11-23-2011 12:13 PM - edited 07-03-2021 09:07 PM
We are trying to allow LWAP to access INSIDE LAN via access switches then using Option43 point them to 5508 which are only connected to DMZ switch. The LAP cannot find WLC server still... not sure our design will work.
I cannot find good documentation for doing this with a 5508
Our intent is that all wireless can only reside in the DMZ but the AP will be sitting on INSIDE LAN
I have attached PDF with 2 network designs..both are the same but the second is better detailed
here is the error I ma getting on the AP
Translating "CISCO-CAPWAP-CONTROLLER.langleyfcu.org"...domain server (10.248.55.25)
*Mar 1 05:21:35.716: %CAPWAP-5-DHCP_OPTION_43: Controller address 49.57.50.46 obtained through DHCP
*Mar 1 05:21:35.716: %CAPWAP-5-DHCP_OPTION_43: Controller address 49.54.56.46 obtained through DHCP
*Mar 1 05:21:35.716: %CAPWAP-5-DHCP_OPTION_43: Controller address 53.49.46.50 obtained through DHCP
*Mar 1 05:22:15.717: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar 1 05:22:25.875: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.248.23.29, mask 255.255.255.0, hostname AP70ca.9b99.4859
*Mar 1 05:22:32.219: %CAPWAP-5-DHCP_OPTION_43: Controller address 49.57.50.46 obtained through DHCP
*Mar 1 05:22:32.219: %CAPWAP-5-DHCP_OPTION_43: Controller address 49.54.56.46 obtained through DHCP
*Mar 1 05:22:32.219: %CAPWAP-5-DHCP_OPTION_43: Controller address 53.49.46.50 obtained through DHCP
*Mar 1 05:23:12.221: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar 1 05:23:22.756: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.248.23.29, mask 255.255.255.0, hostname AP70ca.9b99.4859
11-23-2011 01:07 PM
Well you need to allow udp 5246 from the AP's to the WLC and vice versa. Why not have an interface connect to your internal network also and then put users on the dmz? This way your wlc and AP's can communicate.
Sent from my iPhone
