Cisco 1262 repeater mode , blue led , not improving signal of the root
Helllo,
I am trying to improve the signal strength of a Cisco 1262 configured as an AP . I installed the second CIsco 1262 and set it to Repeater mode, same SSID , encryption mode and authentication method as the parent AP . On the parent AP I set the Infrastrucutre ID the same one as the SSID  and did the same on the repeater. So the AP SSID , the repeater SSID and the Isfrastrucutre ID are all the same . I can see the repeater associating with the parent (in the Association List), the logs say the same thing, no errors, but the signal it is not improving at all, as fi the repeater does not even exist. The led on the repeater is steady blue , the same on the AP . Any thoughts?  I would really need some help on this. Thank you.
Hall of Fame Super Silver
Can you see clients associated to the repeater?  When you use an AP as a repeater, the throughput is cut in half automatically, just to let you know.  I don't like to use repeaters, just because of performance issues.  If you can run an Ethernet cable to the other location, that is what I would recommend.  If you don't see client associated to that repeater, can you attach the configuration of both your AP's so we can see how you have it configured.
-Scott
Hi Scott,
Thanks for the fast answer . Here are the conf files for the AP and the Repeater. When I try to register I get associated only on the parent AP .
Parent AP configuration file :
version 12.4
no service pad
service password-encryption
hostname ue
logging rate-limit console 9
enable secret 5 xxxxxxxxxxxxx
no aaa new-model
dot11 syslog
dot11 ssid MYSSID
   vlan 66
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 xxxxxxxxxxxxxxx
username Cisco password 7 xxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 66 mode ciphers aes-ccm
ssid MYSSID
antenna gain -128
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel 2412
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface Dot11Radio0.66
encapsulation dot1Q 66 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 254
interface Dot11Radio1.66
no ip route-cache
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 254
interface GigabitEthernet0.66
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.5.22 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
And here is the configuration file for the Repeater. The led goes steady blue on both equipments.
version 12.4
no service pad
hostname ap
enable secret 5 xxxxxxxxxxxxxxxx
no aaa new-model
ip domain name cis
dot11 syslog
dot11 ssid MYSSID
   vlan 66
   authentication open
   infrastructure-ssid optional
   wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxx
username Cisco password 7 xxxxxxxxxxxxxxxxxxx
ip ssh version 1
bridge irb
no ip address
no ip route-cache
ssid MYSSID
antenna gain 0
parent 1 d48c.b52f.31a9
parent timeout 10
station-role repeater
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
shutdown
antenna gain 0
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.5.23 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Thnak you
743
