Community Member
Cisco 2504 controller, missing Guest lan check box
In the Cisco Wireless Lan Controller Configuration Guide, Software Release 7.0.116.0 April 2011 guide, on Figure 3-8 has a Guest Lan check box.
I don't have that option when I try to create a new wlan.
How do I designate my wlan as a guest wlan?
Steve
Everyone's tags (3)
Thats a good question. I dont think the 2500 can do that feature.
Hall of Fame Super Silver
George is right... its is not available on the 2500.  You only use this for wired guest though,, is that what your trying to do?
-Scott
Community Member
I thought the check box was for the wireless guest, not the wired guest. ... my mistake
4192
