07-22-2013 04:18 AM - edited 07-04-2021 12:28 AM
I have a cisco 2960 switch and 2504 WLC so i want to make a etherchannel bundle between these switch and controller.
I read some documents regarding this scenario but there was different informations; some of them had been told it is possible and some of them had been told it is impossible with 2504 series.
Is it possible to make a etherchannel?
If it is possible how can i do that?
my WLC image is 7.3
Charith
Solved! Go to Solution.
07-22-2013 05:51 AM
Indeed. 7.4 supports it .. Here is the release notes
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps10315/product_bulletin_c25-722724.html
07-22-2013 05:52 AM
Upgrade to 7.4. Under controller tab select LAG. On the switch side build an etherchannel .. Follow the config guide best practices .. Look up lag in 7.4 config guide
07-22-2013 11:19 AM
It can be confusing ..
7.2, 7.3 and 7.4 are different trains .. One has more features than the last .. Cisco will release maintenace updates for each train ..
07-22-2013 11:36 AM
sorry my mobile got cut off .. So the latest train and the train that supports LAG is 7.4. So whatever the hightest number is in the 7.4 folder is the lastest ..
make sense?
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
07-22-2013 11:40 AM
Haha... Its George's iOS 7:)
So the first version to support LAG was v7.4.100.0 and the other image available is the v7.4.100.60 which is the latest but is beta. So either one of the v7.4 will work.
07-22-2013 05:51 AM
07-22-2013 05:52 AM
07-22-2013 10:21 AM
Thanks for supporting the rating system. Stop back if you have any questions or issues when you do the LAG config.
07-22-2013 11:01 AM
Thank you George for your quick and correct reply.
07-22-2013 11:14 AM
George,
I am confusing with WLC software download.
because the lateset release is 7.2.115.2
7.4.100.60 have been released prior to the 7.2.115.2.
what is the latest one?
why old 7.2 versions are releasing yet ?
Charith
07-22-2013 11:19 AM
07-22-2013 11:36 AM
make sense?
07-22-2013 12:01 PM
ok. but why dose it conduct different trains? like 7.2, 7.3 and 7.4
what is the reason?
07-22-2013 12:08 PM
Features! Various trains are developed for specific WLC models, access points and features. The release notes will explain what devices are supported and what are the new features.
07-22-2013 12:21 PM
Cisco released a number of different trains. The difference between them is features. The 7.2 has been out longer than 7.3 and 7.4. Folks that dont want to be bleeding edge tend to stick with older releases. For example, Im still on 7.0 myself for most of my gear ..
07-22-2013 11:40 AM
07-22-2013 01:30 PM
Hello Charith,
As per your query i can suggest you the following solution-
WLC 7.4 version supports it.
Hope this will help you.
