yes i have those are working fine
CDP shows Name of that AP when i shutdown port, ping was stopped
Zohaib,
Since you have other AP's at the same site that are working and joined to the WLC, you will need to console into the AP and look at the output.
Post the show CDP neighbor detail
-Scott
.Post the show CDP neighbor detail
sh cdp neighbors
AP-OFFICE
                 Gig 1/0/9         148              R T   AIR-CAP36 Gig 0.1
VIP Purple
What is the WLC software version you are running ?
Once AP rebooted, does it get registered ?
Rasika
Software Version 7.5.102.0
AP still not registered
Post the show CDP neighbor detail on that AP port and another AP on that switch. I need to see the detail.
-Scott
Scott
SMBZ#sh cdp neighbors detail
Device ID: AP-Old-Office
Entry address(es):
  IP address: 172.16.30.212
Platform: cisco AIR-CAP3602E-N-K9,  Capabilities: Router Trans-Bridge
Interface: GigabitEthernet1/0/2,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 174 sec
Version :
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.2(4)JA1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 30-Jul-13 22:57 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 15.400 Watts
Power request id: 10260, Power management id: 1
Power request levels are:15400 13000 0 0 0
Power Available TLV:
    Power request id: 0, Power management id: 0, Power available: 0, Power management level: 0
Management address(es):
Device ID: AP-OFFICE
Entry address(es):
  IP address: 172.16.30.217
Interface: GigabitEthernet1/0/9,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 163 sec
Version :
Duplex: full
Power request id: 44378, Power management id: 1
Well it looks like you will need to get to that AP to have console access.  SInce the CDP shows up fine and everything looks okay along with other ap's associated to the WLC, you now need to access the console and reboot the AP and provide us with the output of the log.
You do have enough ap license on the WLC correct?
Scott
-Scott
Thanks. i will try to access from console, when i will be there. i am connected to VPN thats why its difficult for me for next  couple of days i will get back to you if issue remains.
Yes i have.
Okay... Just reply back when you get a chance. I would shut the port down so that devices don't connect to that AP. If it joined before, it may still broadcast the SSID.
-Scott
#Scott,
Sorry for late reply AP associated with Controller after reboot, for some reason i could get there to check from console and can't reboot remoting because there that AP is on Power Injector....but thanks for help
Ah.. so power cycling the AP helped?
Scott
-Scott
Hall of Fame Super Gold
That's not possible.
Look at the output to the command "sh cdp neighbor".  Look at how much power is drawn.
The "sh cdp neighbor detail" command is telling me the switch is providing 15.4w PoE to the AP.
VIP Purple
paste output of sh sysinfo from wlc and also paste the entire console boot process .
Reagrds
931
