Cisco AIR-SAP1602E-A-K9 not broadcasting SSID
I am having some difficulty getting an SSID to be broadcast.   I have omitted some username, password, and domain name information but the rest is the current AP config.   Would anyone know why the SSID is failing to be broadcast?  Would it be becuase the Dot11Radio0 & Dot11radio0.1 is reset?   I have shut and no shut the interfaces and reloaded the AP.    Please let me know if I need to provide more information.   Thanks in advance.
rockford-ap#sho ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       192.168.7.249   YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  reset                 down
Dot11Radio0.1              unassigned      YES unset  reset                 down
Dot11Radio1                unassigned      YES NVRAM  up                    up
Dot11Radio1.1              unassigned      YES unset  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
version 15.2
no service pad
service password-encryption
hostname rockford-ap
logging rate-limit console 9
aaa new-model
aaa group server radius rad_eap
server name 192.168.7.254
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip cef
ip domain name company.com
dot11 syslog
dot11 ssid welding
   vlan 1
   authentication open eap eap_methods
   authentication network-eap eap_methods
   guest-mode
   information-element ssidl advertisement
dot11 guest
bridge irb
interface Dot11Radio0
no ip address
antenna gain 0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
encryption vlan 1 mode wep mandatory
ssid weldering
antenna gain 0
peakdetect
dfs band 3 block
stbc
beamform ofdm
channel dfs
station-role root
interface Dot11Radio1.1
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.1
bridge-group 1
interface BVI1
ip address 192.168.7.249 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip default-gateway 192.168.7.254
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
radius server 192.168.7.254
address ipv4 192.168.7.254 auth-port 1645 acct-port 1646
key 7 0013160A005E1915
bridge 1 route ip
line con 0
line vty 0 4
transport input telnet ssh
end
Hi William,
Please check the spelling of the ssid.
The ssid configured and the ssid mapped in the Radio 1 interface is different.
dot11 ssid welding
and
no ip address
ssid weldering
Please make them identical and that should resolve the issue.
Thanks and regards,
Manas Pratap Singh.
Okay,  I have changed the config so that the SSIDs now match in both sections.   However the SSID is still not being broadcast.
Could it possible be the command "information-element ssidl advertisement" in the dot11 section?   Thanks for the assistance.   I feel like everything should be good.  Please let me know if you have any more advice.   Thanks again.
dot11 ssid welding
   vlan 1
   guest-mode
Hi William,
The configuaration looks good to me.
Let us try removing the command: information-element ssidl advertisement and see if it helps.
If this does not help do let me know... I will try another versy simple configuration as a test which will tell us if the issue is with the Hardware or software. Also please attach the show version from the AP.
Thanks and regards,
Manas Pratap Singh.
VIP Purple
Re: Cisco AIR-SAP1602E-A-K9 not broadcasting SSID
Hi William,
Since you are using vlan information under ssid, you have to issue "mbssid" command under radio interfaces. Try that & let us know
Also try NOT to use WEP which is very weak. Use WPA2/AES instead. I have given some sample config under this thread. Pls check that
https://supportforums.cisco.com/thread/2259767
Rasika
*** Pls rate all useful responses ****
291
