12-14-2011 08:51 AM - edited 07-03-2021 09:14 PM
I have setting the Management Interface Vlan Identifier to 0 or untagged.
If i change this to a vlan, I am unable to manage the device, is this correct?
Steve
Solved! Go to Solution.
12-14-2011 08:55 AM
If u make it untagged then specify the NATIVE vlan on the switchport..
If u tag the management interface, then dont configure the native vlan on the switchport..
Both the cases u will be able to access!!
Lemme know if this answered ur question!!
Surendra
12-14-2011 08:55 AM
Surendra
12-14-2011 09:02 PM
I will piggy back on Surendra's comment. Its best to TAG your interface. If you plan to do QoS you can trust CoS on the link and not have to worrk about the mangment traffic not being trusted w.o having to do a policy map.
12-15-2011 05:46 AM
Pointed to be noted George!
