Cisco 1602i + Authenticating users via RADIUS?
Our company recently purchased a Cisco 1602i standalone WAP to replace the WAP4410Ns that we were having issues with.  I am now attempting to configure the RADIUS authentication, as we have a User network and a Guest connection.  The Guest connection works fine, using WPA PSK.  However, I can't seem to get the RADIUS authentication to work.  Reading the documentation has got me a little confused, and I have tried turning on debugging (debug radius authentication, debug aaa) but those show nothing.  Also, in the RADIUS server itself (Windows 2008 R2 NPS), I see nothing in the logs when I try to connect using a device or the "test aaa" command.  Can someone guide me on what I'm doing wrong?  I followed someone's advice on another forum and removed "authentication network-eap" from the SSID (phoenix_2), and now when I attempt to connect with a device it just asks me for a password, it doesn't prompt for a username anymore.  I am very stumped.  Here's the relevant config:
aaa new-model
aaa group server radius rad_eap
server 10.200.5.24
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone EST -5 0
ip cef
ip domain name gst
dot11 syslog
dot11 vlan-name guest vlan 255
dot11 vlan-name user vlan 140
dot11 ssid phoenix_2
   vlan 140
   band-select
   authentication open eap eap_methods
   mbssid guest-mode
dot11 ssid walker_2
   vlan 255
   band-select
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 0353035E535879191B
interface BVI1
ip address 10.200.5.70 255.255.255.0
ip default-gateway 10.200.5.1
ip forward-protocol nd
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 10.200.140.1
ip route 0.0.0.0 0.0.0.0 10.200.5.1
ip radius source-interface BVI1
access-list 111 permit tcp any any neq telnet
snmp-server community G!0bal RO
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.200.5.24 key 7 01445E510E1C07032A495C0D0B0C011718190D3E2E767863
radius-server vsa send accounting
The NPS worked just fine with the WAP4410Ns, not sure why we're having so much trouble with the 1602i.
VIP Purple
Re: Cisco 1602i + Authenticating users via RADIUS?
Hi Scott,
Follow this config example & see if you can get it working. Hopefully you should be able to fix it by yourself
http://mrncciew.com/2013/11/14/autonomous-ap-with-external-radius/
I can see multiple things are missing in your config (eg conflicting default routes, authenitcation key mgt missing on wlan, etc)
Rasika
**** Pls rate all  useful repsonses *****
Thanks Rasika,
I will look this over and see what I can do.  Another question, about the default routes, I was unable to remove the 10.200.140.1 default route using the "no ip route..." command.  Is there something I'm missing?  The correct default route should be the 10.200.5.1.  When I entered the "no ip route.." command, it accepted it with no error but nothign happened.
VIP Purple
Hi Scott,
Try "erase startup-config" & then reboot  your AP. So it should come up with zero configuration & then you can do the required configuration.
See whether in this way you can get rid of this duplicate default routes
Rasika
**** Pls rate all useful responses ****
Thanks Rasika, your link worked.  I had the authentication key before, but i removed it while I was trying different things.  My main issue was not applying the list name to the ssid, the documentation did not make it clear that when the radius server is specified using the "radius-server ...." command, that the radius group refers to that command when you configure the group.  Once that clicked, it made sense that the method list name was specifed by the radius group, and that the authentication methods then referred to the radius group.  It was a big question mark in my head how the radius server was applied to the SSID prior to reading your post.
I haven't tried the "erase startup-config" command yet, I will try that next.
Quick question, why are both authentication open and authentication network-eap needed?  I would assume authentication network-eap would suffice, unless the authentication open command refers to the allowed devices and not just authentication via RADIUS?
VIP Purple
Hi Scott,
That's great to hear.
Regargding authentication open (as shown below), it says authentication shceme can be open with EAP authentication. "network-eap" require as certain clients (like anyconnect) with certain EAP methods (like LEAP)
A1142-1(config)#aaa authentication login EAP_MTD group RAD_GRP
A1142-1(config)#dot11 ssid TEST
A1142-1(config-ssid)#   authentication open eap EAP_MTD
A1142-1(config-ssid)#   authentication network-eap EAP_MTD
A1142-1(config-ssid)#   authentication key-management wpa version 2
A1142-1(config)#interface Dot11Radio1
A1142-1(config-if)# encryption vlan 143 mode ciphers aes-ccm
Pls do not forget to rate our responses if that helps you.
Rasika
967
