Cisco 881W - ap gui interface problem
We have a new Cisco 881W wireless router;
used the CP Express gui interface to perform initial setup;
router assigned 10.10.10.3 as wireless ap gui interface;
when entering ap gui the entire screen is blank expect for an "enter" button near bottom;
clicking on this button does nothing; "error on page" is indicated on IE8 status;
assigned SSID is not broadcasting
Everyone's tags (3)
Re: Cisco 881W - ap gui interface problem
we are hitting the software bug.. i request you to upgrade the AP module software to the latest.. if the device is under warranty or contract, then u can open up a Cisco TAC case and we will resolve that in few mins..
Surendra
This is a common issue due to documented bug in firmware 12.4.21a.JA1 of the internal AP801.
Tthe AP can be configured and made to work after connecting to the 881 with Configuration Pro software and not Configuration Pro Express.
Full configuration of the AP can be made by connecting to the separate IP of the internal WAP with Configuration Pro.
The proper resolution requires upgrading the firmware of the WAP from older 12.4.21a.JA1 to 12.4.21a.JY
Trouble is to download this you need a paid service contract (supposedly not required for Small Business products according to some of the Cisco documents). IE You buy a Cisco product, under warranty, that doesn;'t function properly. You then have to pay more to make it work properly. Not acceptable.
I raised the issue with Cisco tech assistance, showing links to other Cisco clients with same problem, who had had the issue resolved by tech support providing them with updated firmware. Should have been straightforward, but no.
Initially Cisco denied my request stating that the issue was not due to a bug in the software, despite my original email giving links, references, plus the problems being listed on their caveats, and documented as resolved on the newer firmware caveat list.
Some weeks later, I have just received download links. If my problems are not resolved I will post again.
Main problem that Cisco needs to address is providing freely accessible updates for ALL Small Business products as they promise, and not just a small selection. A costly service contract is not an option for the small business community that only uses Cisco in some of their sales.
mdw
same thoughts here! We where also forced to pay but refused, unfortunately we stay with an non functional AP.
To me it is  unacceptable that cisco delivers non-working AP.
https://supportforums.cisco.com/thread/2003325
To overcome this problem Cisco is releasing the device with the latest image on the AP module so that we dont face this issue at all.. i guess you purchased the old device not the new..
Surendra
mdw
Surendra, what do you mean?  Buy a new one?
Remember we have this unit only since feb 2010!
Hi Maxim,
new one is not needed!!! its just the latest IOS is required. We took this issue seriously and the new routers are coming up with the latest image which is having the fix.you can refer to the Doc which i have written to overcome the issue..
https://supportforums.cisco.com/docs/DOC-13047
Surendra
mdw
Surendra,
Ok, but now I end up by not having a support contract as stated earlier by jon langley and myself.
We did bouth a new Cisco product where the AP gui is not functioning so we want an bug-fixed firmware w/o having to pay for any form of support!
Maxim
Ok.. in that case.. if your device is under warranty then you can open up a TAC case and we will help you out in publishing the software for you if you have the CCO id..
Surendra
mdw
Surendra,
We would be very pleased to receive the fixed firmware, so how can we proceed?
I already print the numbers found on the router:
CLEI Part#: COMBD00BRA
Prod.#: CISCO881W-GN-E-K9
Base P/N: CISCO881W-GN-E-K9
Serial#: FCZ1353C03Z
Maxim
Great!! now i request you to contact any below mentioned toll free numbers..
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
Surendra
Hello Surendra,
I have the same problem on my 881W, I can't access to AP configuration. The software version that I currently use is:
AP 12.4(10b)JA3
ROUTER 12.4(20)T1
My 881W is still under warranty, can I contact TAC Service?
Thank you
Enrico
Hi Enrico,
Yes you can open up a TAC case..
Surendra
mdw
Thanks Surendra,
I already received and installed the new AP801 firmware. Now we can start to find out how to configure the AP !
Maxim
Hi !!
im the same problem , but i fix it
first you must change the IOS version to ap801-k9w7-tar.124-10b.JDA3 ( you can dowload for the cisco web )
after download the image file you putt this command in the ap exec mode:
ap#archive download-sw /overwrite /force-reload tftp://x.x.x.x/ap801-k9w7-tar.124-10b.JDA3.tar
after the files are copied to flash memmory , the routyer boots with the new image ang bug fixed
its is my configuration working:
Current configuration : 3267 bytes
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$T0Qk$/wKGmrwqo0WcBbvTapaNb.
no aaa new-model
dot11 ssid CASIO
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 121A04041B04010132222727
crypto pki trustpoint TP-self-signed-4051168682
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4051168682
revocation-check none
rsakeypair TP-self-signed-4051168682
crypto pki certificate chain TP-self-signed-4051168682
certificate self-signed 01
  3082023A 308201A3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303531 31363836 3832301E 170D3131 30383139 31303037
  33385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30353131
  36383638 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B090 26BE5E77 FCB338C0 F54949DB 43EF95C1 61A9C3FA 38AC8BDC 18931195
  B1B1A503 65A71B68 8940639A FB6A6D9B 0F327B09 F5C48ECD 89C1B279 9DC6DC98
  11E5D014 914200BB 7F29CFD1 1CC5FDF0 F3AFE547 4954E2CA 37FC1CEC 60641871
  D9949391 35C958B3 FBA6FBF7 116612FD DFAB9467 478A6E07 0F7B2616 F1204158
  EC510203 010001A3 62306030 0F060355 1D130101 FF040530 030101FF 300D0603
  551D1104 06300482 02617030 1F060355 1D230418 30168014 1120DB6C BE01CDEE
  64A2DB14 FA240B27 D3573B9B 301D0603 551D0E04 16041411 20DB6CBE 01CDEE64
  A2DB14FA 240B27D3 573B9B30 0D06092A 864886F7 0D010104 05000381 81003B69
  8FC11090 E61D3BC1 D04FBDC5 622E8BC6 EB63B9FA C795BB15 BB05F417 CFC51F09
  A8A1971E 7E523203 5A40654D B71623CB A48B193A 101FD1AD 868128E9 91940B71
  5CFDDDD4 856B8170 7700C656 A75443DF DBB60F06 67E37A70 69175B84 24AB0380
  221AAA1D 3EB80465 FD1C1F49 B75B0F1D BC4A82B2 EB2176F2 27F54894 5E94
  quit
username Cisco password 7 106D000A0618
username ivan privilege 15 secret 5 $1$eEHQ$Dc.dDfXJz2fBbPIGhH.zg1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
ssid CASIO
speed  basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description  the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.10.5 255.255.255.0
no ip route-cache
ip http server
ip http authentication local
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
no activation-character
line vty 0 4
login local
end
now you cant acces to ap web gui
thanks !!!
6191
