Community Member
Cisco 2500 Series Wireless Controller add AP's AIR-CAP702I-E-K9
Dear ALL
I have Cisco 2500 Series Wireless Controller and Access Point AIR-CAP702I-E-K9 not joining to controller.
I's some one can help me?
Join request received from an unsupported AP writing on controller
Community Member
Hi,702I requires the software
702I requires the software 7.5 or 7.6 to join.
Are you running one of these codes?
Cheers,
Nour
Please check the
Please check the compatibility matrix:
Access Points
First Cisco Wireless Release Support
Last Cisco Wireless Release Support
First IOS XE Release Support
Last IOS XE Release Support
700 Series
AIR-CAP702I-x-K9
7.5.102.0
3.6.0E
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
VIP Purple
HI Tahir,As other mentioned
HI Tahir,
As other mentioned you must have have 7.5 or higher version WLC to Join this AP.
Check this matrix:http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
If you have 7.5 or 7.6 version and still not joining then please paste the output of these commands:
From WLC. sh sysinfo
From AP: sh version
Dont forget to rate helpful posts
Community Member
hi  Can you give me a AP 7021
hi
  Can you give me a AP 7021 n of ios,I have an AP 7021 n system is broken, I need a thin AP version of this equipment. My email is zjdataa@126.com.
Thanks for you
VIP Purple
Hi,You dont need IOS fro AP.
You dont need IOS for AP.
You just have to upgarde the image on WLC to 7.5.or 7.6.
If you have a valid smarnet contract then you can download from here:
http://software.cisco.com/download/release.html?mdfid=283848165&flowid=24841&softwareid=280926587&release=7.6.130.0&relind=AVAILABLE&rellifecycle=ED&reltype=latest
1013
