Cisco 5760 Client Connectivity Questions
We have a network which is routed completely.
We have cisco 6500 switches and we have cisco 5760 WLC.
We have a situation where in the wireless user vlan is on the WLC (i.e vlan 5 for floor 5 , vlan 6 for floor 6) and we have the ssid's mapped to them.
The Problem is the link between the core and the wireless controller is a trunk port without vlans tagged on it
The config looks like
interface tengig 1/0/5
switchport
switchport mode trunk
So its basically vlan 1 passing across and i am able to reach mgmt ip address from core to WLC and Vice versa.
Will the client traffic be routed if we dont have them defined on the trunk port and if the gateway for the wireless clients are on the wlc
Do we need to the vlans tagged on the core and the WLC to make them work ?
VIP Purple
Re: Cisco 5760 Client Connectivity Questions
HI Sripathy,
Configure like this and try:
Controllers typically map WLANs to VLANs. When configuring a switch port to a controller, you would set the port to support
802.1Q ( switchport trunk encapsulation dot1q ), then set the port to trunk ( switchport mode trunk ) and only allow the VLANs
needed by the controller.
The switch port is configured as an IEEE 802.1Q trunk and only the appropriate VLANs
This is an example 802.1Q switch port configuration:
interface GigabitEthernet1/0/1
description Trunk Port to Cisco WLC
switchport trunk allowed vlan 1,2,3
no shutdown
Dont forget to rate helpful posts.
You must allow vlan 5 and 6 as well for the data traffic to pass.
switchport trunk allowed vlan 1,5,6
Hall of Fame Super Gold
Maybe it's me, but this statement is confusing.
Are you saying that you've segmented SSIDs based on your floor?  If this is the case, I have no idea what you are trying to achieve but it won't work.
The wireless client decides what APs to join (and what SSID to join).  If a wireless client has all the SSIDs configured in it's system, you will not be guaranteed that the wireless client on floor 5 will join the SSID for floor 5.  Instead, you just might see the client either join an SSID in floor 4 or 6.
228
