Community Member
Catalyst c3750G Integrated WLC
Hi All,
I'm setting up a catalyst 3750G with integrated WLC switch for a client. The swithing portion look good, but i'm facing problem with bringing up the WLC. Below is the information.
WLC Software:5.0.148.0
ap-manager LAG 1 172.16.1.252 Static
management LAG 1 172.16.1.253 Static
service-port N/A N/A 10.10.10.1 Static
virtual N/A N/A 1.1.1.1 Static
wlan_773 LAG 773 10.226.3.254 Dynamic
The problem that i'm facing now is i can't connect to the management interface from the network even i've configure an IP for that. As from the Cisco Doc, the LAG is the only option for this integrate WLC, i cannot disable it. The 3750G is the same management IP as the WLC management interface, which's 172.16.1.2/16
the management IP for WLC and 3750G are within the same VLAN and subnet, and both the devices trunking are connected, how come they can't reach each other?
regards.
orochi
1 REPLY
Community Member
Re: Catalyst c3750G Integrated WLC
Hi all,
I managed to resolve this issues by referred to another post from this forum session also.
thanks.
Orochi
238
