Cisco 1602 AP issue
We are facing below issue with our recently purchased Cisco AP - AIR-CAP1602I-N-K9
CONFIGURATION :
  1. We have configured WAP2 security with Auto channels.
  2. Configured 2 SSID (CCL_WIFI & CCL_GUEST) as per VLAN, IP’s are assigned via DHCP to the Client.
ISSUE :
  1. Some of our laptop (MAC & Windows) are not able to Connect to CCL_GUEST SSID, if in case it get connect, the client are getting default IP (169.XX.XX.XX).
  2. If we connect to CCL_WIFI, it is getting properly connect and IP’s are getting assign properly.
  3. If we try to provide manual IP, some time it does not recognized the SSID (CCL_GUEST).
  4. We tried the same LAPTOP (MAC & WINDOWS) in our office having – Cisco AP AIR-AP1131AG-N-K9, with same configuration (WAP only), the devices are able to connect to both the SSID’s (BKT_WIFI & BKT_GUEST).
  5. IP’s are also getting properly (as per VLAN) via DHCP.
1 ACCEPTED SOLUTION
VIP Purple
Hi Nalin,I will recommand to
Hi Nalin,
I will recommand to use WPA2 with only AES encryption.
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm tkip
 encryption vlan 2 mode ciphers aes-ccm tkip
 encryption vlan 20 mode ciphers aes-ccm tkip
interface Dot11Radio1
 no ip address
Try to change these and try again.
Alos check this: https://supportforums.cisco.com/document/55561/multiple-ssid-multiple-vlans-configuration-example-cisco-aironet-aps
Dont forget to rate helpful posts
VIP Purple
Hi Nalin,
 no ip address
 no ip address
Thanks for for help.
86
