I have a problem with my router, several time it stop working.
My SSID is not broadcasted but I can't connect to it thru wireless.
I have to reload it to make it work again...
here is my config:
running ap802-k9w7-mx.152-2.JB
version 15.2
no service pad
service password-encryption
service internal
hostname AP-1
logging rate-limit console 9
enable secret 5
no aaa new-model
no ip routing
no ip domain lookup
ip domain name jbtech.local
dot11 syslog
dot11 ssid JBTech
vlan 1
authentication open
authentication key-management wpa version 2
infrastructure-ssid optional
wpa-psk ascii 7 mykey
dot11 ssid Noob Land
vlan 2
authentication open
crypto pki trustpoint TP-self-signed-324430270
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-324430270
revocation-check none
rsakeypair TP-self-signed-324430270
crypto pki certificate chain TP-self-signed-324430270
quit
username jon privilege 15 secret 5
ip ssh version 2
ip scp server enable
bridge irb
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
ssid JBTech
ssid Noob Land
antenna gain 0
mbssid
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m8. m9. m10. m11. m12. m13. m14. m15.
packet retries 64 drop-packet
no preamble-short
channel 2427
station-role root
no cdp enable
infrastructure-client
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface GigabitEthernet0
description The embedded AP GigabitEthernet0 is an internal interface connecting ap to the host Router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 192.168.2.252 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.254
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging trap debugging
logging 192.168.2.10
access-list 20 permit 192.168.2.0 0.0.0.255
bridge 1 protocol ieee
bridge 1 route ip
line con 0
access-class 20 in
exec-timeout 0 0
privilege level 15
password 7 mypass
logging synchronous
login local
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
login local
length 0
transport input all
transport output telnet
sntp server 134.214.100.6 version 3
end
