Community Member
Cisco 2504 WLC and AirLAP1131AG-E-K9 not registering.
Hello, Is some one able to assist me.
We have a 2504 on version 7.2.103.0 and 15 of the 1131 AG's.
In short we cannot get the access points to register against the WLC, they seem to be caught up in a boot loop. They are seen on the WLC with a status of downloading, then once they have downloaded (Seen via CLI) I get an error message
I have searched and searched for a resolution with no sucesss.
Things I can confirm are
The Country code is set to GB
All ports are in Native VLAN
Access points are ETSI type.
It stops and restarts at syslog output
DTLS-3-BAD-RECORD: Erroneous record recieved from x.x.x.x: Duplicate (replayed) record.
Hall of Fame Super Gold
Can I ask if you could possible post the output to the following commands:
1.  WLC:  sh sysinfo
2.  WAP:  sh version
3.  WAP:  sh inventory
Lastly, please attach a console cable to the WAP and reboot the WAP.  I would like to ask if you are able to post the entire bootup process.
Community Member
Hi Leolaohoo,
Please see the information below.
WLC 2504 sysinfo.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.2.103.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_e3:9b:c4
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.1
Last Reset....................................... Software reset
System Up Time................................... 0 days 20 hrs 55 mins 42 secs
System Timezone Location......................... (GMT) London, Lisbon, Dublin, Edinburgh
Configured Country............................... GB  - United Kingdom
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +29 C
External Temperature............................. +32 C
Fan Status....................................... 3700 rpm
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ D0:C2:82:E3:9B:C0
Maximum number of APs supported.................. 15
LAP AP
APc464.1360.6f04#show ver
Cisco IOS Software, C1130 Software (C1130-K9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:07 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(8)JEA, RELEASE SOFTWARE (fc2)
APc464.1360.6f04 uptime is 1 minute
System image file is "flash:/c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision B0) with 27638K/5120K bytes of memory.
Processor board ID FCZ1609Q0MT
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.220.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C4:64:13:60:6F:04
Part Number                          : 73-13303-02
PCA Assembly Number                  : 800-36180-01
PCA Revision Number                  : B0
PCB Serial Number                    : FOC16054KH5
Top Assembly Part Number             : 800-29144-04
Top Assembly Serial Number           : FCZ1609Q0MT
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1131AG-E-K9
Configuration register is 0xF
show inv
NAME: "AP1130", DESCR: "Cisco Aironet 1130 Series (IEEE 802.11a/g) Access Point"
PID: AIR-LAP1131AG-E-K9, VID: V06, SN: FCZ1609Q0MT
bootup of wap
Xmodem file system is available.
flashfs[0]: 27 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 7024128
flashfs[0]: Bytes available: 8974848
flashfs[0]: flashfs fsck took 30 seconds.
Base ethernet MAC Address: c4:64:13:60:6f:04
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3"...######################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 27 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15740928
flashfs[1]: Bytes used: 7024128
flashfs[1]: Bytes available: 8716800
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Radio1  present A506 6700 E8000100 A0040000 80010000 2
export@cisco.com.
2 802.11 Radio(s)
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:05.705: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:07.314: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:08.899: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:08.999: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:09.028:  status of voice_diag_test from WLC is false
*Mar  1 00:00:11.137: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:11.196: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:11.196: %SNMP-5-COLDSTART: SNMP agent on host APc464.1360.6f04 is undergoing a cold start
*Mar  1 04:26:55.071: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 04:26:55.249: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 04:26:55.249: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 04:26:55.249: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 04:26:55.488: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 04:26:55.488: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 04:26:55.762: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 04:26:55.934: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 04:26:56.195: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 04:26:56.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 04:26:56.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 04:26:56.611: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 04:26:57.610: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 04:27:05.373: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 192.168.1.127, mask 255.255.255.0, hostname APc464.1360.6f04
*Mar  1 04:27:13.928:  status of voice_diag_test from WLC is false
*Mar  1 04:27:13.998: Logging LWAPP message to 255.255.255.255.
