Cisco 876w router,wireless connection problem!
I cant connect wirelles to the 876w router.
I use to test the connection, a laptop with a wireless connection card:Intel(R)PROSet/Wireless 2200BG.
My configuration for the radio interface:
interface Dot11Radio0
no ip address
ssid matrix
vlan 1
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
no preamble-short
station-role root
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
Now the wireless network is found from my laptop's wireless card using 802.11/g
in channel 2.
However it writes that the SSID didnt transmit and i cant connect.
Any ideas what might be wrong?
I d appreciate if someone with the same router would give me his configuration if he has his wireless connection established to check if it ll work with mine.
p.s It isnt my wirelless card problem as i have tested it with other wireless cards and have the same problem.
Thans in advance of any help i could get
1 REPLY
Re: Cisco 876w router,wireless connection problem!
Forget it.
I just typed no vlan 1 at the ssid and i connected!!!
oh well step by step ill find the way.
Im just sorry i opened a discussion which is very similar to another below.So ill continue the wireless setup progress from there trying helping the guy ,too.
149
