Cisco 1142N Radio interface gone
Hi All,
I have around 20 1142Ns registered to 4402 WLC. WLC was saying:
     802.11a/n Radios     20
     802.11b/g/n Radios     19
So I compared and found the AP which had only 802.11a/n Radio. SSH-d to the AP and sh ver:
1 Gigabit Ethernet interface
1 802.11 Radio(s)
and if I try to configure the radio interface:
apname(config)#interface dot11Radio ?
  <0-1>  Dot11Radio interface number
apname(config)#interface dot11Radio 0?
.  :  <0-1>
apname(config)#interface dot11Radio 0 ?
% Unrecognized command
apnameconfig)#interface dot11Radio 1 ?
  <cr>
So as you can see dot11Radio 0 is gone. I've tried rebooting the AP with no success. I'm thinking there is a hardware failure with the radio antenna.
Has anyone experienced this kind of problem? What could be the cause?
Delgee
This can happen, the 2.4Ghz radio probably died on you.
Try getting a "Show controllers" of your AP and see what it says about Dot11radio0.
You're probably heading towards an RMA anyway
show controller return same as config t, dot11Radio 0 has just disappeared:
lapname#sh controllers dot11Radio 0 ?
lapname#sh controllers dot11Radio 1 ?
  |  Output modifiers
Consoled and restarted the AP:
bsnInitRcbSlot: slot 0 has NO radio
and it is saying 1 radio interface:
cisco AIR-LAP1142N-A-K9    (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FTX1504EHJF
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 7.0.98.0
1 802.11 Radio(s)
Hall of Fame Super Gold
Contact Cisco TAC and get the part replaced.  The 1140 should be covered under the Cisco Limited Lifetime Hardware Warranty.
Right.  I've seen this before.
Try the following:
1.  Console into the AP and post the complete "sh log".
2.  Reload the AP.
I noticed that when running 7.0.98.0 firmware I get APs (1140 and 3500) suddenly loosing one of the two radios (either one).  One way for me fixing it is to reboot the AP and they should be fine.
Hope this helps.
I tried reloading the AP with no success. I'll try to console and   reload but its mounted and not that easy to connect. Thanks for the   replies, guys.
Ok.  If you can console into the AP then try the following from the WLC CLI:
config ap debug enable
config ap debug command "sh log"
Post the output
config ap debug disable
Hey Leo,
Exactly what I think he should do. Although it probably is a bad radio in the slot, I have seen power being an issue on these Marvell radios. Overloading a PoE switch to its very limits can cause one radio to not initiate and this would only be identified by looking at the output of the debugs on the AP as the controller never sees it in the slot. A quick way to verify this is to replace the AP with another 1142 in the same spot. Since it is port dependent on the switch then the new AP will exhibit the same behaviour. I have only seen this twice in 3 years.
Re: Cisco 1142N Radio interface gone
Thank you for reminding me something ...
WHAT is the bootstrap version of the 1140???  I've seen Cisco release a bootstrap update for the 1140 ONLY:  12.4(23)JA1
Someone from Cisco told me that this fixes some issues with the radios (the person couldn't be more specific than that).  The new 7.0.116.0 firmware won't upgrade the bootstrap so one has to do something out of the ordinary:
1.  Convert the AP into autonomous;
2.  Copy the bootstrap into the AP;
3.  Copy the bootstrap from the AP to the bootstrap of the AP using the command "copy to bs:";
4.  Reboot;
5.  Convert to CAPWAP.
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE (fc3?
I've tried to convert it back to autonomous and then to LAP but it was giving me some error which I haven't seen before. We have around 50 of these APs and only this one is giving me this kind of errors. I'll try to convert to autonomous and try what you suggested and if it fails, gonna get it replaced.
Thanks guys!
Convert it to autonomous FIRST, then upgrade the bootstrap to 12.4(23)JA1 (using the command I've posted) and then convert it back to LWAP/CAPWAP.
Looking forward to hear the result(s).
Converted to autonomous, upgraded bootstrap:
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA1, RELEASE SOFTWARE (fc1)
Converted back to lightweight and the problem is still same:
APxxxx.xxxx.xxxx#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio1                unassigned      NO  unset  up                    up
GigabitEthernet0           x.x.x.x       YES DHCP   up                    up
1 802.11 Radio(s)
Guess the only option left is to get it replaced under its warranty.
I have replaced the AP with a spare and connected it to my test environment with same results. Thanks for the suggestion but I guess PoE is not the cause here.
The test environment rules out the power as being the problem. I would suggest opening a warranty claim on the unit and replacing it. The time you have spent already exceeds the time the new AP would have taken to arrive. Kudos for trying to resolve this yourself.
Thanks for all the help suggestions guys.
2169