Translating "CISCO-CAPWAP-CONTROLLER.inflite.co.uk"...domain server (192.168.1.254)
Translating "CISCO-LWAPP-CONTROLLER.inflite.co.uk"...domain server (192.168.1.254)
*Mar  1 04:27:25.050: %CAPWAP-5-DHCP_OPTION_43: Controller address 192.168.1.1 obtained through DHCP
examining image...
extracting info (292 bytes)
Image info:
    Version Suffix: k9w8-.124-23c.JA3
    Image Name: c1130-k9w8-mx.124-23c.JA3
    Version Directory: c1130-k9w8-mx.124-23c.JA3
    Ios Image Size: 4905472
    Total Image Size: 5069312
    Image Feature: WIRELESS LAN|LWAPP
    Image Family: C1130
    Wireless Switch Management Version: 7.0.220.0
Extracting files...
c1130-k9w8-mx.124-23c.JA3/ (directory) 0 (bytes)
c1130-k9w8-mx.124-23c.JA3/html/ (directory) 0 (bytes)
c1130-k9w8-m
*May 22 07:38:54.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.1 peer_port: 5246
*May 22 07:38:54.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 22 07:38:55.430: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.1 peer_port: 5246
*May 22 07:38:55.431: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.1
*May 22 07:38:55.431: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIx.124-23c.JA3/html/level/ (directory) 0 (bytes)
c1130-k9w8-mx.124-23c.JA3/html/level/1/ (directory) 0 (bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/forms.js (17486 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/sitewide.js (16548 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/officeExtendap.css (41795 bytes)Nperform archive download capwap:/c1130 tar file
*May 22 07:38:55.451: %CAPWAP-5-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*May 22 07:38:55.455: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/appsui.js (557 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/config.js (24633 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/ap_home.shtml.gz (1300 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/back.shtml (506 bytes)
c1130-k9w8-mx.124-23c.JA3/html/level/1/images/ (directory) 0 (bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/images/cisco-logo-2007.gif (1648 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/images/background_web41.jpg (732 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/images/login_homeap.gif (19671 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/1/images/info.gif (399 bytes)
c1130-k9w8-mx.124-23c.JA3/html/level/15/ (directory) 0 (bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/15/officeExtendapBanner.htm (7108 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/15/officeExtendapHelp.htm (5007 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/15/officeExtendapEvent.shtml.gz (983 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/15/officeExtendapConfig.shtml.gz (2861 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/15/officeExtendapMain.shtml.gz (3361 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/html/level/15/officeExtendapSummary.htm (712 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3 (4638152 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/7101.img (131328 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/6701.img (131328 bytes)
extracting c1130-k9w8-mx.124-23c.JA3/info (292 bytes)
extracting info.ver (292 bytes)
Deleting target version: flash:/c1130-k9w8-mx.124-23c.JA3...done.
New software image installed in flash:/c1130-k9w8-mx.124-23c.JA3
Configuring system to use new image...done.
archive downloa
Writing out the event log to nvram...
d: takes 78 seconds
*May 22 07:40:13.171: %DTLS-3-BAD_RECORD: Erroneous record received from 192.168.1.1: Duplicate (replayed) record
*May 22 07:40:13.913: image upgrade successfully, system is now reloading
*May 22 07:40:13.958: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*May 22 07:40:13.962: %SYS-5-RELOAD: Reload requested by capwap image download proc. Reload Reason: NEW IMAGE DOWNLOAD.
*May 22 07:40:13.962: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
Ok, the output looks good, however, the output of the entire bootup process of the WAP stops after the WAP receives the IOS from the WLC.  What happens after that?
Community Member
After that it reboots and starts all over again.
Ok, so the WAP reboots and downloads the same IOS?
Right, console into the WAP and delete this subdirectory using the command "delete /f /r flash:c1130-k9w8-mx.124-23c.JA3"
Make sure you have a file/directory with the prefix "rcv".  If you are not sure, please post the output to the command "dir".
If you have this file/subdirectory, enter the command "clear capwap ap private" and then reboot the WAP.
Community Member
Here is the contents of the WAPs flash;
  2  -rwx       93858  May 22 2012 09:28:40 +00:00  event.log
    3  -rwx           0   Mar 1 2012 04:28:32 +00:00  config.txt
    4  drwx         128   Jan 1 1970 00:02:24 +00:00  c1130-rcvk9w8-mx
    7  -rwx        5144   Mar 1 2012 04:28:31 +00:00  private-multiple-fs
    9  -rwx         269   Mar 1 2002 00:00:06 +00:00  env_vars
   37  drwx         320  May 22 2012 09:28:36 +00:00  c1130-k9w8-mx.124-23c.JA3
Is this the file you have mentioned?
