Cisco 1230 max clients per AP & solutions?
Hi all
We have approx 15 APs located around site. We have introduced 40+ notebooks recently and noticed slow access with our wireless network.
I understand the recommend amount is roughly 10-20 clients per access point. The less clients connected the better performance per user.
My question is can I change the max associations for each AP to 10 or 20, introduce a few more new AP's and would this mean the client notebook would keep trying until it reaches an AP that will accept associations ? Is this the recommended solution ?
Jon
Re: Cisco 1230 max clients per AP & solutions?
I believe the hard coded limit for associations is 32. But I would never go above 15 per access point as your performance will suffer greatly.
I would add more AP's into your environment to lighten the load. If you were in an LWAPP environment, the controller can handle load balancing for you as well.
Hi Jon
Greetings!
what type ur application ur using in you clients(Laptops).my experiance i am using 25 Laptops per AP .ITS working fine for internet browing.but it doesn'tsupport for Applications like Browser based.i suggest you to put a WLAN Controller and automatic load balancing .it wil solve your problem
regs
s.Mohana sundaram
262
