Cisco 2602 could not join the Wireless controller.
karinn001
I have 2602 AP and i rebooted after rebooting i could not joining the controller (2502) and getting the following logs. Kindly suggests me any solution. Moreover after rebooting AP showed the admin "status disable" and clean air status is "down". I manually enable both these options after that Cisco  Prime and controller showing no error but both the radio channel could not on or no signal is broadcast.
*Mar  1 00:00:11.615: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:11.619: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar  1 00:00:15.123: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:18.795: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:25.171: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:27.827: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.2(2)JB3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 04:30 by prod_rel_team
*Mar  1 00:00:27.827: %SNMP-5-COLDSTART: SNMP agent on host APf8c2.8838.9850 is undergoing a cold start
*Mar  1 00:00:27.883: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:27.883: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:28.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:28.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:28.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:28.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:31.295: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed
*Mar  1 00:00:31.295: DPAA Initialization Complete
*Mar  1 00:00:31.295: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:32.295: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:36.891: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:00:36.891: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:37.043: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:56.635: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:59.135: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:01:00.227: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:01.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:01:01.319: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:02.319: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:02:56.639: %CAPWAP-3-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP.
*Mar  1 00:03:04.663: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:03:04.671: %IP-4-DUPADDR: Duplicate address 10.0.10.63 on BVI1, sourced by 4c4e.353d.85b0
*Mar  1 00:03:04.715: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.0.10.63, mask 255.255.255.0, hostname APf8c2.8838.9850
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:03:06.643: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:03:15.643: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:03:25.643: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug 31 12:26:40.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.0.10.52 peer_port: 5246
*Aug 31 12:26:40.479: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.0.10.52 peer_port: 5246
*Aug 31 12:26:40.479: %CAPWAP-5-SENDJOIN: sending Join Request to 10.0.10.52
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Aug 31 12:26:40.499: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.0.10.52
*Aug 31 12:26:40.923: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Aug 31 12:26:40.995: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Aug 31 12:26:41.059: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller PK-KARAC-WLC1
*Aug 31 12:26:41.343: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Aug 31 12:26:41.923: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Aug 31 12:26:41.995: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
Hi Karinn,
1. Are your laptop in 192.168.1.0 subnet ?
2. Put this vlan in 0 . VLAN............................................. untagged(It must be 0)
via CLI:
config interface vlan management 0
change this and try again.
Dont forget to rate helpful posts
15 Replies 15
Sandeep Choudhary
1.IN outdoor maximum 300 feet(Max), check table 20  for more info: http://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/7-0MR1/design/guide/MeshAP_70MR1.html#wp1149153
2. Yes they will work as mesh with 2504 WLC but make sure WLC.
3. Yes they have Ethernet port to connect with Switch.
Thanks for reply sandeep.
I need to confirm one more thing that WLC 2504 can support mesh and local network simultaneously(means some access points are working are connected with LAN cables and some are on mesh mode).
Hi Karinn,
Yes, you can use AP's in local & mesh network simultaneously.
Hi Sandeep,
I have cisco 2504 controller with the IOS(software ver) 7.4.121.0 and i am using 2602E-C-K9 my objective is to make a mesh network by using these access points.I am not getting any option in the controller or in access points kindly clearly either controller or access points can support the mesh or i am doing wrong configuration. Kindly help me
On the same page as you paste the screenshot, you can see AP mode option.
select to use this AP as Bridge Mode.
sandeep,
1)  Is it possible  to make two roort AP by using one controller( like port port 1 serve as a mesh network 1 and port 2 vise versa. I just need to design two mesh network controlled by single WLC.
2) If we design these two mesh network the bandwidth would be divide? means controller bandwidth (throughput).
Hi Karin,
1. yes you can have 2 root AP on same controller.
2. I have never tried but if you have more and more MAP then it reduced throughput by half over every hop.
Check the configuration guide:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-0/configuration/guide/c70/c70mesh.html
Design and deployment guide:
Hi sandep,
do you have any experience that cisco 1552 wireless access point can penetrate the signals into the "PORTACABIN" (Pls see the attachment). I am going to implement a wireless project on our field. Your kind help highly be appreciated.
Hi Sandeep,
Hope you are well. please confirm that WLC AIR-CT2504-25-K9 with the software version 7.4.121.0 can support the 1552H-M-K9 access points.
Hi Karin,
Yes it will support.
See the comaptibility matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Hi Sandeep,
I am using WLC 2504 and not able to getting the GUI interface. Kindly help me
Interface Name................................... management
MAC Address...................................... 50:06:04:ca:85:40
IP Address....................................... 192.168.1.1
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.1.2
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 192.168.1.100
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Disabled
Hi Karinn,
via CLI:
karinn001
Sandeep,
Thanks allot its working
Sandeep,
Now i making a mesh network by using AIR-CAP2602E-C-K9 with the same WLC 2504. Kindly tel me what are the major changes can be done on WLC by using GUI.
