Cisco 877W - SSID blank
Hello from Greece.
I have Configure my router like this.
interface Dot11Radio0
no ip address
encryption vlan 3 mode ciphers aes-ccm
broadcast-key vlan 3 change 1800 membership-termination capability-change
ssid ServiceGroup
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
infrastructure-client
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 3 native
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Vlan1
ip address 192.168.2.111 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
no ip address
bridge-group 2
interface Vlan3
no ip address
bridge-group 3
i
interface BVI2
ip address 192.168.0.50 255.255.255.0
interface BVI1
ip address 192.168.10.111 255.255.255.0
interface BVI3
ip address 192.168.250.111 255.255.255.0
ip nat inside
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 3 protocol ieee
bridge 3 route ip
my Problem is that on my laptop i can see my SSID but on my desktop i can only see this
Why is that.
Sorry For my english.Thanks
1 ACCEPTED SOLUTION
Gold
Re: Cisco 877W - SSID blank
The config you posted doesn't show the dot11 ssid.... section, but I'll assume you don't have guest-mode configured under it.  Guest-mode is what tells the AP to broadcast the SSID.  You should be able to connect to the SSID even with it hidden like that as long as the WLAN profile on your supplicant is configured correctly.
Gold
I have Added guest-mode under dot11 ssid ServiceGroup session and everything seems OK.
Thank you very much.
1344
