Cisco 2504 Controller, 2602e LWAPP and 2602e Work GroupBridge Configuration
I have the below lab setup in my office.
1) I have one controller Cisco 2504.
2) I have one LWAPP which is controlling by above controller. 2602e LWAPP
3) I have one Workgroup Bridge (WGB) which is assoiciated wirelessley to the above LWAPP.
4) I have one Cisco 3560 switch where VLANs are configured and connected to Controller through trunk link.
The setup went sucessfully to assoicate the Workgroup Bridge to LWAPP AP. In contoller I am able to see WGB under clients in the controller.
Initially after setting up the above task i am able to ping the WGB ip from 3560 switch, controller and client laptop. Even from WGB also I am able to ping the controller Ip, switch VLAN ip and laptop IP.
But after that I just reset the WGB config and copied the same once again as there is a request from customer end. After copying the same config the WGB is able to associate with LWAPP AP. But either I am not able to ping the conrtoller IP, switch IP and laptop IP from WGB or from WGB the Switch IP, controller IP and laptop IP..
Below is the configuration used in WGB: Can anyone help me why this is not happening. Please let me know if you need further information.
Configuration:
WGB1#sh run
Building configuration...
Current configuration : 3740 bytes
! Last configuration change at 20:23:54 EST Sun Feb 28 1993
version 15.2
no service pad
hostname WGB1
logging rate-limit console 9
no aaa new-model
clock timezone EST -5 0
clock summer-time EST recurring 2 Sun Mar 2:00 2 Sun Nov 2:00
ip cef
dot11 syslog
dot11 ssid Testing
   vlan 10
   band-select
   authentication open
   guest-mode
dot11 network-map
crypto pki trustpoint TP-self-signed-1551819103
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1551819103
revocation-check none
rsakeypair TP-self-signed-1551819103
crypto pki certificate chain TP-self-signed-1551819103
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
   69666963 6174652D 31353531 38313931 3033301E 170D3933 30333031 30303035
  34335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35353138
  31393130 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D778 B4C95379 101F50B5 D1D9656F 72011A36 FA1D74EC 872A2642 5739DEBF
  4A90B7D6 1A40BE95 894B76B1 731CAA19 A29C2FDC C53C8A46 8CEE97A2 2A18A01C
  C3590556 EC33C295 6439FA67 8776FCFE 8CD620A4 1C798FED 60E68D74 6188321B
  8EA69AAC 08F5179C 6C961B24 5701CDDC 3AC7971D 6B7B5780 2F91F455 DC3FA143
  B2FF0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14B9E514 8532D420 AC715E37 DD9D82F1 D14D0541 62301D06
  03551D0E 04160414 B9E51485 32D420AC 715E37DD 9D82F1D1 4D054162 300D0609
  2A864886 F70D0101 05050003 81810027 71F0A8D4 201E5326 FF97FFD6 05664F9D
  360A29D7 65B80C26 58E1C646 AAEA07A6 B27FFB9E 89772E0C 28471E73 0C067A2E
  CE36708D 1C78A011 11BD07B0 10E5DA00 551421A4 FA680C4E 912933BD B6D66E12
  E8018E17 F9D19CFF 4B1D2BC5 60E24511 2B54C427 0C6884BE 75691A64 995FE3C6
  EB0DDC9A 7624AF9C 1369A6E8 FB5BC9
            quit
interface Dot11Radio0
no ip address
ssid Testing
antenna gain 0
stbc
power local -1
power client 22
station-role workgroup-bridge
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
bridge-group 10
interface Dot11Radio1
no ip address
ssid Testing
  antenna gain 0
dfs band 3 block
stbc
power local -1
power client 23
channel dfs
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1.10
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 spanning-disabled
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface GigabitEthernet0.10
bridge-group 10
interface GigabitEthernet0.20
encapsulation dot1Q 20
interface BVI1
ip address 10.10.10.3 255.255.255.0
ip default-gateway 10.10.10.5       ---------> Controller IP.
ip forward-protocol nd
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
line con 0
line vty 0 4
login
transport input all
workgroup-bridge client-vlan 10
end
Switch IP: 10.10.10.1
Laptop IP: 10.10.10.50
Controller IP: 10.10.10.5
DHCP Pool configured in Controller: 10.10.10.50 - 10.10.10.100.
Please reply this on prioirty.
Praveen
VIP Purple
Re: Cisco 2504 Controller, 2602e LWAPP and 2602e Work GroupBridg
What is the gateway address for vlan 10 ? Use that ip as the gateway for WGB and try.
Not related to your problem but this line:
should be this:
clock summer-time EDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
360
