Cisco 891w - accidentally erased AP801 flash
Thought I'd get a cisco 891w to learn on. Turns out the AP801 wireless module can't be flashed like the router itself can be from rommon. I logged into the AP801 by using service-module wlan-ap0  session
I then issued format flash and wiped the AP801's flash, then reboot the router.
Now I can't configure anything on the AP801.
I've got the file I need to reload to the AP801,  ap801-k9w7-tar.124-10b.JDA3.tar
I know there's an update to that file, but I'll stick with that one for now to get it back up.
The only prompt I get from the AP801, is: ap:
I can't use sh run
If I type help, my options are:
? -- Present list of available commands
         arp -- Show arp table or arp-resolve an address
        boot -- Load and boot an executable image
         cat -- Concatenate (type) file(s)
clear_ether -- clear ethernet port statistics
        copy -- Copy a file
      delete -- Delete file(s)
         dir -- List files in directories
   dump_regs -- dump reset registers
       etest -- test emac driver code
  ether_init -- initialize ethernet port
  flash_init -- Initialize flash filesystem(s)
      format -- Format a filesystem
        fsck -- Check filesystem consistency
        help -- Present list of available commands
load_helper -- Load and initialize a helper image
      memory -- Present memory heap utilization information
       mkdir -- Create dir(s)
        more -- Concatenate (display) file(s)
        read -- read at address
      rename -- Rename a file
       reset -- Reset the system
       rmdir -- Delete empty dir(s)
         set -- Set or display environment variables
    set_baud -- set baud rates
   set_sleep -- Pause (sleep) for a specified number of seconds
  show_ether -- show ethernet port statistics
switch_status -- report push button switch status
         tar -- extract or listing a tar file
   tftp_init -- Initialize tftp file system
        type -- Concatenate (type) file(s)
       unset -- Unset one or more environment variables
     version -- Display boot loader version
       write -- write at address
My question is, how do I get ap801-k9w7-tar.124-10b.JDA3.tar to the AP801's flash? I've tried several methods, but none of them seem to work.
Thank you.
1 REPLY
Take a look at the below link for getting an AP out of rommon mode.
https://supportforums.cisco.com/docs/DOC-14636
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
303
