Community Member
Cisco 881 can't get Wireless working
Hi all,
I just bought a 881w and its working fine except the wireless-part. Some strange things are happening:
1) Router is configured and working, I can browse the internet without any problems;
2) When I log in to the CCP, I can click on the 'Wireless' option, and after typing my credentials I can see the tabs 'Basic Configuration' and 'Network Configuration';
3) I assigned a static IP to the wireless-accesspoint (https://172.16.74.200);
4) When I click on the button 'Launch Wireless Application' (which just opens a browser to 'https://172.16.74.200'), I get a webpage with just one button in it (see attached screenshot). When I click the button, InternetExplorer gives a JavaScript-error. When I look at the page-source, I can see where it goes wrong: the JS-function below uses the value of a field, and expects certain values.But the field contains a Cisco-error-message... Strange right?
5) When I add a network on the tab 'Network Configuration', my PC does see a network, but it's SSID is not visible (SSID Broadcast = yes, see screenshots attached).
Can anyone help me? I think I ran out of options...
Thx!
Regards Casper.
Snippet 1:
function chkmode () {
    var form = document.forms[0];
    if(isBlank(form.officeExtendConfig.value)) {
        return
    var config = grep_string(/ApMode /, form.officeExtendConfig.value);
    if(config.indexOf("Remote") != -1) {
        window.location.href='officeExtendapSummary.htm'
    } else {
        alert("The AP is not in Remote mode.");
        return
Snippet2:
<input type="hidden" name="officeExtendConfig" value="
show capwap client rcb
% Invalid input detected at '^' marker.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Cisco 881 can't get Wireless working
Hi Casper,
We are hitting the software bug.. the below link will help you out in resolving..
https://supportforums.cisco.com/docs/DOC-13047
please follow the instructions and then try accessing the GUI and configure the wireless AP.
Let me know how this works out for you!!
Surendra
Hi Casper,
Surendra
Community Member
Thx Surendra, works now!
Strange stuff from Cisco. Buggy and all, but when it works it's unbeatable. Don't know why, but I still have a good feeling about Cisco products, wouldn't buy another brand security-hardware for the world!
Casper.
ha ha Thanks for posting in CSC and using Cisco products!!
have a great day!!
Surendra
Community Member
lol @ last two replyes
Cisco IOS is full of buggs, i have just downgraded from IOS 15 to 12.4 to bypass one, but only have i found more.
I think cisco is not investing as much as it should in reliability. Their prices are tremendous, i just payed a fortune (at least for me) for a crappy 881w router and now i have to replace it because it is full of bugs, just tested 3 different IOS and each has diferent (realy important) ones, wtf.
Well lets just say that, with today IOS, i wouldnt thrust it in a realiable network.
Just one liner!!
"if you are hitting a bug, then we have the fix" " we make sure the bug is fixed..
Surendra
Community Member
Disagree. Sure, there are bugs, but once it runs correctly, you don't have to worry anymore. At least with the 881, ASA5510's and PIX-501's that I am working with... Great stuff.
2612
