Community Member
Cisco 1242 AP Conf
Dear Sir,
i need to configure mobile on access point on cisco 1242 ap
what are steps i need to follow and also share the configuration steps for that
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.04.03 14:55:04 =~=~=~=~=~=~=~=~=~=~=~=
cisco1242#sh run
Building configuration...
Current configuration : 1902 bytes
version 12.4
no service pad
service password-encryption
hostname cisco1242
enable secret 5 $1$Lev1$okqV0elsefS4ii0oDOIla0
no aaa new-model
dot11 ssid PenguinFinance
   authentication open
   guest-mode
power inline negotiation prestandard source
username Cisco privilege 15 password 7 106D000A0618
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption key 1 size 128bit 7 3841A362155D3214A5439B05B04B transmit-key
 encryption mode wep mandatory
 ssid PenguinFinance
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio1
 no ip address
 no ip route-cache
 encryption key 1 size 128bit 7 B543776D56B3651C4A3415AC5FC5 transmit-key
 ssid PenguinFinance
 dfs band 3 block
 speed  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
 channel dfs
 station-role root
 bridge-group 1
interface FastEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 168.146.177.43 255.255.255.0
 no ip route-cache
ip default-gateway 168.146.177.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
end
cisco1242#
2 ACCEPTED SOLUTIONS
VIP Purple
Hi,"i need to configure
"i need to configure mobile on access point on cisco 1242 ap"
Can you explain little bit more what is your requirement to help on this. I did not understand what you mean by the above.
Rasika
VIP Purple
Hi Kamal,This may due to
Hi Kamal,
This may due to configuration of WEP on your AP. This is not a good security protocol & should not be used any longer.
I would suggest you to configure WPA2/PSK & see if that works for all clients. Give it a go & see whether 1242 supports WPA2. Here is a sample config. I have used Cisco123 as password, you can change it to whatever you like.
Lines in BLUE are new additions & lines in RED to be removed.
   authentication open
   guest-mode
   authentication key-management wpa version 2
   wpa-psk ascii 0 Cisco123
 encryption mode ciphers aes-ccm
 ssid PenguinFinance
 speed default
 station-role root
 bridge-group 1
 ssid PenguinFinance
 dfs band 3 block
 speed default
 channel dfs
 station-role root
 bridge-group 1
 bridge-group 1
Let us know how it goes
Rasika
**** Pls rate all useful responses ****
VIP Purple
Rasika
Community Member
actually laptop and desktop
actually laptop and desktop users are able to connect but apple IPAD & I Phone users are not able to connect
so just want to know is there any specific settings for apple users or setting are common
i am also pasting my conf..
sh run
version 12.4
no service pad
hostname PenguinFinance
no aaa new-model
   authentication open
   guest-mode
bridge irb
 no ip address
 no ip route-cache
 ssid PenguinFinance
 station-role root
 bridge-group 1
 no ip address
 no ip route-cache
 ssid PenguinFinance
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 login local
VIP Purple
Hi Kamal,
   authentication open
   guest-mode
 ssid PenguinFinance
 speed default
 station-role root
 bridge-group 1
 ssid PenguinFinance
 dfs band 3 block
 speed default
 channel dfs
 station-role root
 bridge-group 1
 bridge-group 1
Rasika
Community Member
Dear Manannalage rasika
Dear Manannalage rasika Nayanajith
Thanks for sharing
135
