Cisco 801 ISDN Router Problem
Hi at all,
I need your experience with this device! I will implement a remote connection to a customer.
Following constellation:
My PC --> Our ISDN NTBA --> provider --> Phone System customer --> S0 --> ISDN 801 Router --> End Device
My problem is when I call the phone number with my mobile phone the call takes place, the router brings up the channel and hold this for a few seconds.
The he kick me out than he can´t speak with my end device.
When I do this with my remote pc nothing happens only this.
He hangs up and I must restart this application to do the next attempt. How can I fix this problem?
The debug isdn q931 shows this:
00:34:24: ISDN BR0 Q931: RX <- SETUP pd = 8  callref = 0x01
Sending Complete
Bearer Capability i = 0x8890
  Standard = CCITT
  Transer Capability = Unrestricted Digital
  Transfer Mode = Circuit
  Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Calling Party Number i = 0x0083, 'xxxxxxx'
  Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '69'
00:34:24: %DIALER-6-BIND: Interface BR0:2 bound to profile Di1
00:34:103079215104: %LINK-3-UPDOWN: Interface BRI0:2, changed state to up
00:34:24: ISDN BR0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
Channel ID i = 0x8A
00:34:24: ISDN BR0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x01
Channel ID i = 0x8A
00:34:24: ISDN BR0 Q931: TX -> ALERTING pd = 8  callref = 0x81
00:34:24: ISDN BR0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x01
Cause i = 0x85D1 - Invalid call reference value
00:34:24: ISDN BR0 Q931: TX -> CONNECT pd = 8  callref = 0x81
00:34:24: %ISDN-6-CONNECT: Interface BRI0:2 is now connected to xxxxxxxx
00:34:24: %LINK-3-UPDOWN: Interface BRI0:2, changed state to down
00:34:24: %DIALER-6-UNBIND: Interface BR0:2 unbound from profile Di1
00:34:24: ISDN BR0 Q931: L3_Go: L3_GetUser_NLCB returned NULL cid 0x0 cr 0x81 ev 0x5A ces 1 -- Message ignored
00:34:27: ISDN BR0 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
Cause i = 0x8090 - Normal call clearing
Facility i = 0x91A11302029372020122300AA1053003020100820101
- ETSI Supplementary Service, Invoke, AOC-D Charging Units: 0
00:34:27: ISDN BR0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x01
And this is my configuration on the Cisco 801 ISDN Router:
sh run
Building configuration...
Current configuration : 1539 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname customer
boot-start-marker
boot system flash c800-y6-mw.123-3i.bin
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $1$4sbt$qMDQoozleDqJstTzC2P8I1
username admin password 7 01000505571F0303
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa session-id common
ip subnet-zero
no ip domain lookup
isdn switch-type basic-net3
interface Ethernet0
description connection
ip address 192.168.1.254 255.255.255.0
no keepalive
interface BRI0
description connected to Dial-inPC (ISDN)
no ip address
encapsulation ppp
dialer pool-member 1
isdn incoming-voice data
isdn answer1 12
isdn send-alerting
isdn sending-complete
isdn static-tei 0
interface Dialer0
ip unnumbered Ethernet0
encapsulation ppp
no ip split-horizon
dialer pool 1
peer default ip address pool test
no cdp enable
ppp authentication chap
ppp multilink
router rip
version 2
network 192.168.1.0
no auto-summary
ip local pool test 192.168.1.10 192.168.1.11
ip classless
no ip http server
dialer-list 1 protocol ip permit
line con 0
exec-timeout 0 0
transport preferred all
transport output all
stopbits 1
line vty 0 4
transport input all
no rcapi server
end
I hope anyone have or had this constellation too with a solution that works.
Many Thanks in advance,
Mario
1 REPLY
Hi at all,
We found a solution for this Problem !!
We always and always got this error:
%PQUICC-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
The problem was the cable! The following pin-out is required:
                                        1 ----- 1
                                        2 ----- 2
                                        3 ----- 6
                                        4 ----- 5
                                        5 ----- 4
                                        6 ----- 3
                                        7 ----- 7
                                        8 ----- 8
We used this and the fault has disappeared!!
The only problem that still exists:
After the first connection the router must be rebooted because otherwise no more additional session is established.
Thanks for all answers.
Mario
294
