Cisco 1142 Wireless access point intermittently will not authenticate
Hi all,
We have a Cisco 1142 standalone access point, and from time to time I will come into the office and it will not authenticate any users to either our guest or corporate networks. I then have to go in and reboot the access point. After that, it begins to work. Any advice? Here's my configuration below:
Current configuration : 6450 bytes
version 12.4
no service pad
service password-encryption
hostname cisco-chiap01
logging monitor errors
enable secret 5 $1$fsD8$CU42/3/Up5AAlL4hQWvvg0
aaa new-model
aaa group server radius rad_eap
 server 172.17.16.12 auth-port 1645 acct-port 1646
 server 172.17.21.10 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap2
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods2 group rad_eap2
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
login on-failure log
login on-success log
dot11 syslog
dot11 vlan-name Admin vlan 100
dot11 vlan-name DevNetwork vlan 20
dot11 vlan-name Guest vlan 150
dot11 vlan-name Network vlan 16
dot11 ssid DevNetwork
   vlan 20
   authentication open eap eap_methods2
   authentication network-eap eap_methods2
   authentication key-management wpa version 2
dot11 ssid Guest
   vlan 150
   authentication open
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 142407060101380B013A3A2670435642
   information-element ssidl advertisement
dot11 ssid Network
   vlan 16
username monkeyman privilege 15 secret 5 $1$ZZ7C$rqimu2FNONdfeacMNGAD/.
bridge irb
interface Dot11Radio0
 no ip address
 ip helper-address 172.17.19.10
 no ip route-cache
 encryption mode ciphers aes-ccm
 encryption vlan 16 mode ciphers aes-ccm
 encryption vlan 150 mode ciphers aes-ccm
 encryption vlan 20 mode ciphers aes-ccm
 ssid DevNetwork
 ssid Guest
 ssid Network
 antenna gain 0
 parent timeout 120
 speed  5.5 11.0 basic-6.0 9.0 12.0 36.0 48.0 54.0
 packet retries 128 drop-packet
 channel 2462
 station-role root
 rts threshold 512
 rts retries 128
interface Dot11Radio0.11
 encapsulation dot1Q 11
 no ip route-cache
interface Dot11Radio0.16
 encapsulation dot1Q 16 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.20
 encapsulation dot1Q 20
 no ip route-cache
 bridge-group 20
 bridge-group 20 subscriber-loop-control
 bridge-group 20 block-unknown-source
 no bridge-group 20 source-learning
 no bridge-group 20 unicast-flooding
 bridge-group 20 spanning-disabled
interface Dot11Radio0.150
 encapsulation dot1Q 150
 no ip route-cache
 bridge-group 150
 bridge-group 150 subscriber-loop-control
 bridge-group 150 block-unknown-source
 no bridge-group 150 source-learning
 no bridge-group 150 unicast-flooding
 bridge-group 150 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 ssid DevNetwork
 ssid Guest
 ssid Network
 antenna gain 0
 traffic-metrics aggregate-report
 dfs band 3 block
 mbssid
 parent timeout 120
 speed  6.0 12.0 basic-24.0 36.0 48.0 54.0
 channel width 40-above
 channel dfs
 station-role root access-point
interface Dot11Radio1.11
 no ip route-cache
interface Dot11Radio1.16
 no ip route-cache
 bridge-group 1
interface Dot11Radio1.20
 no ip route-cache
 bridge-group 20
interface Dot11Radio1.150
 no ip route-cache
 bridge-group 150
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
interface GigabitEthernet0.11
 no ip route-cache
interface GigabitEthernet0.16
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.20
 no ip route-cache
 bridge-group 20
interface GigabitEthernet0.100
 encapsulation dot1Q 100
 ip address 192.168.100.3 255.255.255.0
 no ip route-cache
 bridge-group 100
 no bridge-group 100 source-learning
 bridge-group 100 spanning-disabled
interface GigabitEthernet0.150
 no ip route-cache
 bridge-group 150
interface BVI1
 ip address 172.17.16.251 255.255.255.0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface GigabitEthernet0
access-list 1 permit 172.17.16.1
access-list 1 remark Admin network access
access-list 1 permit 192.168.100.0 0.0.0.255
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.17.21.10 auth-port 1812 acct-port 1813 key 7 047958071C3561410D4A44
radius-server host 172.17.16.12 auth-port 1645 acct-port 1646 key 7 08045E471A48574446
radius-server host 172.17.21.10 auth-port 1645 acct-port 1646 key 7 1320051B185D56797F
radius-server timeout 15
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
 access-class 1 in
end
VIP Purple
When the issue occurs does
When the issue occurs does that affect both 2.4GHz & 5GHz devices ? I would see which band operating devices affected.
I noticed you have set CH11 under Radio 0 statically.  I would prefer to configure it as below so AP can change the channel depend on the environment.
int d0
channel least-congested
Rasika
**** Pls rate all useful responses ****
Thanks for the input.To
To answer your question, yes it does happen on both 2.4GHz and 5GHz devices.
For the static channel, I did that for our old building because we were having channel interference in our last office suite and statically setting it made it much more predictable. We've moved since then, so I can definitely change it back.
VIP Purple
If that is the case I would
If that is the case I would check the IOS upgrade option as well.
What version of 12.4.(x) is running on your 1142 ?
Rasika
Version 12.4(23c)JA6Michael
Michael
VIP Purple
I do not have these
I do not have these autonomous AP in my production. But I have used below code for my lab environment & did not come across any issues.
So if possible move to that & see if any improvement
c1140-k9w7-tar.124-25d.JA.tar
Rasika
I will take your suggestions
I will take your suggestions and give any updates. Thank you very much for all your help!
68
