Cisco AIR-SAP2602I
I'm trying to deploy a WiFi solution for a client. It would consist of 2 SSIDs; one for internal users with internal network access and a guest with only internal access.
I have a Sonicwall TZ215:
External IP: x.x.x.x
LAN IP: 192.168.1.1/24
DHCP Server: 192.168.5-195/24
Cisco SG500:
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch queues-mode 4
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname xxx
ip ssh server
snmp-server location "xxx"
snmp-server contact "John Doe"
clock timezone CST 0 minutes 0
clock dhcp timezone
ip telnet server
interface vlan 1
ip address 192.168.1.2 255.255.255.0
no ip address dhcp
interface gigabitethernet1/1/1
switchport mode access
interface gigabitethernet1/1/2
interface gigabitethernet1/1/3
interface gigabitethernet1/1/4
interface gigabitethernet1/1/5
interface gigabitethernet1/1/6
interface gigabitethernet1/1/7
interface gigabitethernet1/1/8
interface gigabitethernet1/1/9
interface gigabitethernet1/1/10
interface gigabitethernet1/1/11
interface gigabitethernet1/1/12
interface gigabitethernet1/1/13
interface gigabitethernet1/1/14
interface gigabitethernet1/1/15
interface gigabitethernet1/1/16
interface gigabitethernet1/1/17
interface gigabitethernet1/1/18
interface gigabitethernet1/1/19
interface gigabitethernet1/1/20
interface gigabitethernet1/1/21
interface gigabitethernet1/1/22
interface gigabitethernet1/1/23
interface gigabitethernet1/1/24
interface gigabitethernet1/1/25
interface gigabitethernet1/1/26
interface gigabitethernet1/1/27
interface gigabitethernet1/1/28
interface gigabitethernet1/1/29
interface gigabitethernet1/1/30
interface gigabitethernet1/1/31
interface gigabitethernet1/1/32
interface gigabitethernet1/1/33
interface gigabitethernet1/1/34
interface gigabitethernet1/1/35
interface gigabitethernet1/1/36
interface gigabitethernet1/1/37
interface gigabitethernet1/1/38
interface gigabitethernet1/1/39
interface gigabitethernet1/1/40
interface gigabitethernet1/1/41
interface gigabitethernet1/1/42
interface gigabitethernet1/1/43
interface gigabitethernet1/1/44
interface gigabitethernet1/1/45
interface gigabitethernet1/1/46
interface gigabitethernet1/1/47
interface gigabitethernet1/1/48
interface gigabitethernet1/1/51
interface gigabitethernet1/1/52
exit
macro auto disabled
ip default-gateway 192.168.1.1
encrypted
Cisco AIR-SAP2602I
! Last configuration change at 00:11:27 UTC Mon Mar 1 1993 by administrator
version 15.2
no service pad
service password-encryption
hostname XXX
logging rate-limit console 9
enable secret 5 $1$RVFD$DybWHlNypzf3XsnL6RGND/
no aaa new-model
no ip routing
ip domain name XXX
dot11 syslog
dot11 vlan-name Guest_VLAN vlan 200
dot11 vlan-name Internal_Users vlan 300
dot11 vlan-name default vlan 1
dot11 ssid Internal
   vlan 300
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 05180704241A18471802161B05
dot11 ssid Guest
   vlan 200
   authentication open
   guest-mode
   mbssid guest-mode
   infrastructure-ssid optional
   wpa-psk ascii 7 10652D4B5341151E09173E
crypto pki trustpoint TP-self-signed-2946962253
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2946962253
revocation-check none
rsakeypair TP-self-signed-2946962253
crypto pki certificate chain TP-self-signed-2946962253
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32393436 39363232 3533301E 170D3933 30333031 30303431
  34325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39343639
  36323235 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009438 47D6CAB8 36B9260D D5FEFA7A DFA7E065 E47ECCA2 346674C6 54D9C004
  D6D62585 DE26A41E 447E8607 D0BD58C5 92899510 4EEBF95C 9352D082 1BB71EBF
  72D56DDC 87D55A85 4A242578 6BBD31AD E48C8354 1C7331BD 5ED9F29D 5F8B868E
  14DB0C08 3930D2D4 3266ED2D 9902DAA4 A348B722 82FCC132 6FC4BF22 DC7B9DBC
  2F010203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 149FB8D9 F772C9DE 4BC86DD9 451902F3 4994F7D8 E0301D06
  03551D0E 04160414 9FB8D9F7 72C9DE4B C86DD945 1902F349 94F7D8E0 300D0609
  2A864886 F70D0101 05050003 81810054 FBCE018A CC09679F 8CB2D20A C773DE00
  51AFA13A AB5105D5 BAAB6F2F B7CAF46A 2BFDCDDC F156593F 16C509EF 8C5215C1
  7631DEFA 9E16633C 1E89CE65 C56591B2 5BE90BD0 1941F0EA 5478924C 4C0E229D
  013743C3 2D4993E0 C44F9143 89A7A5D6 870E3A6C A772B8BB D032956F 1A5B894A
  40EC55B9 8C5E3876 7E4B45FE 3DD00B
            quit
ip ssh version 1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 100 mode ciphers aes-ccm
encryption vlan 200 mode ciphers aes-ccm
encryption vlan 300 mode ciphers aes-ccm
broadcast-key vlan 1 change 10000
broadcast-key vlan 100 change 10000
ssid Internal
ssid Guest
antenna gain 0
stbc
mbssid
station-role root
interface Dot11Radio0.200
encapsulation dot1Q 200 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.300
encapsulation dot1Q 300
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 spanning-disabled
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
antenna gain 0
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.1
encapsulation dot1Q 1
no ip route-cache
interface Dot11Radio1.200
no ip route-cache
bridge-group 1
interface Dot11Radio1.300
no ip route-cache
bridge-group 255
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
hold-queue 160 in
interface GigabitEthernet0.1
no ip route-cache
interface GigabitEthernet0.200
no ip route-cache
bridge-group 1
interface GigabitEthernet0.300
no ip route-cache
bridge-group 255
interface BVI1
ip address 192.168.1.10 255.255.255.0
no ip route-cache
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
I was able to get dhcp from the Sonicwall with 192.168.1.0/24, but not from the SG500. I created a scope(192.168.2.0/24 for guest; 192.168.3.0/24 for internal users) I even created DHCP scope on the AP, but cannot get an IP from that either. I creatd an ACL to allow the 192.168.3.0/24 access elewhere, and denied 192.168.2.0 access to other but internet.
If I disabled all scopes on the Sonicwall, I get an APIPA from both AP/SG500. Any thoughts?
1 REPLY
Cisco AIR-SAP2602I
What is your default VLAN?
On the AP, you configured VLAN 200 to be the native. is that the same with your othe devices?
"encapsulation dot1Q 200 native"
Amjad
Rating useful replies is more useful than saying "Thank you"
931
