03-26-2014 12:22 PM - edited 07-05-2021 12:33 AM
I have a cisco 1262n if rebooted will display a hazel light but once a device is connect, does not display any type of light. Access Point is working jut like seeing my blue light once a device is connected. .... Thanks
Solved! Go to Solution.
03-26-2014 01:00 PM
As long as AP is working you should be fine (no visual indication though), As per the documents 1262 should have blue LED when client associated.
They mentioned below regarding LED status colours as well in the document as a note.
"Regarding LED status colors, it is expected that there will be small variations in color intensity and hue from unit to unit. This is within the normal range of the LED manufacturer's specifications and is not a defect."
In certain other AP models (like 1600 series ) you do not get this blue LED indicator at all.
Rasika
*** Pls rate all useful responses ***
03-26-2014 01:00 PM
Rasika
03-27-2014 10:40 AM
Thanks for the reply. All is working just miss my blue light. If I reboot, I see a hazel while boot but once startup completes no light. No biggie. Thought maybe a setting somewhere may correct this.
