Cisco 1242G converting Autonomous to Lightweight
I am trying to convert Cisco 1242G access point from Autonomous to Lightweight mode.
I downloaded Tftpd32 server and the Lightweight image c1200-rcvk9w8-tar.124-21a.JA2.tar
and issued the command "archive download-sw /force-reload /overwrite tftp://10.0.0.5/ c1200-rcvk9w8-tar.124-21a.JA2.tar"
But it is showing the following Error message
ERROR: Image family mismatch
The image you are using is for the 1220/1230 AP families. The 1240 AP has image prefix of c1240 instead of c1200.
So the file you would want is:
c1240-rcvk9w8-tar.124-21a.JA2.tar
Otherwise, the procedure you are using appears to be correct.
-Pat
Hall of Fame Super Gold
Get the correct IOS and follow the process below:
Using a TFTP Server to Return to a Previous Release
Re: Cisco 1242G converting Autonomous to Lightweight
Thank you. I installed the Lightweight image successfully
May I know how to configure for lwapp
Should I need to configure anything on Wireless controller
You need to do all your configuration on the WLC.  This is the main purpose of the WLC.
3104