I will run through the rest now and capture the results.
c1130-rcvk9w8-mx
You need to KEEP whatever is in this directory.  Do a "dir flash:c1130-rcvk9w8-mx".  If there is a BIN file in there then it's good.
Recommend you delete this using the command "delete /f /r flash:c1130-k9w8-mx.124-23c.JA3".
Then enter the command "clear capwap ap private" and then reboot the WAP.
Community Member
here is a log of a few reboots from the device after your advice.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.05.22 10:35:59 =~=~=~=~=~=~=~=~=~=~=~=
AP2894.0f74.8e38>en
Password:
AP2894.0f74.8e38#relo
*Mar  1 00:00:20.757: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to upad
Proceed with reload? [confirm]
*Mar  1 00:00:23.769: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload command.
*Mar  1 00:00:23.769: %LWAPP-5-CHANGED: LWAPP changed state to DOWN
*Mar  1 00:00:24.771: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERYXmodem file system is available.
flashfs[0]: 6 files, 2 directories
flashfs[0]: Bytes used: 1970176
flashfs[0]: Bytes available: 14028800
flashfs[0]: flashfs fsck took 23 seconds.
Base ethernet MAC Address: 28:94:0f:74:8e:38
Reset done!
Loading "flash:/c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3"...flash:/c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3: no such file or directory
Error loading "flash:/c1130-k9w8-mx.124-23c.JA3/c1130-k9w8-mx.124-23c.JA3"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx"...#########################################################################################################################################################################
File "flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx" uncompressed and installed, entry point: 0x3000
executing...
           cisco Systems, Inc.
Cisco IOS Software, C1130 Software (C1130-RCVK9W8-M), Version 12.3(11)JX1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 17-Jul-06 11:38 by alnguyen
Image text-base: 0x00003000, data-base: 0x0035E440
flashfs[1]: 6 files, 2 directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 1970176
flashfs[1]: Bytes available: 14028800
flashfs[1]: flashfs fsck took 3 seconds.
cisco AIR-LAP1131AG-E-K9   (PowerPCElvis) processor (revision B0) with 24566K/8192K bytes of memory.
Processor board ID FCZ1609Q0N2
Last reset from reload
LWAPP image version 3.0.51.0
Base ethernet MAC Address: 28:94:0F:74:8E:38
PCB Serial Number                    : FOC16052JL4
Top Assembly Serial Number           : FCZ1609Q0N2
*Mar  1 00:00:05.740: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 00:00:05.747: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:06.680: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:07.680: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:24.755: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar  1 00:00:34.891: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 192.168.1.157, mask 255.255.255.0, hostname AP2894.0f74.8e38
*Mar  1 00:00:36.165: LWAPP_CLIENT_ERROR: lwapp_name_lookup - Could Not resolve CISCO-LWAPP-CONTROLLER.inflite.co.uk
examining image...
Image info:
    Image Family: C1130
Extracting files...
c1130-k9w8-mx.
*Mar  1 00:00:46.174: %LWAPP-5-CHANGED: LWAPP changed state to JOIN
*May 22 09:36:01.154: %LWAPP-5-CHANGED: LWAPP changed state to IMAGE124-23c.JA3/html/level/ (directory) 0 (bytes)
Configuring system to use new image...done.archive download: takes 74 seconds
*May 22 09:37:15.516: image upgrade successfully, system is now reloading
*May 22 09:37:15.551: %SYS-5-RELOAD: Reload requested by lwapp image download proc. Reload Reason: NEW IMAGE DOWNLOAD.
*May 22 09:37:15.551: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file system is available.
flashfs[0]: Bytes used: 7023616
flashfs[0]: Bytes available: 8975360
flashfs[0]: flashfs fsck took 33 seconds.
Reset done!
executing...
           cisco Systems, Inc.
flashfs[1]: Bytes used: 7023616
flashfs[1]: Bytes available: 8717312
flashfs[1]: flashfs fsck took 5 seconds.
export@cisco.com.
