Cisco 1552H Outdoor AP
Hi Team,
Can anyone tell me the procedure to reset AIT-CAP1552H outdoor AP..?
I tried by pressing reset button while powering on. But it has battery, i am unable to make it to ap: mode.
Should i remove power and disable battery, then i have to press reset button..?
Or Any other simple solution is there.
Quick help is appreciated
Everyone's tags (1)
you can  reset the AP to
you can  reset the AP to factory defaults from WLC
It is not joined to the
It is not joined to the controller. How about pressing reset button while booting..?
However i tried it. Its not going to ap: mode.
Use a Phillips screwdriver to
http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifUse a Phillips screwdriver to remove the reset button screw then  http://www.cisco.com/c/dam/en/us/td/i/templates/blank.gifUse a straightened paper clip and push the reset button for longer than 10 seconds.
-When the access point is only battery powered, the access point reboots and then disables the backup battery power. The LEDs turn off for approximately 5 seconds, reactivate for approximately 5 seconds, and then turn off and stay off.
-When the access point has battery power and another power source, the access point reboots, then disables the battery and continues operating from the second power source. The LEDs turn off for approximately 5 seconds and then reactivate.
92
