Cisco 3850 Fast SSID
Roger Alderman
Level 3
Level 3
Hi all
Can anyone confirm that the fast SSID change feature on a Cisco 3850 actually works?
I have set wireless client fast-SSID-change as a global command.
If the client tries to switch between SSIDs he is still being cached on the 3850 and can't connect to the second SSID until he has disappeared from the cache.
Roger
16 Replies 16
Yeah who knows... With it enabled my clients can switch:)
-Scott
Scott,
If you're not sending your authentication/authorization to an external RADIUS server, then it'll work fine.  It's when the WLC has to send the RADIUS attributes to a RADIUS server that you see the issue.