2 802.11 Radio(s)
*Mar  1 00:00:06.888: soap_prepare_new_image_crash: mini ios flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx
*Mar  1 00:00:06.890:  set boothlpr to mini ios
*Mar  1 00:00:07.238: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:08.653: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:10.046: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:10.145: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:10.174:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.284: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:12.342: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:12.343: %SNMP-5-COLDSTART: SNMP agent on host AP2894.0f74.8e38 is undergoing a cold start
*Mar  1 04:28:13.069: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 04:28:13.251: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 04:28:13.251: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 04:28:13.252: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 04:28:13.491: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 04:28:13.491: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 04:28:13.759: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 04:28:13.936: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 04:28:14.215: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 04:28:14.251: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 04:28:14.263: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 04:28:14.653: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 04:28:15.653: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 04:28:23.375: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 192.168.1.158, mask 255.255.255.0, hostname AP2894.0f74.8e38
*Mar  1 04:28:31.927:  status of voice_diag_test from WLC is false
*Mar  1 04:28:31.998: Logging LWAPP message to 255.255.255.255.
*Mar  1 04:28:43.053: %CAPWAP-5-DHCP_OPTION_43: Controller address 192.168.1.1 obtained through DHCP
examining image...
Image info:
    Image Family: C1130
Extracting files...
c1130-k9w8-m
*May 22 09:40:14.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.1 peer_port: 5246
*May 22 09:40:14.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 22 09:40:15.424: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.1 peer_port: 5246
*May 22 09:40:15.425: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.1
*May 22 09:40:15.425: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIx.124-23c.JA3/html/level/ (directory) 0 (bytes)
*May 22 09:40:15.445: %CAPWAP-5-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*May 22 09:40:15.449: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
archive downloa
d: takes 78 seconds
*May 22 09:41:32.816: %DTLS-3-BAD_RECORD: Erroneous record received from 192.168.1.1: Duplicate (replayed) record
*May 22 09:41:33.552: image upgrade successfully, system is now reloading
*May 22 09:41:33.599: %SYS-5-RELOAD: Reload requested by capwap image download proc. Reload Reason: NEW IMAGE DOWNLOAD.
*May 22 09:41:33.599: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
*May 22 09:41:33.804: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiatedXmodem file system is available.
Reset done!
executing...
           cisco Systems, Inc.
export@cisco.com.
2 802.11 Radio(s)
*Mar  1 00:00:06.840: soap_prepare_new_image_crash: mini ios flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx
*Mar  1 00:00:06.842:  set boothlpr to mini ios
*Mar  1 00:00:07.191: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:08.606: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.999: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:10.098: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:10.128:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.237: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:12.295: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:12.296: %SNMP-5-COLDSTART: SNMP agent on host AP2894.0f74.8e38 is undergoing a cold start
*Mar  1 04:28:13.246: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 04:28:13.247: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 04:28:13.247: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 04:28:13.486: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 04:28:13.486: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 04:28:13.761: %CDP_PD-4-POWER_OK: Full power - AC_ADAPTOR inline power source
*Mar  1 04:28:13.937: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 04:28:14.218: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 04:28:14.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 04:28:14.256: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 04:28:23.370: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 192.168.1.159, mask 255.255.255.0, hostname AP2894.0f74.8e38
*Mar  1 04:28:31.926:  status of voice_diag_test from WLC is false
*Mar  1 04:28:43.052: %CAPWAP-5-DHCP_OPTION_43: Controller address 192.168.1.1 obtained through DHCP
examining image...
Image info:
    Image Family: C1130
Extracting files...
c1130-k9w8-m
*May 22 09:43:46.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.1 peer_port: 5246
*May 22 09:43:46.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*May 22 09:43:47.431: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.1 peer_port: 5246
*May 22 09:43:47.432: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.1
*May 22 09:43:47.432: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIx.124-23c.JA3/html/level/ (directory) 0 (bytes)
*May 22 09:43:47.452: %CAPWAP-5-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller.
*May 22 09:43:47.457: %CAPWAP-5-CHANGED: CAPWAP changed state to IMAGE
Wierd.  Is this affecting ALL your 1130?
Community Member
we have tried 3 of the 15 with the same results.
Hmmm ... There's one thing left to do ...
