Cisco 871 Wireless VPN router
Hi all,
          I have this 871 router that I am configuring for VPN access and Wireless access. The VPN part is already done and works fine; however, the wireless part is giving me some headhache.
First I cannot have access to the web interface even I set an IP address to bvi1. When I issue a show ip int brief, the output shows that the dot1radio 0 is up/up, but the virtual dot1radio is down/down. As I am a wireless guru, I don't really know what may explain this.
Any help will appreciate,
Thank,
1 REPLY
Re: Cisco 871 Wireless VPN router
Any ideas Pros? I really need help with that. Once again, the ssid is set via the cli. Show ip int brief shows that the dot1Radio0 interface and bvi1 are up/up, but the unit does not broadcast the ssid. I cannot get to the browser, usually I use the brower to set up the cisco wireless  devices.
905
