Cisco Aironet 1100 AP - SNMP - Associated Clients
I'm been trying everything and searched the net for this without any luck this time. I found it a few years back, but now I can't.
I want to make some graph with http://oss.oetiker.ch/mrtg/ that list how many clients that are connected.
I know this is possible with SNMP, but I how no clue where to find it. I know I need the OID for this. The MIBS should not be required since as I understand it, these only translate the OID's to human readable names. Well, this could actually make it easier to find but I can't find them either.
If more information is needed, please let me know. This is really making me crazy.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Cisco Aironet 1100 AP - SNMP - Associated Clients
Mikael,
The community string cisco is arbitrary and you could make it whatever you want. It was the view definition and application of that view to your public string that were limiting what you could pull out of the MIB tree on the AP:
  • snmp-server view dot11view ieee802dot11 included
This configuration line defines a new view called "dot11view" and restricts that view to only the OIDs within the ieee802dot11 branch of the MIB tree. The included keyword is inclusionary and means this view excludes everything in the tree except what's in the ieee802dot11 branch.
  • snmp-server community public view dot11view RO
This configuration line defines a new community string called public but limits its view to the dot11view, which we created above.
  • snmp-server community cisco RO
This configuration line defines a new community string called cisco. Without a view applied it is unrestricted and if we call it we can see anything in the AP's MIB tree that we ask for.
Using the SNMP Object Navigator, I see that ieee802dot11 has OID 1.2.840.10036
The OID that you are trying to get to, cDot11ActiveWirelessClients, has a value of 1.3.6.1.4.1.9.9.273.1.1.2.1.1, which is not a subset of the 1.2.840.10036 tree.
So when you use your snmpwalker tool with the public string as it is currently defined with the dot11view, you are going to get denied to anything but the ieee802dot11 part of the MIB tree.
Please mark this question as answered to help future searchers. Thanks!
Justin
Haven't found any solution yet. So if any one ever finds one, I will be very happy to hear about it.
mvh
Mikael,
Autonomous AP or controller? Version?
Justin
We got 4 AP's (Guess we can call them Autonomous AP, if thats the correct term) which are doing RADIUS Auth to our firewall with has FreeRADIUS installed.
They are certainly not controlled anything. If I need to change any setting, I need to do it manually on all of them. I can live with that.
I'm not sure what you mean about "version" ... do you mean firmware version?
mvh
Mikael,
Do a show version at your AP command line and please post the output here.
Justin
ap30#show version
Cisco IOS Software, C1100 Software (C1100-K9W7-M), Version 12.3(8)JED, RELEASE S                                   OFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 18-Sep-09 10:28 by tinhuang
ROM: Bootstrap program is C1100 boot loader
BOOTLDR: C1100 Boot Loader (C1100-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE (                                   fc1)
ap30 uptime is 3 weeks, 5 days, 6 hours, 17 minutes
System restarted at 14:59:16 +0100 Wed Jan 25 2012
System image file is "flash:/c1100-k9w7-mx.123-8.JED/c1100-k9w7-mx.123-8.JED"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1121G-E-K9     (PowerPCElvis) processor (revision A0) with 15138K/1236K bytes of memory.
Processor board ID FOC12022Q3W
PowerPCElvis CPU at 197Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:1E:F7:6E:4F:2A
Part Number                          : 73-7886-12
PCA Assembly Number                  : 800-21481-11
PCA Revision Number                  : A0
PCB Serial Number                    : FOC12022Q3W
Top Assembly Part Number             : 800-28711-02
Top Assembly Serial Number           : FCZ1205V11T
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1121G-E-K9
Configuration register is 0xF
Mikael,
It looks like the relevant MIB file (should you decide to use it) is CISCO-DOT11-ASSOCIATION-MIB
This is the MIB object:
cDot11ActiveWirelessClients OBJECT-TYPE
        SYNTAX     Gauge32 (0..2007)
        UNITS      "Device"
        MAX-ACCESS read-only
        STATUS     current
        DESCRIPTION                 "This is the number of wireless clients
                currently associating with this device on this
                interface.
        ::= { cDot11ActiveDevicesEntry 1 }
Using the Cisco SNMP Object Navigator, this object name produces the following OID and related info:
Specific Object Information
ObjectcDot11ActiveWirelessClients
OID1.3.6.1.4.1.9.9.273.1.1.2.1.1
UnitsDevice
Range0 - 2007
MIBCISCO-DOT11-ASSOCIATION-MIB ;   -   View Supporting Imagesthis link will generate a new windowhttp://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=cDot11ActiveWirelessClients&translate=Translate&submitValue=SUBMIT
Description"This is the number of wireless clients
interface."
The SNMP Object Navigator is an excellent tool for browsing MIBs, finding and downloading MIBs relevant to your platform or image, and doing objectName-to-OID or OID-to-objectName lookups.
Justin
This is getting closer, but the problem might be another place.
When doing:
[syska@freebsd /home/syska]> snmpwalk -v 1 -c public 172.17.4.30 1.3.6.1.4.1.9.9.273.1.1.2.1.1
End of MIB
The above fails with the following: "End of MIB"
I guess I don't have to download the MIBs, just to do a lookup with the OID since it returns a integer. ( But I could be wrong here )
Now I'm just wondering if I have disabled something on the AP ... not sure what since I can query some basic information with snmpwalk.
I REALLY appreciate your help. This will be awesome if I get it working.
Silver
try -v 2c instead of -v 1
Some mibs are only available via snmp v2 or greater
Was just about to post it with 2c but saw a mail about your post blakekrone ... but almost same problem.
Using version 2c
[syska@freebsd /home/syska]> snmpwalk -v 2c -c public 172.17.4.30 .1.3.6.1.4.1.9.9.273.1.1.2.1.1
SNMPv2-SMI::enterprises.9.9.273.1.1.2.1.1 = No more variables left in this MIB View (It is past the end of the MIB tree)
I also just tried to "Reset to Defaults" ... no luck.
Can this be some kind of "bad/wrong/old/faulty" firmware on the AP's ?
System Software Filename:c1100-k9w7-tar.123-8.JED
System Software Version:12.3(8)JED
Bootloader Version:12.3(2)JA4
mvh
Mikael,
Make sure you have SNMP v2 enabled on your AP, too.
Run these two commands and post output, please (remember to sanitize community names):
# show snmp host
# show run | include snmp
Justin
When typing the following:
ap30#show snmp host
There is a empty line above after the command ... odd maybe, not sure.
ap30#show run | include snmp
snmp-server location loc
snmp-server contact con
ap30#
The above information don't tell me much, but maybe they do to you :-) cross my fingers for that.
I know that had been working sometime in the past. Not sure if it was on these firmware versions we are running now.
mvh
Mikael,
It looks like the browsable MIBS are restricted to a view. Try adding this line for testing:
(config)# snmp-server community cisco ro
After you add the above config, again try your snmpwalker utility, this time using "cisco" as the community string and see if you can hit the OID without the "end of mib" error.
Justin
Hi Justin,
HOLY crap ... it works.
I'm no expert on snmp, but howcome the information is not availble for the "public" community? is in some built-in restriction on that name?
I have used HOURS on that, and the fix is so simple. I think I even have used that OID before, but got that error and well, thought it was wrong because of the error I got.
Thanks ... this saved my day.
Mikael,
Justin
Makes sence ... and again ... THANKS, this makes it alot easier to monitor how many connected users there are.
Mikael Syska
7588