1.  Convert the WAPs to autonomous IOS.
2.  Once in autonomous, convert back to CAPWAP, this time use the file "c1130-rcvk9w8-tar.124-21a.JA2.tar".
Hall of Fame Super Silver
Re: Cisco 2504 WLC and AirLAP1131AG-E-K9 not registering.
Have you tried uploading the code in the wlc again. If this is a new setup, I would upload the firmware on the wlc and see if that fixes it, unless you do have a few that worked.
Scott Fella
Sent from my iPhone
-Scott
Hey Scott,
I need to ask because I have not been exposed to the 7.2.X code yet but look at the output of the "sh sysinfo" and look at the bootstrap of the WLC.  I don't believe it's been upgraded.  Would this be causing the issue?
Hey Leo... the 7.2 is weird:)... this is the output from a 2504 that I have 7.2.103.0 loaded on:
(WLC2504) >show sysinfo
System Name...................................... WLC2504
IP Address....................................... 192.168.201.25
System Up Time................................... 20 days 7 hrs 15 mins 39 secs
System Timezone Location......................... (GMT -6:00) Central Time (US and Canada)
Configured Country............................... US  - United States
-Scott
Ok.  That theory is shot down to pieces.
That was the first thing I thought also when I saw the bootloader on the 2504.  The 5508 you need to install the FUS image and it takes around 30 minutes sitting front of the console and entering "y" for each upgrade.
-Scott
I would maybe delete these files also.  I ran into some 3500's that I needed to delete these and then use the capwap ap controller ip address command from the console to get the ap to join.
-Scott
Community Member
I tried deleting said files.
I will need to involve our supplier as our smartnet is not active as new kit therefore unable to get the software needed.
Thanks for you help. I update you when I have more.
Bronze
The problem could be that the WLC is not set to the correct country code, try to set a diffetent country to the WLC, reboot, then set it back to GB and reboot the WLC.
Check if the APs are able to join the WLC.
The error message "%DTLS-3-BAD_RECORD: Erroneous record received from
x.x.x.x:Duplicate (replayed) record" appears to relate to a duplicate record
being received by the AP.
If the access points are not on the same subnet as the WLC subnet the issue could be a layer 3
problem or latency issue on the network.
If the issue continues try to open a case with TAC.
WLC country code is set for GB and the WAP is "E" regulatory domain.
Check your links between the WLC and the APs. Make sure you don't have a half duplex link in the path.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
All in all we have had a nightmare few days. The reseller we purchased the kit from cannot get Support from Cisco (I am wondering how they have purchased this kit and who from)
We have a device on its way to us today which is covered by smartnet and should we have the same issue hopefully be ablw to raise with TAC, This will be our 3rd controller 2 of which have the same symtoms.
They both have the same software build, and both units fail to upgrade to the latest build, they say their is an issue saving to flash. I am not to sure how the storage works on these devices but am wondering if there is a flash issue or memory issue which is corrupting the image that is sent to the access points.
I have already checked the Regional settings, I have also ruled this out by enabling 20 Countries at a time.
Also duplex and speed has been checked through out the pre-staging equipment.
Intefaces are all at 100Mbps/Full or 1000Mbps/Full, no CRC errors are generating so I believe the network topology to be ok.
I will update later when we have a TAC cased raised.
You are right to raise a TAC case in this. The behavior match a bug that we had in 7.0 firmware where we ran out if room on the WLC when installing the AP firmwares on the WLC. This bug is the reason why your "show run-config" now outputs the name and size of every AP firmware in the primary and backup image of the WLC. I don't have my PC handy right now to get the exact bug for you but make sure your TAC engineer is thinking along those lines. This bug was fixed in 7.0.220.0 but they will need to verify that the fix was commuted to the 7.2 line as well
-Eric
Bronze
Since the WLC has code 7.2.103.0 and there is code 7.2.110.0  if you have access to downalod software from the Cisco.com website and it is okay for you you could try to upgrade the code and see if the issue continues or not.
But still the best option is to open a TAC case.
Community Member
I have a similar problem, I was finally able to get mine to join by adding the mac address of the AP to the AP policies access list. I did not have to change any other options or check any of the additionnal policy config check boxes.
Community Member
Once they rejoined I noticed they came up in Bridge mode, changed them back to local and was able to remove them from the list!
3355
