Community Member
Cisco 1131AG AP not able to boot
Dear All,
My AP 1131AG is not light weight mode and not able to boot. I have captured logs from consle port it stuck up after following error:
Xmodem file system is available.
flashfs[0]: 9 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 6000640
flashfs[0]: Bytes available: 9998336
flashfs[0]: flashfs fsck took 30 seconds.
Base ethernet MAC Address: 00:21:d8:3d:8a:7a
Initializing ethernet port 0...
Reset ethernet port 0...
Ehternet LED goes green and red.
Any idea what to do?
AS
Everyone's tags (1)
Hall of Fame Super Blue
I hope you have SmartNet contract because your next move is to contact Cisco TAC and get this RMA-ed.
Community Member
Re: Cisco 1131AG AP not able to boot
Engage TAC, initiate RMA.
Bronze
Have you tired using the mode button to either reload the IOS or reset the AP to defaults?
If this does not work then you will need to have the unit replaced.
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38trb.html
Check under Resetting to the Default Configuration using the mode button or Reloading the Access Point Image using the mode button.
687
